Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 05.29.26
File Size 1.75 MB
Date 05.29.26
File Size 2.78 MB
Power LAN Terminal: PoE power supply supported (IEEE802.3af Compliant)
DC IN 12V terminal: DC input: DC 11.4 - 12.6 V
Power Consumption
PoE input: 12.4 W (max power consumption)
DC input: 11.4 W (max power consumption)
Dimensions (W x H x D) Approx. 10.04 x 3.7 x 7.09 inches (255 × 94 × 180 mm)
Weight Approx.3.09 lbs (1.4kg)
Operating Temperature 0°C +40°C (+32°F +104°F)
Controller Supported Cameras CR-N700, CR-N500, CR-N400, CR-N350, CR-N300, CR-N100, CR-X500, CR-X300, XF605, EOS C300 Mark III, EOS C500 Mark II, EOS C70, EOS C400, EOS C80, EOS C50
Number of Connectable Cameras 200 (1 with serial connection)
Number of Camera Select Buttons 10
Number of Camera Groups 20 (10 cameras in 1 group)
Supported Protocols XC protocol (IP) NU protocol (serial), Standard (serial)
Preset (Store/Play/Delete) Up to 100 for each camera
Trace (Store/Play/Delete) Up to 10 for each camera
Other Controls Control lever, zoom rocker, focus dial, user buttons x 12 (3 Hard Buttons), dials x 8, up down left right select buttons
Supported Add-On Applications RA-AT001 Auto Tracking Application, RA-AL001 Auto-loop Application
Stream Deck Support Stream Deck Mini, Stream Deck Mk.2, Stream Deck XL*, Stream Deck Pedal
* - External power supply required via USB Hub
LCD Display 3.5-inch touch panel, 1280 x 720 resolution
Camera Video Preview YES (IP), up to 9 cameras per page
Touch Focus YES (IP)
Crop Frame Control YES (IP - CR-N700, CR-N400, CR-N350 only)
OSD Menu Display YES (IP, select cameras only**)
**XF605, EOS C70, EOS C500 Mark II, EOS C300 Mark III
Assist Display Waveform Monitor, Vector Scope, Center/Grid/Area Marker
GPIO D-Sub 9pin x 1 port For GPIO external control/link
LAN / PoE+ RJ45 port IP camera control, IP video input, PoE power supply
Serial RJ45 port x 1 RS-422 Serial camera control
12V DC Input DC Power - Adapter Included
USB Type A x1 Save Settings, Firmware Updates, Stream Deck Support
CANON U.S.A., INC. LIMITED WARRANTY
RC-IP1000 and RC-IP300 PRODUCT LIMITED WARRANTY
Canon U.S.A., Inc. (“Canon”) warrants (a) the Canon RC-IP1000 and RC-IP300 product (the “Product”), when sold and used in the United States, to be free from defects in workmanship and materials under normal use and service for a period of One (1) year from the date of receipt by purchaser. During such warranty period, Canon will, at its option, repair or replace a Product.
(1)which is returned to Canon’s designated service center, transportation charges prepaid,(2)which is proven to be defective upon Canon’s inspection and (3) which isotherwise eligible for coverage under this limited warranty. A Product repaired byCanon under this limited warranty will be returned to the purchaser’s designated locationwithin the United States at Canon’s expense. Warranty replacement will not extend theoriginal warranty period of a Product.
The purchaser’s cost of labor to inspect and remove a defective Product, and to install repaired or replaced Products in the field, will be purchaser’s sole responsibility and will therefore not be reimbursable by Canon. Canon will have no liability for use or performance of the Product in connection with the purchaser’s systems, even though purchaser discusses the same from time to time with Canon employees.
This warranty shall only apply if a Product is used in conjunction with compatible software, computers and other equipment, as to which items Canon will have no responsibility. This warranty does not cover Canon brand optional accessories for a Product for which separate warranties are given.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES AND CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES AND CONDITIONS REGARDING MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF A PRODUCT. NO OTHER EXPRESS WARRANTY, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO A PRODUCT WILL BIND CANON. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
THE PRODUCTS ARE NOT FAULT TOLERANT AND ARE NOT DESIGNED, MANUFACTURED OR INTENDED FOR USE OR RESALE AS CONTROL EQUIPMENT IN HAZARDOUS ENVIRONMENTS REQUIRING FAIL SAFE CONTROLS, SUCH AS, WITHOUT LIMITATION, THE OPERATION OF NUCLEAR FACILITIES, AIRCRAFT NAVIGATION OR AIRCRAFT COMMUNICATION SYSTEMS, AIR TRAFFIC CONTROL, LIFE SUPPORT, OR WEAPONS SYSTEMS (“HIGH RISK ACTIVITIES”). IN ADDITION TO THE OTHER DISCLAIMERS HEREIN, CANON SPECIFICALLY DISCLAIMS ANY EXPRESS OR IMPLIED WARRANTY OR CONDITION OF FITNESS FOR SUCH HIGH RISK ACTIVITIES.
This warranty shall be void and of no force or effect if a Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating instructions, or maintenance, and environmental conditions prescribed, in Canon’s operator’s manual or other documentation, (c) installation or repair by other than Canon service centers, (d) use of supplies or parts (other than those distributed by Canon) which damage a Product or cause abnormally frequent service calls or service problems, or (e) use of a Product with non-compatible software, computers, or other equipment, including the use of a Product in any system configuration not recommended in any manual distributed with a Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered.
CANON WILL NOT BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE A PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF A PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE A PRODUCT SOLD BY CANON NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON. THIS WARRANTY WILL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF A PRODUCT AND STATES SUCH PURCHASER’S EXCLUSIVE REMEDY.
IT IS UNDERSTOOD AND AGREED THAT THIS LIMITED WARRANTY CAN ONLY BE ENFORCED BY PURCHASER. IT IS FURTHER UNDERSTOOD AND AGREED THAT UPON SELLING A PRODUCT, WHETHER ALONE OR IN ITS SYSTEMS, PURCHASER WILL DELIVER ITS OWN WARRANTY TO ITS CUSTOMERS. BUYER’S WARRANTY TO ITS CUSTOMERS SHALL STATE CONSPICUOUSLY THAT THE SAME IS THE SOLE AND EXCLUSIVE WARRANTY COVERING A PRODUCT.
A range of Canon USA customer technical support* options are available:
  • Visit www.usa.canon.com/support for Interactive troubleshooting guidance, to obtain the latest driver downloads, hours of operation, and answers to frequently asked questions
  • Toll-free live technical support Monday–Friday (excluding Canon-observed holidays) at 1-800-423-5367
Warranty Service:
In the event service is required for the Product during the limited warranty period, a Canon USA Customer Care Center representative will attempt to diagnose the nature of the problem and, ifpossible, correct it over the telephone. If the problem cannot be corrected over the telephone, youwill be provided instructions for Canon USA’s then current warranty service procedures. Youmay be asked for the Product serial number and/or other information pertaining to your Product.
*Support program specifics are subject to change without notice.
CONDITIONS OF WARRANTY
Defective parts must be returned to Canon with all necessary documentation and will becomethe property of Canon. Canon is a registered trademark of Canon Inc.
Title Firmware Notice: RC-IP300: Firmware Version 1.0.1
Advisory Type Firmware Notice
Date 11.16.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
