Canon Support for PowerShot SX160 IS | Canon U.S.A., Inc.
PowerShot SX160 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
16.0 Megapixel 1/2.3-inch CCD
Total Pixels
Approx. 16.6 Megapixels
Effective Pixels
Approx. 16.0 Megapixels
Focal Length
5.0 (W) - 80.0 (T) mm (35mm film equivalent: 28 - 448 mm)
Optical Zoom
16x
Digital Zoom
4x
Focusing Range
Normal/Auto: 0.4 in. (1 cm) - infinity (W), 2.0 ft. (60 cm) - infinity (T)
Macro AF: 0.4 in. 1.6 ft. (1-50 cm) (W)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
N/A
LCD Monitor
3.0-inch TFT color LCD with wide viewing angle
LCD Pixels
Approx. 230,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.5 (W) - f/5.9 (T)
Shutter Speed
1-1/3200 sec.
15-1/3200 sec. (Total shutter speed range)
Sensitivity
Auto, ISO 80/100/200/400/800/1600
Light Metering Method
Evaluative*, Center-weighted Average, Spot**
* Facial brightness is evaluated in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: +/-2 stops in 1/3-stop increments
Videos: +/-2 stops in 1/3-stop increments (Not available when shooting movies)
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Camera automatically sets the optimal ISO speed according to shooting mode.
Built-in Flash
Auto, Flash On, Slow Synchro, Flash Off
- Facial brightness is also evaluated in Face Detect.
Flash Range
1.6 - 9.8 ft. (W), 2.0 - 6.6 ft. (T) (50cm - 3.0m (W), 60cm - 2.0m (T))
Recycling Time
15 seconds or less (battery voltage: 3.0 V)
Flash Exposure Compensation
Shooting Modes
M, Av, Tv, P, Live View Control, Auto, SCN*1, Creative Filters*2, Discreet, Movie*3
Shooting movies is possible with the movie button
*1 Portrait, Face Self-timer, Low Light, Snow, Fireworks
*2 Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect
*3 Standard, iFrame Movie
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color**Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay, approx. 2-sec. delay, custom*
*Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Normal: Approx. 0.8 shots/sec. (in P mode)
Normal: Approx. 2.8 shots/sec. (in Low Light mode)
AF: Approx. 0.5 shots/sec. (in P mode)
LV: Approx. 0.6 shots/sec. (in P mode)
Under conditions where the flash does not fire automaticallyDiffers depending on the zoom position
Storage Media
SD Memory Card, SDHC Memory Card, SDXC Memory Card
File Format
Design rule for Camera File System, DPOF (Version 1.1) compliant
Image Recording Format
Superfine / Fine
JPEG Compression Mode
Still Image: 2.3 (JPEG)
Video: MOV (image data: H.264, Audio data: Linear PCM (Stereo))
Number of Recording Pixels
Still Images:
[16:9]
Large: 4608 x 2592
Medium 1: 3264 x 1832
Medium 2: 1920 x 1080
Small: 640 x 360
[3:2]
Large: 4608 x 3072
Medium 1: 3264 x 2176
Medium 2: 1600 x 1064
Small: 640 x 424
[4:3]
Large: 4608 x 3456
Medium 1: 3264 x 2448
Medium 2: 1600 x 1200
Small: 640 x 480
[1:1]
Large: 3456 x 3456
Medium 1: 2448 x 2448
Medium 2: 1200 x 1200
Small: 480 x 480
Videos:
HD 1280 x 720: 25 fps
iFrame Movie HD 1280 x 720: 30 fps / 25 fps
Miniature Effect HD 1280 x 720: 5 fps / 2.5 fps / 1.25 fps
Miniature Effect 640 x 480: 6 fps / 3 fps / 1.5 fps
640 x 480: 30 fps (29.97)
Image data
&nbsp;&nbsp;&nbsp;
Note: SF=Superfine F=Fine
*When in High-speed Burst, Movie Digest or Low Light.
- The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
*1 Playback frame is 25 fps.
*2 Playback frame is 30 fps*3.
*3 Actual frame rate is 29.97 fps.
Playback Modes File
Stills & Videos: Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Operation Tools, Transition Effects, Scroll Display, Active Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Image Search, Slideshow (Playback Interval, Repeat, Effect, Playlist)
Still Images: Single, Index (4-130 thumbnails), Magnification (2-10x), Information Display, Red-eye Correction, i-Contrast, Trimming, Resize, My Colors, Focus Check, Histogram, Overexposure Warning
Videos: Normal Playback*, Skip Backward**, Previous Frame***, Next Frame***, Skip Forward**
* Audio settings available in 5 levels
** Approximately 4 seconds
*** Slow motion available
Erase Modes
Select Image, Select Range, Select All Images
- The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).
- Using the Movie editing function, sections of the movie (1 sec. increments) can be deleted.
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Mini-HDMI connector
Audio Out
Stereo (dedicated connector (female) with unified type of digital, audio and video)
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
1) 2 AA Alkaline batteries
2) AC Adapter Kit ACK-800
Shooting Capacity
AA Alkaline: Approx. 140 shots
AA NiMH: Approx. 380 shots
Playback Time
AA Alkaline Batteries: Approx. 7 hours
AA NiMH Batteries (NB-3AH): Approx. 10 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.37 x 2.85 x 1.74 in (111.0 x 72.5 x 44.1 mm)
Weight
CIPA standard: Approx. 10.3 oz. or 291 g
Camera Body Only: Approx. 8.57 oz. or 243 gNote: 27 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, and Hindi).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
