Canon Support for PowerShot SX710 HS | Canon U.S.A., Inc.
PowerShot SX710 HS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.06.15
File Size 10.18 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
20.3 Megapixel, 1/2.3-inch CMOS
Total Pixels
Approx. 21.1 Megapixels
Effective Pixels
Approx. 20.3 Megapixels*
*Image processing may cause a decrease in the number of pixels.
Focal Length
4.5mm (W) - 135.0mm (T) (35mm film equivalent: 25-750mm)
Optical Zoom
30x
Digital Zoom
4.0x
Focusing Range
Auto: 0.4 in. (1 cm) - infinity (W), 4.6 ft. (1.4 m) - infinity (T);
Normal: 2.0 in. (5 cm) - infinity (W), 4.6 ft. (1.4 m) - infinity (T);
Macro: 0.4 in. - 1.6 ft. (1 - 50 cm);
Sports: 3.3 ft. (1 m) - infinity (W), 26.0 ft. (8m) - infinity (T)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
Not available
LCD Monitor
3.0-inch TFT Color LCD with wide viewing angle (4:3)
LCD Pixels
Approx. 922,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.2 (W), f/6.9 (T)
Shutter Speed
1 - 1/3200 sec.
15 - 1/3200 sec. (in Tv and M Modes)
Sensitivity
Auto, ISO 80-3200
Available in 1-step increments
Light Metering Method
Evaluative*1, Center-weighted average, Spot*2
*1 Facial brightness is evaluated (Face Detect AE) in Face Detect.
*2 Fixed to Center, linked to AF frame
Exposure Control Method
AE Lock
Exposure Compensation
&plusmn;2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Facial color is evaluated in Face Detect (Face Detect WB).
Adjusts the white balance separately for the main subject and the background when the flash fires
Built-in Flash
Auto, On, Slow Synchro, Off
Facial brightness is also evaluated in Face Detect
Flash Range
1.6 - 11 ft. (W), 4.6 - 6.6 ft. (T) / (50cm - 3.5m (W), 1.4 - 2.0m (T))
Image brightness at the corners may diminish depending on the shooting distance
Recycling Time
10 seconds or less (battery voltage: 3.7 V)
Flash Exposure Compensation
&plusmn;2 stops in 1/3 increments
Shooting Modes
M, Av, Tv, P, Live View Control, Hybrid Auto, Auto, Creative Shot1, Sports, Portrait, SmartShutter2, Handheld Night Scene, Low Light, Snow, Fireworks, Fish-eye Effect, MiniatureEffect, Toy Camera Effect, Soft Focus, Monochrome, Super Vivid, Poster Effect, Standard Movie, Short Clip, iFrame Movie
*1Auto, Retro, Monochrome, Special and Natural effects
2Smmile, Wink Self-timer, FaceSelf-timer
Shooting movies is possible with the movie button
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black &amp; White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
* Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available.
Self Timer
Approx. 10-sec. delay, Approx. 2-sec. delay, Custom
Wireless Control
Wi-Fi&trade; and NFC
Continuous Shooting
Normal: Approx. 3.1 shots/sec. (in P mode)
Normal: Approx. 8.5 shots/sec. (in High-speed Burst HQ)
Under conditions where the flash does not fire automatically.Differs depending on the zoom position.
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
JPEG (Superfine, Fine)
JPEG Compression Mode
Still Image: Exif 2.3 JPEG
Video: MP4 (Image data: MPEG-4 AVC/H.264; Audio data: MPEG-4 AAC-LC (Stereo))
Number of Recording Pixels
Still Images:
1) 16:9 - Large: 5184 x 2912; Medium 1: 3648 x 2048; Medium 2: 1920 x 1080; Small: 640 x 360
2) 3:2 - Large: 5184 x 3456; Medium 1: 3648 x 2432; Medium 2: 2048 x 1368; Small: 640 x 424
3) 4:3 - Large: 5184 x 3888; Medium 1: 3648 x 2736; Medium 2: 2048 x 1536; Small: 640 x 480
4) 1:1 - Large: 3888 x 3888; Medium 1: 2736 x 2736; Medium 2: 1536 x 1536; Small: 480 x 480
5) In Low Light: Medium: 2592 x 1944
Videos:
Full HD 1920 x 1080: 60 fps (59.94), 30 fps (29.97)
iFrame Movie 1920 x 1080: 30 fps (29.97)
HD 1280 x 720: 30 fps (29.97)
Digest Movie 1280 x 720: 30 fps (29.97)
Miniature Effect 1280 x 720*1: 6 fps, 3 fps, 1.5 fps
Miniature Effect 640 x 480*1: 6 fps, 3 fps, 1.5 fps
Short Clip 1280 x 720: 30 fps (29.97)
1Playback: 30 fps (29.97)
Image data
Note: SF=Superfine / F=Fine
* When in Low Light.
&#8226; The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
&#42;1 Using an SD Speed Class 10 / UHS-I compatible memory card.
&nbsp; &#8226; Recording stops automatically once the file size reaches 4 GB or the memory card becomes full.
&nbsp; &#8226; Recording may stop unexpectedly if a memory card with a low Speed Class is used.
&#42;2 Actual frame rate is 59.94 fps.
&#42;3 Actual frame rate is 29.97 fps.
Playback Modes File
Still Images & Videos:
Auto Rotate, Transition Effects (Off, Fade), Scroll Display, Rotate, Favorites, Search Jump (Favorites, Date, Still Images, Movies, Digest, Jump 10 Images, Jump 100 Images), Smart Shuffle, Group Playback, Movie Digest, Filtered Playback, Slideshow
Still Images:
Single, Index, Magnification (Approx. 2x-10x), Thumbnails, Information Display, Histogram, Overexposure Warning, Resume Playback, Red-Eye Correction, Cropping, i-Contrast, Resize, My Colors
Videos:
Normal Playback, Skip Backward, Previous Frame, Next Frame, Skip Forward, Resume Playback, Erase Clip, Edit Digest Movie
Erase Modes
Select*1, Select Range, Select All Images
The image data in memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased).
RAW+JPEG images can be erased individually.
*1 Movies can be erased individually.
Video Out
Analog: NTSC or PAL, Digital: HDMI (HDMI&trade; micro connector)
Audio Out
Stereo
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA and PictBridge-compatible printers
Power Source
Battery Pack NB-6LH, AC Adapter Kit ACK-DC40
Shooting Capacity
Approx. 230 Shots
Approx. 315 Shots in ECO Mode
Playback Time
Approx. 4 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.44 x 2.59 x 1.37 in. / 112.7 x 65.8 x 34.8mm
Weight
Approx. 9.49 oz. / 269g (CIPA standard)
Approx. 8.64 oz. / 245g (Body only)Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, Vietnamese).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
