Canon Support for PowerShot SX740 HS | Canon U.S.A., Inc.
PowerShot SX740 HS
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 07.17.25
File Size 6.21 MB
Date 08.01.18
File Size 385.30 KB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Compact digital still camera with built-in flash, 40x Optical, 4x Digital and 160x Combined Zoom with Optical Image Stabilizer
Type
20.3 Megapixel*, 1/2.3-inch CMOS
* Image processing may cause a decrease in the number of pixels.
Total Pixels
Approx. 21.1 Megapixels
Effective Pixels
Approx. 20.3 Megapixels
Focal Length
4.3 (W) - 172.0 (T) mm (35mm film equivalent: 24-960mm)
Optical Zoom
40x
Digital Zoom
Approx. 4x
Focusing Range
Auto: 0.4 in. (1cm) - infinity (W), 6.6 ft. (2.0m) - infinity (T)
Normal: 2.0 in. (5cm) - infinity (W), 6.6 ft. (2.0m) - infinity (T)
Macro: 0.4 in. - 1.6 ft. (1-50cm) (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
Not available
LCD Monitor
3.0-inch TFT Color LCD with wide viewing angle (4:3)
LCD Pixels
Approx. 922,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.3 (W), f/6.9 (T)
Shutter Speed
1 - 1/3200 sec.
15 - 1/3200 sec. (in all shooting modes)
Sensitivity
Auto: ISO 100-1600
P: ISO 100-3200
Light Metering Method
Evaluative, Center Weighted Average, Spot
Exposure Compensation
&plusmn;3 stops in 1/3-stop increments
White Balance Control
Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Custom, WB Correction
Built-in Flash
Auto, On, Slow Synchro, Off
Flash Range
Approx. 1.6-16.4 ft. (W), 6.6-8.2 ft. (T)Approx. 50.0cm - 5.0m (W), 2.0m-2.5m (T)
Flash Exposure Compensation
&plusmn;2 stops in 1/3 increments
Shooting Modes
P, M, Tv, Hybrid Auto, Auto, Standard, Vivid, Neutral, B/W, Sepia, Video Snapshot, Food
Self Timer
Off / 2 sec. / 10 sec. / Custom
Wireless Control
Built-in Wi-Fi&trade; and Bluetooth&reg;
Continuous Shooting
High-speed Continuous Shooting in One-Shot AF mode: Approx. 10.0 shots/sec.
Low-speed Continuous Shooting in One-Shot AF mode: Approx. 4.0 shots/sec.
High-speed Continuous Shooting in Servo AF mode: Approx. 7.4 shots/sec.
Low-speed Continuous Shooting in Servo AF mode: Approx. 4.0 shots/sec.
Continuous shooting speed may become slower due to the following factors: Tv value, Av value, subject conditions, shooting environment, use of flash, ISO speed, zoom position.
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible
Image Recording Format
Fine / Normal
JPEG Compression Mode
Still Image: EXIF 2.31 (JPEG)
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo))
Number of Recording Pixels
Still Images:
  1. 16:9 - Large: 5184 x 2912; Medium 1: 3648 x 2048; Small: 2432 x 1368
  2. 3:2 - Large: 5184 x 3456; Medium: 3648 x 2432; Small: 2432 x 1616
  3. 4:3 - Large: 5184 x 3888; Medium: 3648 x 2736; Small: 2432 x 1824
  4. 1:1 - Large: 3888 x 3888; Medium: 2736 x 2736; Small: 1824 x 1824
Videos:
4K 3840 x 2160: 29.97 fps
Full HD 1920 x 1080: 59.94 fps, 29.97 fps
HD 1280 x 720: 59.94 fps
Playback Modes File
Protect, Rotate, Erase, Set Image Search Conditions, Slideshow, Photobook Set-up, Rating, Movie Playback, Highlight Alert, Movie Frame Grab*, Resize**, Cropping**, Tilt Correction**, Red-Eye Correction**
* 4K movies only.
** Applicable only to images taken with the same model.
Video Out
HDMI (Type D)
Audio Out
Stereo
Other
Hi-Speed USB (Micro); direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack NB-13L
Shooting Capacity
Approx. 265 shots
Approx. 370 shots in ECO Mode
Video Recording Time (CIPA compliant): Approx. 60 min.
Video Recording Time (Continuous Shooting): Approx. 100 min.
Playback Time
Approx. 5 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
Approx. 4.33 x 2.51 x 1.57 in. / 110.1 x 63.8 x 39.9mm
Weight
Approx. 10.5 oz. / 299g (CIPA standard)
Approx. 9.7 oz. / 275g (Body only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: PowerShot SX740 HS: Firmware Version 1.0.2
Advisory Type
Date 11.20.19
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
