var baseURL = 'https://www.usa.canon.com';
var prodSite = 'Y';
var wcmPathStripStart = 'canon_newweb_products/products';
var portalContextRoot = '/internet/portal';
var virtualPortalName = '/us';
var useMaritzCXSurvey = 'Y';
var maritzSurvey = 'M6BSBQ';
var maritzSurveyUrl = 'https://canonusa.esaas.inmoment.com/surveys/M6BSBQ/Scripts/clientExtensibility.js';
var surveyURL = 'https://canonusa.esaas.inmoment.com/cgi-bin/qwebcorporate.dll?idx=M6BSBQ';
var mcxSiteInterceptParameters = {
surveyURL: surveyURL, //string
showOnLoad: true, //boolean
invitationID: undefined, //string
probability: 33, //number (0 - 100 (%))
width: 750, //number (px)
height: 900, //number (px)
cookieID: "", //string
expireDaysIfYes: 60, //number (days)
expireDaysIfNo: 60, //number (days)
delay: undefined, //number (ms)
waitUntilClose: false, //boolean
placeholderURL: undefined, //string
showInline: undefined, //boolean
inlineID: undefined, //string
inlineWrapperID: undefined, //string
inlineCloseID: undefined, //string
cleanseCookie: false, //boolean
debug: undefined, //boolean
ignoreWarning: undefined, //boolean
enabled: undefined, //boolean
domainPath: '',
pagevisit: 45,
mcxBlackList: ["http.support..usa.canon.com/kb/index.page=home"]
(function(w){
"use strict";
//Check to make sure custom parameters exist
if(typeof w.mcxSiteInterceptParameters === 'undefined') {
//Backward compatibility (for customers who have <v1.3)
if(typeof w.allegianceSiteInterceptParameters !== 'undefined') {
w.mcxSiteInterceptParameters = w.allegianceSiteInterceptParameters;
console.warn("The parameters variable (allegianceSiteInterceptParameters) needs to be renamed to mcxSiteInterceptParameters inside of the client extensibility. allegianceSiteInterceptParameters may be deprecated in future versions.");
} else {
console.warn("mcxSiteInterceptParameters undefined, ensure that it is defined in client extensibility and that the site intercept script is loaded in after the client extensibility script. Default parameters used.");
w.mcxSiteInterceptParameters = "";
var isArray = function() { return w.mcxSiteInterceptParameters && w.mcxSiteInterceptParameters.constructor === Array && w.mcxSiteInterceptParameters.length > 0; };
if(isArray()) {
var MCX_DEFAULT = 'MCX_DEFAULT';
var mcxUniqueID = w.mcxUniqueID || MCX_DEFAULT;
//Check over each item to see if a uniqueID matches
for(var i = 0; i < w.mcxSiteInterceptParameters.length; i++) {
if(w.mcxSiteInterceptParameters[i].uniqueID && mcxUniqueID == w.mcxSiteInterceptParameters[i].uniqueID) {
w.mcxSiteInterceptParameters = w.mcxSiteInterceptParameters[i];
//If no matches were found, attempt to assign default
if(isArray()) {
for(var j = 0; j < w.mcxSiteInterceptParameters.length; j++) {
if(w.mcxSiteInterceptParameters[j].uniqueID && MCX_DEFAULT == w.mcxSiteInterceptParameters[j].uniqueID) {
w.mcxSiteInterceptParameters = w.mcxSiteInterceptParameters[j];
//If no default was assigned, use the first item
if(isArray()) {
w.mcxSiteInterceptParameters = w.mcxSiteInterceptParameters[0];
var mcxPresetParam = w.mcxSiteInterceptParameters;
w.McxSiteInterceptOnExit = {
//Parameters used for customizing script
parameters: {
//Defaults
surveyURL: typeof mcxPresetParam.surveyURL === 'string' ? mcxPresetParam.surveyURL : "",
showOnLoad: typeof mcxPresetParam.showOnLoad === 'boolean' ? false : false,
invitationID: typeof mcxPresetParam.invitationID === 'string' ? mcxPresetParam.invitationID : "",
probability: typeof mcxPresetParam.probability === 'number' ? mcxPresetParam.probability : 100, //0 - 100%
width: typeof mcxPresetParam.width === 'number' ? mcxPresetParam.width : 550, //px
height: typeof mcxPresetParam.height === 'number' ? mcxPresetParam.height : 520, //px
cookieID: typeof mcxPresetParam.cookieID === 'string' ? mcxPresetParam.cookieID : "",
expireDaysIfYes: typeof mcxPresetParam.expireDaysIfYes === 'number' ? mcxPresetParam.expireDaysIfYes : 30, //days
expireDaysIfNo: typeof mcxPresetParam.expireDaysIfNo === 'number' ? mcxPresetParam.expireDaysIfNo : 30, //days
delay: typeof mcxPresetParam.delay === 'number' ? mcxPresetParam.delay : 0, //ms
waitUntilClose: typeof mcxPresetParam.waitUntilClose === 'boolean' ? mcxPresetParam.waitUntilClose : false,
placeholderURL: typeof mcxPresetParam.placeholderURL === 'string' ? mcxPresetParam.placeholderURL : "",
showInline: typeof mcxPresetParam.showInline === 'boolean' ? mcxPresetParam.showInline : false,
inlineID: typeof mcxPresetParam.inlineID === 'string' ? mcxPresetParam.inlineID : "mcxSurveyDialog",
inlineWrapperID: typeof mcxPresetParam.inlineWrapperID === 'string' ? mcxPresetParam.inlineWrapperID : "mcxSurveyWrapper",
inlineCloseID: typeof mcxPresetParam.inlineCloseID === 'string' ? mcxPresetParam.inlineCloseID : "mcxSurveyClose",
cleanseCookie: typeof mcxPresetParam.cleanseCookie === 'boolean' ? mcxPresetParam.cleanseCookie : false,
debug: typeof mcxPresetParam.debug === 'boolean' ? mcxPresetParam.debug : false,
ignoreWarning: typeof mcxPresetParam.ignoreWarning === 'boolean' ? mcxPresetParam.ignoreWarning : false,
enabled: typeof mcxPresetParam.enabled === 'boolean' ? mcxPresetParam.enabled : true,
pageVisit: typeof mcxPresetParam.pageVisit === 'number' ? mcxPresetParam.pageVisit : 4,
mcxBlackList: typeof mcxPresetParam.mcxBlackList === 'object' ? mcxPresetParam.mcxBlackList : [],
domainPath: typeof mcxPresetParam.domainPath === 'string' ? mcxPresetParam.domainPath : ""
takeSurvey: false, //Script-level variable, leave false.
surveyWindow: undefined, //Survey window, leave undefined.
surveyURLParams: undefined,
cachedHTML: undefined,
//Called when the page is loaded. Executes logic to determine whether to show the invitation or not.
onPageLoad: function () {
w.mcxLog('onPageLoad');
w.McxSiteInterceptOnExit.cookieVisitCount();
if(w.McxSiteInterceptOnExit.parameters.uniqueID) { w.mcxLog('uniqueID: ' + w.McxSiteInterceptOnExit.parameters.uniqueID); }
w.McxSiteInterceptOnExit.surveyURLParams = sessionStorage["mcx.surveyURLParams"];
if (!w.McxSiteInterceptOnExit.surveyURLParams) { sessionStorage["mcx.surveyURLParams"] = '[{}]'; }
var rand = Math.floor(Math.random() * 100);
if(w.McxSiteInterceptOnExit.parameters.probability < 1 && w.McxSiteInterceptOnExit.parameters.probability > 0) {
var decimal = w.McxSiteInterceptOnExit.parameters.probability;
w.McxSiteInterceptOnExit.parameters.probability = Math.floor(w.McxSiteInterceptOnExit.parameters.probability * 100);
w.mcxWarn('mcxSiteIntercept warning: The script detected a probability between 0 and 1. Probability should be a whole number between 0 and 100. The script has converted it to a whole number: ' + decimal + ' -> ' + w.McxSiteInterceptOnExit.parameters.probability);
if(w.McxSiteInterceptOnExit.parameters.probability <= 0) {
w.mcxWarn('mcxSiteIntercept warning: Probability it set to ' + w.McxSiteInterceptOnExit.parameters.probability + '. It must be greater than 0 to have any chance of displaying the survey.');
//Check if random number is less than probability (less than means probability met) and that survey is enabled
if (rand < w.McxSiteInterceptOnExit.parameters.probability && w.McxSiteInterceptOnExit.parameters.enabled && parseInt(w.McxSiteInterceptOnExit.RgetCookie('McxPageVisit')) >= w.McxSiteInterceptOnExit.parameters.pageVisit && w.McxSiteInterceptOnExit.McxBlackList() === false){
//If no cookie exists, and showOnLoad is true, display the survey modal
if (!w.McxSiteInterceptOnExit.hasCookie() && w.McxSiteInterceptOnExit.parameters.showOnLoad) {
if(w.McxSiteInterceptOnExit.parameters.invitationID.length > 0) {
w.McxSiteInterceptOnExit.showModal();
} else {
w.mcxLog('delay ' + w.McxSiteInterceptOnExit.parameters.delay + ' ...');
w.setTimeout(function () {
w.mcxLog('... delay ');
w.McxSiteInterceptOnExit.popUp();
}, w.McxSiteInterceptOnExit.parameters.delay);
} else {
if(!w.McxSiteInterceptOnExit.parameters.enabled) {
w.mcxLog('Survey is disabled');
} else {
w.mcxLog('Probability fail. Chance to succeed: ' + w.McxSiteInterceptOnExit.parameters.probability + '%');
//Page visit count
cookieVisitCount: function(){
if(w.McxSiteInterceptOnExit.RgetCookie('McxPageVisit') == "" ){
document.cookie="McxPageVisit= 1; path=/; domain="+(w.McxSiteInterceptOnExit.parameters.domainPath)+";";
} else {
var pageVisit = parseInt(w.McxSiteInterceptOnExit.RgetCookie('McxPageVisit'));
document.cookie="McxPageVisit=" +(pageVisit + 1)+ "; path=/; domain="+(w.McxSiteInterceptOnExit.parameters.domainPath)+";";
RgetCookie: function(cname) {
var name = cname + "=";
var ca = document.cookie.split(';');
for(var i=0; i<ca.length; i++) {
var c = ca[i];
while (c.charAt(0)==' ') c = c.substring(1);
if (c.indexOf(name) == 0) return c.substring(name.length,c.length);
return "";
McxBlackList: function(){
var checkArray = w.McxSiteInterceptOnExit.parameters.mcxBlackList;
var aL = checkArray.length;
var curUrl = window.location.href;
for (var i = 0; i < aL; i++){
var testEx = RegExp(checkArray[i]);
var finalCheck = testEx.test(curUrl);
if (finalCheck){ return true; }
return false;
//Function to add a parameter to URL
addUrlParameter: function (value, name) {
w.mcxLog('Added URL parameter: [' + value + ', ' + name + ']');
var object = JSON.parse(w.McxSiteInterceptOnExit.surveyURLParams);
object[0][value] = name;
sessionStorage["mcx.surveyURLParams"] = JSON.stringify(object);
//Function to remove a parameter from URL
removeUrlParameter: function (value) {
w.mcxLog('Removed URL parameter: [' + value + ']');
delete object[0][value];
//Converts the URL parameters to a query string that will get appended to the survey URL
urlParametersToQueryString: function() {
w.mcxLog('urlParametersToQueryString ...');
if(w.McxSiteInterceptOnExit.surveyURLParams) {
var parameters = JSON.parse(w.McxSiteInterceptOnExit.surveyURLParams)[0];
var queryString = [];
for(var property in parameters) {
if(parameters.hasOwnProperty(property)) {
queryString.push(property + "=" + parameters[property]);
w.mcxLog('... urlParametersToQueryString ');
return "&" + queryString.join('&');
} else { return ""; }
//Creates a cookie with the given parameters
createCookie: function (name, value, days) {
w.mcxLog('createCookie: [' + name + ', ' + value + ', ' + days + ']');
var date = new Date();
date.setTime(date.getTime() + (days * 24 * 60 * 60 * 1000));
w.docCookies.setItem(name, value, date);
hasCookie: function() {
var hasCookie = w.docCookies.hasItem('mcxSurveyQuarantine' + w.McxSiteInterceptOnExit.parameters.cookieID, w.McxSiteInterceptOnExit.parameters.cleanseCookie);
w.mcxLog('hasCookie: ' + 'mcxSurveyQuarantine' + w.McxSiteInterceptOnExit.parameters.cookieID + ': ' + hasCookie);
return hasCookie;
//Called when page is closed or domain is changed.
onPageClose: function () {
w.mcxLog('onPageClose');
if(w.McxSiteInterceptOnExit.parameters.enabled) {
//w.McxSiteInterceptOnExit.addUrlParameter("mcxReferrerURL", encodeURIComponent(w.location.href));
if (w.McxSiteInterceptOnExit.takeSurvey && w.McxSiteInterceptOnExit.surveyWindow && w.McxSiteInterceptOnExit.surveyWindow.opener && !w.McxSiteInterceptOnExit.surveyWindow.opener.closed) {
w.McxSiteInterceptOnExit.surveyWindow.location = (w.McxSiteInterceptOnExit.parameters.surveyURL + w.McxSiteInterceptOnExit.urlParametersToQueryString());
} else { return; }
//Brings up the survey
popUp: function () {
w.mcxLog('popUp');
if (!w.McxSiteInterceptOnExit.hasCookie() && w.McxSiteInterceptOnExit.parameters.enabled && rand < w.McxSiteInterceptOnExit.parameters.probability) {
var strWindowFeatures = "menubar=0,location=yes,resizable=yes,scrollbars=yes,toolbar=0,status=yes,modal=yes,width=" + w.McxSiteInterceptOnExit.parameters.width + ",height=" + w.McxSiteInterceptOnExit.parameters.height;
w.McxSiteInterceptOnExit.takeSurvey = true;
w.McxSiteInterceptOnExit.createCookie(
('mcxSurveyQuarantine' + w.McxSiteInterceptOnExit.parameters.cookieID),
w.McxSiteInterceptOnExit.parameters.expireDaysIfYes);
var inv = document.getElementById(w.McxSiteInterceptOnExit.parameters.invitationID);
if(inv) { inv.style.display = 'none'; }
if(w.McxSiteInterceptOnExit.parameters.waitUntilClose) {
//Opens window and shows placeholderURL
w.McxSiteInterceptOnExit.surveyWindow = w.open(w.McxSiteInterceptOnExit.parameters.placeholderURL, "_blank", strWindowFeatures);
//w.McxSiteInterceptOnExit.surveyWindow.blur();
//window.global.focus();
} else {
//Logic for showing survey on the page rather than a separate window
if(w.McxSiteInterceptOnExit.parameters.showInline) {
var elem = document.getElementById(w.McxSiteInterceptOnExit.parameters.inlineID);
//Make sure elem exists on page, otherwise create a DIV with inlineID
if(!elem) {
elem = document.createElement('div');
elem.setAttribute("id", w.McxSiteInterceptOnExit.parameters.inlineID);
document.body.appendChild(elem);
//Preserve existing HTML
if(typeof w.McxSiteInterceptOnExit.cachedHTML === 'undefined') { w.McxSiteInterceptOnExit.cachedHTML = elem.innerHTML; }
//Inject additional required HTML and survey
elem.innerHTML = w.McxSiteInterceptOnExit.cachedHTML +
'<div id="' + w.McxSiteInterceptOnExit.parameters.inlineWrapperID + '">' +
'<div id="' + w.McxSiteInterceptOnExit.parameters.inlineCloseID + '"></div>' +
'<iframe frameborder="0" src="' + (w.McxSiteInterceptOnExit.parameters.surveyURL + w.McxSiteInterceptOnExit.urlParametersToQueryString()) +
'" width="' + w.McxSiteInterceptOnExit.parameters.width + '" height="' +
w.McxSiteInterceptOnExit.parameters.height + '"></iframe></div>';
elem.style.display = 'block';
//Event listener for closing the dialog
var el = document.getElementById(w.McxSiteInterceptOnExit.parameters.inlineCloseID);
if (el.addEventListener) { el.addEventListener("click", w.McxSiteInterceptOnExit.closeSurveyModal, false); }
else { el.attachEvent("onclick", w.McxSiteInterceptOnExit.closeSurveyModal); }
} else {
//Shows survey right away (if both waitUntilClose and showInline are false)
w.McxSiteInterceptOnExit.surveyWindow = w.open((w.McxSiteInterceptOnExit.parameters.surveyURL + w.McxSiteInterceptOnExit.urlParametersToQueryString()), "_blank", strWindowFeatures);
w.focus();
//Hides modal
closeSurveyModal: function() {
w.mcxLog('closeSurveyModal');
document.getElementById(w.McxSiteInterceptOnExit.parameters.inlineID).style.display = 'none';
//Accepts the invitation.
acceptSurvey:function() {
w.mcxLog('acceptSurvey');
w.McxSiteInterceptOnExit.addUrlParameter('ref_url', curUrl);
//Creates a quarantine cookie and hides the invitation.
declineSurvey: function () {
w.mcxLog('declineSurvey');
w.McxSiteInterceptOnExit.parameters.expireDaysIfNo);
document.getElementById(w.McxSiteInterceptOnExit.parameters.invitationID).style.display = 'none';
//Shows the invitation
showModal: function (delay) {
w.mcxLog('showModal ...');
if(!delay) { delay = w.McxSiteInterceptOnExit.parameters.delay; }
w.mcxLog('... showModal');
var invitation = document.getElementById(w.McxSiteInterceptOnExit.parameters.invitationID);
if(invitation) { invitation.style.display = 'block'; }
}, delay);
addOnLoadEvent: function (func) {
var oldonload = w.onload;
if (typeof w.onload != 'function') {
w.onload = func;
} else {
w.onload = function () {
if (oldonload) { oldonload(); }
func();
addBeforeUnLoadEvent: function (func) {
var oldonload = w.onbeforeunload;
if (typeof w.onbeforeunload != 'function') {
w.onbeforeunload = func;
} else {
w.onbeforeunload = function () {
func();
addOnUnLoadEvent: function (func) {
var oldonload = w.onunload;
if (typeof w.onunload != 'function') {
w.onunload = func;
} else {
w.onunload = function () {
func();
w.docCookies = {
getBrowser: function () {
// Opera 8.0+
var isOpera = (!!window.opr && !!opr.addons) || !!window.opera || navigator.userAgent.indexOf(' OPR/') >= 0;
// Firefox 1.0+
var isFirefox = typeof InstallTrigger !== 'undefined';
// Safari 3.0+ "[object HTMLElementConstructor]"
var isSafari = /constructor/i.test(window.HTMLElement) || (function (p) { return p.toString() === "[object SafariRemoteNotification]"; })(!window['safari'] || (typeof safari !== 'undefined' && safari.pushNotification));
// Internet Explorer 6-11
var isIE = /*@cc_on!@*/false || !!document.documentMode;
// Edge 20+
var isEdge = !isIE && !!window.StyleMedia;
// Chrome 1+
var isChrome = !!window.chrome && !!window.chrome.webstore;
return {
isOpera: isOpera,
isFirefox: isFirefox,
isSafari: isSafari,
isIE: isIE,
isEdge: isEdge,
isChrome: isChrome
getItem: function (sKey) {
if (!sKey) { return null; }
return decodeURIComponent(document.cookie.replace(new RegExp("(?:(?:^|.*;)\\s*" + encodeURIComponent(sKey).replace(/[\-\.\+\*]/g, "\\$&") + "\\s*\\=\\s*([^;]*).*$)|^.*$"), "$1")) || null;
setItem: function (sKey, sValue, vEnd, sPath, sDomain, bSecure) {
if (!sKey || /^(?:expires|max\-age|path|domain|secure)$/i.test(sKey)) { return false; }
var sExpires = "";
if (vEnd) {
switch (vEnd.constructor) {
case Number:
sExpires = vEnd === Infinity ? "; expires=Fri, 31 Dec 9999 23:59:59 GMT" : "; max-age=" + vEnd;
break;
case String:
sExpires = "; expires=" + vEnd;
break;
case Date:
sExpires = "; expires=" + vEnd.toUTCString();
break;
var browser = this.getBrowser();
if (browser.isIE || browser.isEdge || !McxSiteInterceptOnExit.parameters.domainPath) {
w.mcxLog('Building cookie without domain. IE: ' + browser.isIE + '; Edge: ' + browser.isEdge + '; domainPath: not used(IE)', true);
document.cookie = encodeURIComponent(sKey) + "=" + encodeURIComponent(sValue) + sExpires + "; path=/";
} else {
w.mcxLog('Building cookie with domain. domainPath: ' + McxSiteInterceptOnExit.parameters.domainPath, true);
document.cookie = encodeURIComponent(sKey) + "=" + encodeURIComponent(sValue) + sExpires + "; domain=" + McxSiteInterceptOnExit.parameters.domainPath + "; path=/";
return true;
removeItem: function (sKey) {
if (!this.hasItem(sKey)) { return false; }
document.cookie = encodeURIComponent(sKey) + "=; expires=Thu, 01 Jan 1970 00:00:00 GMT; domain=" + McxSiteInterceptOnExit.parameters.domainPath + "; path=/";
return true;
hasItem: function (sKey, cleanseCookie) {
if (!sKey) { return false; }
if (cleanseCookie === true) {
this.removeItem(sKey);
return (new RegExp("(?:^|;\\s*)" + encodeURIComponent(sKey).replace(/[\-\.\+\*]/g, "\\$&") + "\\s*\\=")).test(document.cookie);
keys: function () {
var aKeys = document.cookie.replace(/((?:^|\s*;)[^\=]+)(?=;|$)|^\s*|\s*(?:\=[^;]*)?(?:\1|$)/g, "").split(/\s*(?:\=[^;]*)?;\s*/);
for (var nLen = aKeys.length, nIdx = 0; nIdx < nLen; nIdx++) { aKeys[nIdx] = decodeURIComponent(aKeys[nIdx]); }
return aKeys;
w.mcxWarn = function(warning, ignorePrefix) {
var consoleWarn = typeof console !== "undefined" && console.warn && w.McxSiteInterceptOnExit.parameters.ignoreWarning === false;
if(consoleWarn) {
var prefix = ignorePrefix ? '' : 'mcxSiteIntercept: ';
console.warn(prefix + warning);
w.mcxLog = function(log, ignorePrefix) {
var consoleLog = typeof console !== "undefined" && console.log && w.McxSiteInterceptOnExit.parameters.debug === true;
if(consoleLog) {
console.log(prefix + log);
w.AllegianceSiteInterceptOnExit = w.McxSiteInterceptOnExit; //Backward compatibility (for customers who have <v1.3)
w.McxSiteInterceptOnExit.addOnUnLoadEvent(w.McxSiteInterceptOnExit.onPageClose); //ensures that other events are retained
w.McxSiteInterceptOnExit.addBeforeUnLoadEvent(w.McxSiteInterceptOnExit.onPageClose); //ensures that other events are retained
w.McxSiteInterceptOnExit.addOnLoadEvent(w.McxSiteInterceptOnExit.onPageLoad); //ensures that other events are retained
w.mcxLog("script loaded");
}(this));
var Allegiance = (function() {
var showSurvey = function(surveyId, cimId, pimId, modelDesc, transID) {
var url = "https://canonusa.esaas.inmoment.com/cgi-bin/qwebcorporate.dll?";
var idx = surveyId;
var cim = cimId;
var pim = pimId;
var model = modelDesc;
var surveyTimeStamp = "";
var finalSurveyUrl = url+"&idx="+idx+"&CIM="+cim+"&PIM="+pim+"&Model="+model+"&TransID="+transID+"&t="+surveyTimeStamp;
$('#allegiance-iframe').attr('src', finalSurveyUrl);
return {
showSurvey : showSurvey
$(document).ready(function() {
// Need to show ConfirmIt only on support pages
if (window.location.href.indexOf("/support/p") > -1) {
var model = '';
var category = '';
if (useMaritzCXSurvey == "N") {
ConfirmIt.openSurvey(encodeURIComponent(model),encodeURIComponent(category));
} else {
McxSiteInterceptOnExit.addUrlParameter("mcxModel", model);
McxSiteInterceptOnExit.addUrlParameter("mcxPCategory", category);
//Survey ID
McxSiteInterceptOnExit.addUrlParameter("mcxID", "M6BSBQ");
McxSiteInterceptOnExit.addUrlParameter("mcxReferrerURL",encodeURIComponent(window.location.href));
McxSiteInterceptOnExit.acceptSurvey();
//$('#surveyModal').modal('show');
