Canon Support for VB-H41 | Canon U.S.A., Inc.
VB-H41
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Camera Management Tool User Manual
File Name
File Name
File Name
Data Size and Bit Rate Estimates
SELECT ERROR CODE
| IMAGE SENSOR | 1/3 type CMOS (primary color filter) |
| NUMBER OF EFFECTIVE PIXELS | Approx. 2.1 million pixels |
| ANALOG VIDEO RESOLUTION | N/A |
| ANALOG VIDEO STANDARD | N/A |
| ANALOG S/N RATIO | N/A |
| SCANNING METHOD | Progressive |
| LENS | 20x optical (12x digital) zoom lens with auto focus |
| FOCAL LENGTH | 4.7 (W) - 94mm (T) |
| F-NUMBER | F1.6 (W) - F3.5 (T) |
| HORIZONTAL VIEWING ANGLE1 | 60.4° (W) - 3.2° (T) |
| VERTICAL VIEWING ANGLE | 35.1° (W) - 1.8° (T) |
| DAY/NIGHT SWITCH | Auto/Manual |
| I/R CUT FILTER | Removable |
| MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.4 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE) 0.03 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE) 0.01 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE) |
| MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0.02 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE) 0.002 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE) 0.001 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE) |
| FOCUS MODES | Auto/One-shot AF/Manual/Fixed at infinity |
| SHOOTING DISTANCE | Day Mode: 0.3m (12 in.) - infinity (W), 1.0m (3.3 ft.) - infinity (T) Night Mode: 1.0m (3.3 ft.) - infinity (W), 1.5m (4.9 ft.) - infinity (T) |
| SHUTTER SPEED | 1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000, 1/4000, 1/8000, 1/16000 sec. |
| EXPOSURE | Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/ Manual (Shutter Speed, Aperture, Gain) |
| WHITE BALANCE | Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/Lock (One-shot WB)/Manual |
| METERING MODE | Center-Weighted/Average/Spot |
| EXPOSURE COMPENSATION | 9 levels |
| SMART SHADE CONTROL | 7 Levels |
| AGC LIMIT | 2 levels |
| IMAGE STABILIZER | 2 levels (digital) |
| PAN ANGLE RANGE | 340° (±170°) |
| TILT ANGLE RANGE | 100° (ceiling-mounted position: -90° - +10°) |
| ROTATION ANGLE RANGE | N/A |
| MOVING SPEED | Pan: Max. 150°/sec., Tilt: Max. 150°/sec. |
| VIDEO COMPRESSION METHOD | JPEG, H.264 |
| VIDEO SIZE | JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270, 320 x 240 H.264: 1920 x 1080, 960 x 540, 480 x 270 |
| VIDEO QUALITY | JPEG, H.264: 5 levels |
| FRAME RATE | JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps |
| MAXIMUM FRAME RATE | 1920 x 1080: 30 fps |
| I-FRAME INTERVAL | 0.5/1/1.5/2/3/4/5 sec. |
| SIMULTANIOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients |
| CAMERA CONTROL | Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users. |
| ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4, IPv6) |
| ENCRYPTED COMMUNICATIONS | SSL/TLS, IPsec (Auto Key Exchange/Manual) |
| IEEE 802.1X | N/A |
| ONVIF Version | ONVIF Ver. 2.2 / Profile S |
| IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), ARP, ICMP, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon proprietary), ONVIF |
| IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client),ICMPv6, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon Proprietary), ONVIF |
| AUTO IP | Yes |
| AUDIO COMPRESSION METHOD | G.711 µ-law (64 kbps) |
| AUDIO COMMUNICATION METHOD | Full-duplex (two-way) - Echo cancellation function compliant |
| AUDIO FILE PLAYBACK | Available (audio files can be played back when an event is triggered by the intelligent function or external device input.) |
| PRIVACY MASK | Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors) |
| VIEW RESTRICTION | Availables |
| PRESETS | Max. 20 positions |
| INTELLIGENT FUNCTION - VIDEO | Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection |
| INTELLIGENT FUNCTION - AUDIO | Moving object detection, abandoned object detection, removed object detection, camera tampering detection, and passing detection |
| INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
| INTELLIGENT FUNCTION - VOLUME | Volume Detection |
| EVENT TRIGGER TYPE | External Device Input, Intelligent Function (Video),Intelligent Function (Volume), Timer |
| IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail) Temporary storage memory in camera: Max. approx. 5 MB Frame Rate: Max. 10 fps |
| EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
| ON-SCREEN DISPLAY | Available |
| IMAGE CROPPING FUNCTION | N/A |
| DAYLIGHT SAVING TIME | Available |
| CUSTOM SETTINGS | N/A |
| NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
| AUDIO INPUT TERMINAL | f3.5mm (f0.14 in.) mini-jack connector (monaural) Switch LINE IN/MIC IN in the setting page. LINE IN x 1 (connect to an amplifier microphone) or MIC IN x 1 (connect to a microphone w/o amplifier) |
| AUDIO OUTPUT TERMINAL | f3.5mm (f0.14 in.) mini-jack connector (monaural) LINE OUT x 1 (connect to an amplifier speaker) |
| EXTERNAL DEVICE I/O TERMINAL | Input x 2, Output x 2 |
| ANALOG VIDEO OUT | N/A |
| MEMORY CARD | SD Memory Card, SDHC Memory Card, SDXC Memory Card Compatible. Frame Rate: Max. 1 fps |
| TEMPERATURE | Temperature: -10°C - +50°C (+14°F - +122°F) |
| HUMIDITY | Humidity: 5% - 85% (without condensation) |
| PoE | PoE power supply via LAN connector (IEEE802.3af compliant) |
| AC ADAPTER | PA-V17 or PA-V18(100 - 240 V AC) (sold separately) |
| EXTERNAL POWER SOURCE | 24 V AC/12 V DC |
| WITH PoE | Max. approx. 9.2 W |
| WITH AC ADAPTER | Max. approx. 10.7 W |
| WITH 12VDC | Max. approx. 8.6 W |
| WITH 24VAC+ | Max. approx. 8.8 W |
| DIMENSIONS | (f x H) f132 x 155mm (f5.20 x 6.10 in.) |
| MOUNTING POSITION | Horizontal |
| HEATER | N/A |
| WEIGHT | Approx. 1140 g (2.514 lb.) |
| OUTDOOR READY | No |
| IP RATING | N/A |
| VANDAL RESISTANT | No |
| IMPACT RESISTANCE | N/A |
ADDITIONAL SUPPORT
CONTACT US
next to your download
