Canon Support for varioPRINT iX2100 | Canon U.S.A., Inc.
varioPRINT iX2100
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| TECHNOLOGY | |
| Print technology | Inkjet, Drop-on-demand, piezoelectric |
| Ink | Proprietary polymer pigment water-based iX inks |
| Drop size | Variable, MultiLevel |
| Print speed | varioPRINT iX3200: 312 letter duplex images per minute 9,360 8.5 x 11 sheets 4/4 per hour 4,170 14 x 20 sheets 4/4 per hour |
| Duty cycle | varioPRINT iX3200: 1,000,000 10,000,000 letter impressions/month |
| Print resolution | 1200 × 1200 dpi |
| PAPER | |
| Paper weight | Uncoated: 60 - 350 gsm Coated: 90 - 350 gsm |
| Substrates | Commodity coated and uncoated papers including specialties |
| Standard configuration | 2 Paper Input Module (PIM Flex XL) 1 High Capacity Stacker |
| Paper sizes | PIM Flex XL: All sizes between 8 x 8 and 14 x 20 supported |
| Maximum printable area | 13.3 x 19.8 |
| Paper capacity | 3 PIMS x 4,600 sheets per PIM (13,800) 20 lb. bond |
| PAPER INPUT MODULE FLEX XL | |
| Paper trays | 2 × 600 sheets, 2 × 1,650 sheets (80 gsm) |
| Standard paper capacity | 4,500 sheets |
| Paper size | Paper trays 1 and 2: 600 sheets 20 lb. bond 8 x 8 to 14 x 20 Paper trays 3 and 4: 1,700 sheets 20 lb. bond 8 x 8 to 14 x 20 |
| Dimensions (W×D×H) | 37.2 x 34.8 x 44.4 |
| Weight | 441 lbs |
| HIGH CAPACITY STACKER | |
| Stacks | 2 × 3,000 sheets (80 gsm) per stacker |
| Dimensions (W×D×H) | 36 x 30 x 43.2 |
| Weight | 353 lbs |
| INTEGRATED CAMERA MOUNTING UNIT (OPTIONAL) | |
| Inline camera inspection | |
| Dimensions (W×D×H) | 3.2 x 1.2 x 4.6 |
| Weight | 448 lbs |
| PRISMASYNC CONTROLLER | |
| Network connectivity | Internal: 1 x 10 Gbit Ethernet; External: 2 x 1 Gbit (10/100/1000 Base-T), TCP/IP (LPR /LPD, 9100 Socket), Static IP / Auto-IP (DHCP), IPv4, IPv6 (only in Document printing mode) |
| Page Description Languages | PDF 1.7 (Extension Level 3), APPE DP mode is 5.4, APPE for TP mode is 4.9, PDF/VT (Level 1), Postscript, PPML 2.2, IPDS IS/3, SRA PCL6 |
| Job submission | lpr, Hotfolders via WebDAV, Socket (streaming), JDF/JMF, IPP 2.0, Remote PDF Driver |
| Protocols | SNMP v1, SNMP v3, Host Resources MIB, MIB II, Printer MIB, Job Monitoring MIB, Job Management MIB (partially), IEEE 802.1x |
| Spot Color Libraries | PANTONE+ Solid (Coated & Uncoated), PANTONE GOE (Coated & Uncoated), HKS (K,N), HKS (K,N) 3000+ PANTONE+ Solid 336 New (Coated & Uncoated) |
| CONNECTION REQUIREMENTS | |
| Connection fuse | 230/400 VAC, 100A; 100-240 VAC, 13-20A; 100-240 VAC, 13-20A; 200-240 VAC, 13-20A; 100-240 VAC, 13-20A |
| Power consumption printing | 14.9 kW |
| Power consumption idle | 7.1 kW |
| Power consumption sleep | 0.9 kW |
| Compressed air | 5-12 bar, dry and oil free |
| Water | Reverse osmosis water system |
| ENVIRONMENTAL | |
| Temperature | Required range 2026 °C, 68-78.80 Fahrenheit |
| Humidity | Required range 4060% |
| Operating noise | Printing 72 dB, Standby 61 dB |
| PHYSICAL DATA[1] | |
| Length × Width × Height | 33 x 9.2 x 7.3 |
| Weight | Approximately 15,900 lbs. (main engine, 2 PIMs, 1 HCS) |
| OPTIONS | |
| Paper trays | Duo Paper Trays |
| High Capacity Stacker | Second High Capacity Stacker |
| Integrated camera mounting unit | |
| Inline finishing | DFD interface SFD interface |
| PRISMAsync | DPlink DocBox* PRISMAlytics Dashboard* PRISMAsync Simulator PRISMAprofiler * Included in Base Configuration |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
