Canon Support for varioPRINT iX-series | Canon U.S.A., Inc.
TECHNOLOGY
PRINT TECHNOLOGY Inkjet, Drop-on-demand, piezoelectric
INKProprietary polymer pigment water-based iX inks
DROP SIZE Variable, MultiLevel
PRINT SPEED varioPRINT iX3200: 312 letter duplex images per minute 4740 11 x 17 sheets 4/4 per hour 4500 12 x 18 sheets 4/4 per hour
varioPRINT iX2100: 205 letter duplex images per minute
DUTY CYCLEvarioPRINT iX3200: 1,000,000 – 10,000,000 letter impressions/month
varioPRINT iX2100: 1,000,000 – 7,000,000 letter impressions/month
PRINT RESOLUTION 1200 × 1200 dpi
PAPER
PAPER WEIGHTUncoated: 60 - 350 gsm
Coated: 90 - 350 gsm
SUBSTRATES Commodity coated and uncoated papers including specialties
STANDARD CONFIGURATION2 Paper Input Module (PIM Flex XL) 1 High Capacity Stacker
PAPER SIZES PIM Flex XL: All sizes between 8” x 8” and 13.78 x 20” supported
MAXIMUM PRINTABLE AREA 13.3 X 19.8
PAPER CAPACITY 3 PIMS x 4,600 sheets per PIM (13,800) 20 lb. bond
PAPER INPUT MODULE FLEX XL
PAPER TRAYS 2 × 600 sheets, 2 × 1,650 sheets (80 gsm)
STANDARD PAPER CAPACITY 4,500 sheets
PAPER SIZEPaper trays 1 and 2: 600 sheets 20 lb. bond 8 x 8 to 13.78 x 20
Paper trays 3 and 4: 1,700 sheets 20 lb. bond 8 x 8 to 13.78 x 20
DIMENSIONS (WxDxH) 37.2 x 34.8 x 44.4
WEIGHT 441 lbs
HIGH CAPACITY STACKER
STACKS 2 × 3,000 sheets (80 gsm) per stacker
DIMENSIONS (WxDxH) 36 x 30 x 43.2
WEIGHT 353 lbs
INTEGRATED CAMERA MOUNTING UNIT (OPTIONAL)
  Inline camera inspection
DIMENSIONS (WxDxH) 3.2 x 1.2 x 4.6
WEIGHT 448 lbs
PRISMASYNC CONTROLLER
NETWORK CONNECTIVITY
Internal: 1 x 10 Gbit Ethernet; External: 2 x 1 Gbit (10/100/1000 Base-T), TCP/IP (LPR /LPD, 9100 Socket), Static IP / Auto-IP (DHCP), IPv4, IPv6 (only in Document printing mode)
PAGE DESCRIPTION LANGUAGES PDF 1.7 (Extension Level 3), APPE DP mode is 5.4, APPE for TP mode is 4.9, PDF/VT (Level 1), Postscript, PPML 2.2, IPDS IS/3, SRA PCL6
JOB SUBMISSION
lpr, Hotfolders via WebDAV, Socket (streaming), JDF/JMF, IPP 2.0, Remote PDF Driver
PROTOCOLS SNMP v1, SNMP v3, Host Resources MIB, MIB II, Printer MIB, Job Monitoring MIB, Job Management MIB (partially), IEEE 802.1x
SPOT COLOR LIBRARIES PANTONE+ Solid (Coated & Uncoated), PANTONE GOE (Coated & Uncoated), HKS (K,N), HKS (K,N) 3000+ PANTONE+ Solid 336 New (Coated & Uncoated)
CONNECTION REQUIREMENTS
CONNECTION FUSE230/400 VAC, 100A; 100-240 VAC, 13-20A; 100-240 VAC, 13-20A; 200-240 VAC, 13-20A; 100-240 VAC, 13-20A
POWER CONSUMPTION PRINTING 14.9 kW
POWER CONSUMPTION IDLE 7.1 kW
POWER CONSUMPTION SLEEP 0.9 kW
COMPRESSED AIR 5-12 bar, dry and oil free
WATER Reverse osmosis water system
ENVIRONMENTAL
TEMPERATUREOptimal range 20–26 °C
HUMIDITY Optimal range 30–50%
OPERATING NOISEPrinting 72 dB, Standby 61 dB
PHYSICAL DATA
LENGTH x WIDTH x HEIGHT33 x 9.2 x 7.3
WEIGHT Approximately 15,900 lbs. (main engine, 2 PIMs, 1 HCS)
OPTIONS
PAPER TRAYSDuo Paper Trays
HIGH CAPACITY STACKER Second High Capacity Stacker
INLINE FINISHING DFD interface SFD interface
PRISMAsync DPlink DocBox*
PRISMAlytics Dashboard*
PRISMAsync Simulator
PRISMAprofiler
* Included in Base Configuration
INTEGRATED CAMERA MOUNTUNG UNIT
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
