Canon Support for varioPRINT iX3200 | Canon U.S.A., Inc.
varioPRINT iX3200
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
TECHNOLOGY
Print technology Inkjet, Drop-on-demand, piezoelectric
Ink Proprietary polymer pigment water-based iX inks
Drop size Variable, MultiLevel
Print speed varioPRINT iX3200:
312 letter duplex images per minute
9,360 8.5 x 11 sheets 4/4 per hour
4,170 14 x 20 sheets 4/4 per hour
Duty cycle varioPRINT iX3200: 1,000,000 10,000,000 letter
impressions/month
Print resolution 1200 × 1200 dpi
PAPER
Paper weight Uncoated: 60 - 350 gsm
Coated: 90 - 350 gsm
Substrates Commodity coated and uncoated papers including specialties
Standard configuration 2 Paper Input Module (PIM Flex XL)
1 High Capacity Stacker
Paper sizes PIM Flex XL: All sizes between 8 x 8 and 14 x 20 supported
Maximum printable area 13.3 x 19.8
Paper capacity 3 PIMS x 4,600 sheets per PIM (13,800) 20 lb. bond
PAPER INPUT MODULE FLEX XL
Paper trays 2 × 600 sheets, 2 × 1,650 sheets (80 gsm)
Standard paper capacity 4,500 sheets
Paper size Paper trays 1 and 2: 600 sheets 20 lb. bond 8 x 8 to 14 x 20
Paper trays 3 and 4: 1,700 sheets 20 lb. bond 8 x 8 to 14 x 20
Dimensions (W×D×H) 37.2 x 34.8 x 44.4
Weight 441 lbs
HIGH CAPACITY STACKER
Stacks 2 × 3,000 sheets (80 gsm) per stacker
Dimensions (W×D×H) 36 x 30 x 43.2
Weight 353 lbs
INTEGRATED CAMERA MOUNTING UNIT (OPTIONAL)
Inline camera inspection
Dimensions (W×D×H) 3.2 x 1.2 x 4.6
Weight 448 lbs
PRISMASYNC CONTROLLER
Network connectivity Internal: 1 x 10 Gbit Ethernet; External: 2 x 1 Gbit (10/100/1000 Base-T), TCP/IP (LPR /LPD, 9100 Socket), Static IP / Auto-IP (DHCP), IPv4, IPv6 (only in Document printing mode)
Page Description Languages PDF 1.7 (Extension Level 3), APPE DP mode is 5.4, APPE for TP mode is 4.9, PDF/VT (Level 1), Postscript, PPML 2.2, IPDS IS/3, SRA PCL6
Job submission lpr, Hotfolders via WebDAV, Socket (streaming), JDF/JMF, IPP 2.0, Remote PDF Driver
Protocols SNMP v1, SNMP v3, Host Resources MIB, MIB II, Printer MIB, Job Monitoring MIB, Job Management MIB (partially), IEEE 802.1x
Spot Color Libraries PANTONE+ Solid (Coated & Uncoated), PANTONE GOE (Coated & Uncoated), HKS (K,N), HKS (K,N) 3000+
PANTONE+ Solid 336 New (Coated & Uncoated)
CONNECTION REQUIREMENTS
Connection fuse 230/400 VAC, 100A; 100-240 VAC, 13-20A; 100-240 VAC, 13-20A; 200-240 VAC, 13-20A; 100-240 VAC, 13-20A
Power consumption printing 14.9 kW
Power consumption idle 7.1 kW
Power consumption sleep 0.9 kW
Compressed air 5-12 bar, dry and oil free
Water Reverse osmosis water system
ENVIRONMENTAL
Temperature Required range 2026 °C, 68-78.80 Fahrenheit
Humidity Required range 4060%
Operating noise Printing 72 dB, Standby 61 dB
PHYSICAL DATA[1]
Length × Width × Height 33 x 9.2 x 7.3
Weight Approximately 15,900 lbs. (main engine, 2 PIMs, 1 HCS)
OPTIONS
Paper trays Duo Paper Trays
High Capacity Stacker Second High Capacity Stacker
Integrated camera mounting unit
Inline finishing DFD interface
SFD interface
PRISMAsync DPlink
DocBox*
PRISMAlytics Dashboard*
PRISMAsync Simulator
PRISMAprofiler
* Included in Base Configuration
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
