Canon Support for VB-H47 | Canon U.S.A., Inc.
VB-H47
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Mobile Camera Viewer Operation Guide
File Name
Recorded Video Utility User Manual
File Name
Camera Management Tool User Manual
File Name
Before Using This Camera
SELECT ERROR CODE
| IMAGE SENSOR | 1/2.8 type CMOS |
| NUMBER OF EFFECTIVE PIXELS | Approx. 2.0 million pixels |
| SCANNING METHOD | Progressive |
| LENS | 20x optical zoom lens with auto focus |
| FOCAL LENGTH | 4.7 (W) 94 mm (T) |
| F-NUMBER | F1.6 (W) F3.5 (T) |
| DIGITAL ZOOM | 16X |
| HORIZONTAL VIEWING ANGLE (16:9) | Horizontal: 62.4° (W) 3.3° (T) |
| VERTICAL VIEWING ANGLE (16:9) | Vertical: 36.3° (W) 1.9° (T) |
| DAY/NIGHT MODE | Auto/Day Mode/Night Mode |
| I/R CUT FILTER | Automatically removable infrared-cut filter |
| MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.02 lux (F1.6, shutter speed 1/30 sec., 50IRE) |
| MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0.003 lux (F1.6, shutter speed 1/30 sec., 50IRE) |
| FOCUS MODES | Auto/One-shot AF/Manual/Fixed at infinity |
| AF RESPONSE SPEED | High, Normal, and Low |
| SHOOTING DISTANCE | Day Mode: 0.3 m (12 in.) infinity (W), 1.0 m (3.3 ft.) infinity (T) Night Mode: 1.0 m (3.3 ft.) infinity (W), 1.5 m (4.9 ft.) infinity (T) |
| SHUTTER SPEED | 1 - 1/16000 sec. |
| EXPOSURE MODES | Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Auto (Aperture-priority AE)/Manual |
| WHITE BALANCE | Auto/Light Source (Daylight Fluorescent/White Fluorescent/WarmFluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/Manual(One-shot WB/R Gain/B Gain) |
| METERING MODES | Center-Weighted/Average/Spot/Specify Area |
| EXPOSURE COMPENSATION | 13 levels |
| WDR | Available |
| SMART SHADE CONTROL | Available |
| HAZE COMPENSATION | Available |
| AGC LIMIT | Available |
| IMAGE STABILIZER | Digital (2 Levels) |
| MOTION ADAPTIVE NOISE REDUCTION | Available |
| CLEAR IR | n/a |
| PAN ANGLE RANGE | 340° (±170°) |
| TILT ANGLE RANGE | 100° (ceiling-mounted position: -90° - +10°) |
| ROTATION ANGLE RANGE | N/A |
| IR ILLUMINATION RANGE | N/A |
| MOVING SPEED | Pan: Max. 150°/sec., Tilt: Max. 150°/sec. |
| VIDEO COMPRESSION METHOD | JPEG, H.264, H.265 |
| BIT RATE CONTROL | CBR (Constant Bit Rate), VBR (Variable Bit Rate), MBR (Maximum Bit Rate) |
| VIDEO SIZE | JPEG, H.264, H.265: 1920 x 1080, 1280 x 720, 960 x 540, 640 x 360, 480 x 270, 320 x 180 1280 x 960, 640 x 480, 320 x 240 |
| VIDEO QUALITY | JPEG, H.264, H.265: 10 levels |
| FRAME RATE | System frequency 60 Hz: 1, 5, 7.5, 10, 15, 30, 60 fps System frequency 50 Hz: 1, 2.5, 5, 6.25, 10, 12.5, 25, 50 fps |
| MAXIMUM FRAME RATE | 60 fps |
| I-FRAME INTERVAL | Available |
| SIMULTANIOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client H.264: Max. 10 Clients H.265: Max. 10 Clients |
| CAMERA CONTROL | Administrator, Authorized user, Guest user |
| ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4, IPv6) |
| ENCRYPTED COMMUNICATIONS | SSL/TLS |
| IEEE 802.1X | EAP-TLS, EAP-TTLS, EAP-PEAP |
| ONVIF Version | Profile-S, Profile-G, Profile-T |
| IPv4 PROTOCOL | TCP/IP, UDP, HTTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, ONVIF, WV-HTTP (Canon proprietary) |
| IPv6 PROTOCOL | TCP/IP, UDP, HTTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, ONVIF, WV-HTTP (Canon proprietary) |
| AUTO IP (LINK-LOCAL) | Yes |
| AUDIO COMPRESSION METHOD | G.711 -law (64 kbps), AAC (16/48 KHz, 16/32/64/96/128 Kbps) |
| AUDIO COMMUNICATION METHOD | Full-duplex (two-way)/half-duplex RTP, Sound Transfer Protocol by Canon |
| AUDIO FILE PLAYBACK | Available |
| PRIVACY MASK | Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors) |
| VIEW RESTRICTION | Available |
| PRESETS | Number of registers: Max. 64 positions (+Home Position) Number of Preset Tour Route: Max. 5 |
| INTELLIGENT FUNCTION - VIDEO | Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, Intrusion Detection, Face Detection |
| INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
| INTELLIGENT FUNCTION - VOLUME | Volume Detection |
| EVENT TRIGGER TYPE | External Device Input, Intelligent Function, Timer, Day/Night Mode Switching Number of Linked Events: 2 Linked Event Conditions: OR, AND (whether or not there is a sequence to events) |
| IMAGE UPLOAD | FTP/FTPS/HTTP/HTTPS/SMTP/SMTPS (e-mail) |
| EVENT NOTIFICATION | HTTP/HTTPS/SMTP/SMTPS (e-mail) |
| ON-SCREEN DISPLAY | Available |
| IMAGE CROPPING FUNCTION | Digital PTZ |
| ENHANCED DIGITAL ZOOM | Available |
| DAYLIGHT SAVING TIME | Available |
| CUSTOM SETTINGS | Available |
| NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto)) |
| AUDIO INPUT TERMINAL | 3.5 mm (0.14 in.) mini-jack connector (monaural) LINE IN or MIC IN |
| AUDIO OUTPUT TERMINAL | 3.5 mm (0.14 in.) mini-jack connector (monaural) LINE OUT |
| EXTERNAL DEVICE I/O TERMINAL | Input x 2, Output x 2 |
| ANALOG VIDEO OUT | N/A |
| MEMORY CARD TYPE | SD Memory Card, SDHC Memory Card, SDXC Memory Card Supported. Class 10 recommended. |
| TEMPERATURE | Temperature: -10°C - +50°C (+14°F - +122°F) |
| HUMIDITY | Humidity: 5% - 85% (without condensation) |
| TEMPERATURE | Temperature: -30°C +60°C (-22°F +140°F) |
| HUMIDITY | 5% 90% (without condensation) |
| PoE | PoE power supply via LAN connector (IEEE802.3af compliant) |
| AC ADAPTER | PA-V17 or PA-V18(100 - 240 V AC) (sold separately) |
| EXTERNAL POWER SOURCE | 12 V DC |
| WITH PoE | Max. approx. 9.1 W |
| WITH AC ADAPTER | AC Adapter PA-V18: Max. approx. 9.2 W (100 V AC) Max. approx. 9.7 W (240 V AC) |
| WITH 12VDC | 7.9 W |
| DIMENSIONS | (f x H) f132 x 155mm (f5.20 x 6.10 in.) |
| MOUNTING POSITION | Ceiling |
| HEATER | N/A |
| WEIGHT | 1100 g (2.43 lb.) |
| OUTDOOR READY | No |
| IP RATING | N/A |
| VANDAL RESISTANT | No |
| IMPACT RESISTANCE | N/A |
| Certifications and Compatibility | EN 55032 class A, FCC part15 subpart B class A, ICES-003 class A, VCCI class A, RCM AS/NZS EN55032 class A, CNS13438 class A, EN 55035, IEC EN 63000:2018, CNS15663 IEC/EN 62368-1 3'rd ed., UL 62368-1 3'rd ed. |
ADDITIONAL SUPPORT
CONTACT US
next to your download
