Canon Support for PowerShot SD500 | Canon U.S.A., Inc.
PowerShot SD500
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.23 MB
Date 05.23.08
File Size 4.45 MB
Date 10.25.07
File Size 4.45 MB
Date 10.25.07
File Size 464.44 KB
Date 10.25.07
File Size 1.01 MB
Date 05.23.08
File Size 1.16 MB
Date 10.25.07
File Size 1.16 MB
Date 10.25.07
File Size 2.88 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital camera with built-in flash and 3x Optical/4x Digital/12x Combined Zoom
Image Capture Device
Type 7.1 Megapixel, 1/1.8 inch type Charge Coupled Device (CCD)
Total Pixels Approx. 7.4 Megapixels
Effective Pixels Approx. 7.1 Megapixels
Lens
Focal Length 7.7-23.1mm f/2.8-4.9 (35mm film equivalent: 37-111mm)
Digital Zoom 4x
Focusing Range NORMAL: 1.6 ft./50cm-infinity
MACRO: 2.0 in.-1.6 ft./5-50cm (W), 1.0-1.6 ft./30-50cm (T
DIGITAL MACRO: 2.0-3.9 in./5-10cm (W)
Autofocus System 9-point AiAF/1-point AF (fixed to center) (Intelligent Orientation Sensor), AF Lock, AF-assist Beam On/Off
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 2.0 inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 118,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8-7.1 (W), f/4.9-13.0 (T)
Shutter Speed 15-1/2000 sec.
Exposure Control
Sensitivity AUTO, ISO 50/100/200/400 equivalent
Light Metering Method Evaluative, Center-weighted average, Spot*
*Metering frame with Spot mode is center fixed.
Exposure Control Method Program AE, AE Lock is available
Exposure Compensation +/- 2 stops in 1/3-stop increments
ND Filter Not Available
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), Custom
Flash
Built-in Flash Operation Modes: Auto*, Flash On*, Flash Off, Slow Synchro* Red-Eye Reduction is available
Flash Range Normal: 1.6-15.8 ft./50cm-4.8m (W), 1.6-9.2 ft./50cm-2.8m (T)
Macro: 1.0-1.6 ft./30-50cm (W/T) (When sensitivity is set to Auto)
Recycling Time Approx. 10 sec. or less (battery voltage=3.7V)
Flash Exposure Compensation Not Available
Shooting Specifications
Shooting Modes Still Images: Auto, Manual, Scene Modes (Digital Macro, Portrait, Night Snapshot, Kids & Pets, Indoor, Underwater), My Colors, Stitch Assist; Movies: Standard, Fast Frame Rate, Compact, My Colors.
Photo Effects Off, Vivid, Neutral, Low Sharpening, Sepia, Black & White
Self Timer Activates shutter after an approx. 2-sec. or approx 10-sec. delay, custom
Wireless Control Not Available
Continuous Shooting Approx. 2.0 shots/sec.
Image Storage
Storage Media SD memory card
Print Order Format Design rule for camera file system Exif 2.2 (JPEG) and DPOF (Version 1.1) compliant
Image Recording Format Still: Exif 2.2 (JPEG)
Movies: AVI (Image data: Motion JPEG; Audio data: WAVE (Monaural))
JPEG Compression Mode Normal, Fine, SuperFine
Number of Recording Pixels Still Image: 3072x2304 (Large), 2592x1944 (Medium 1), 2048x1536 (Medium 2), 1600x1200 (Medium 3), 640x480 (Small), 1600x1200 (Postcard Date Imprint Mode)
Movie: 640x480, 320x240, 160x120
Number of Recordable Images
Image data &#160;
Time of Recordable Movies
Movie data &#160;Note: N=Normal F=Fine SF=SuperFine
Storage capacity varies depending on the scene or the subjects. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of SD Memory Card. Individual clips are limited to 3 minutes. The values given above vary depending on the subject, shooting conditions and shooting mode.
Playback Specifications
Playback Modes File Single, Index (9 thumb images), Normal Playback, Special Playback, Slow Motion, Movie Editing
Erasing Specifications
Erase Modes Still Images: Single Images, All Images
Movies: Part of Movie, All of Movie
Interfaces
Computer Interface USB 2.0 Hi-Speed (mini-B/PTP)
Video Out NTSC, PAL
Audio Out Monaural
Other SD memory card slot. Direct connection to Canon CP Printers and select BJ Printers (no computer required)
Power Supply 1. One Rechargeable lithium-ion battery NB-3L
2. AC Adapter Kit (ACK-900)NB-3L: LCD On - Approx. 160 shots (CIPA Test Standard); LCD Off - Approx. 550 shots.Approx. 210 minutes (Under Canon's standard conditions*1 with fully charged battery)
Power Source 1. One Rechargeable lithium-ion battery NB-3L
Shooting Capacity NB-3L: LCD On - Approx. 160 shots (CIPA Test Standard); LCD Off - Approx. 550 shots.
Playback Time Approx. 210 minutes (Under Canon's standard conditions*1 with fully charged battery)
Physical Specifications
Operating Temperature 32-104&deg F/0-40&deg C
Operating Humidity 10-90%
Dimensions (W x H x D) 3.37 x 2.24 x 1.04 in./85.6 x 57.0 x 26.5mm (Excluding protrusions)
Weight Approx. 6.0 oz./170g (camera body only)
Note: *1 Normal temperature (73&deg F/23&deg C). Shoot images at wide angle and at telephoto end alternatively with 20 second intervals. Use flash every fourth shot. Turn camera off and on after every eight shots. LCD brightness setting by Factory default.
21 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
