Canon Support for VB-S805D | Canon U.S.A., Inc.
VB-S805D
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Camera Management Tool User Manual
File Name
File Name
File Name
Data Size and Bit Rate Estimates
SELECT ERROR CODE
| IMAGE SENSOR | 1/3 type CMOS (primary color filter) |
| NUMBER OF EFFECTIVE PIXELS | Approx. 1.3 million pixels |
| ANALOG VIDEO RESOLUTION | N/A |
| ANALOG VIDEO STANDARD | N/A |
| ANALOG S/N RATIO | N/A |
| SCANNING METHOD | Progressive |
| LENS | Fixed focal length lens (4x digital zoom) |
| FOCAL LENGTH | 2.7 mm |
| F-NUMBER | F1.6 |
| HORIZONTAL VIEWING ANGLE | 95 ° |
| VERTICAL VIEWING ANGLE | 60 ° |
| DAY/NIGHT SWITCH | Auto/Manual |
| I/R CUT FILTER | Fixed |
| MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.45 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE)
0.03 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE) 0.01 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE) |
| MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0.25 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE)
0.02 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE) 0.007 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE) |
| FOCUS | Fixed at infinity |
| SHOOTING DISTANCE | 0.5m (1.6 ft.) - infinity |
| SHUTTER SPEED | 1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000, 1/4000, 1/8000, 1/10000, 1/16000 sec. |
| EXPOSURE | Auto / Auto (Flickerless)/Auto (Shutter-priority AE)/ Manual (Shutter Speed, Gain) |
| WHITE BALANCE | Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/ Manual (One-shot WB / R Gain/ B Gain) |
| METERING MODE | Center-Weighted/Average/Spot |
| EXPOSURE COMPENSATION | 9 levels |
| SMART SHADE CONTROL | Auto / Manual / Disable
Auto: 3 Levels Manual: 7 Levels |
| AGC LIMIT | 5 levels |
| IMAGE STABILIZER | N/A |
| PAN ANGLE RANGE | 350 ° (±175 ° ) |
| TILT ANGLE RANGE | 90 ° (ceiling-mounted position: -90 ° - 0 ° ) |
| ROTATION ANGLE RANGE | 180 ° (±90 ° ) |
| MOVING SPEED | N/A |
| VIDEO COMPRESSION METHOD | JPEG, H.264 |
| VIDEO SIZE | JPEG, H.264: 1280x720, 640x360, 320x180 1280x960, 640x480, 320x240 |
| VIDEO QUALITY | JPEG, H.264: 5 levels |
| FRAME RATE | JJPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps |
| MAXIMUM FRAME RATE | JPEG, H.264 (1280x960): 30fps |
| I-FRAME INTERVAL | 0.5/1/1.5/2/3/4/5 sec. |
| SIMULTANIOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients |
| CAMERA CONTROL | Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users. |
| ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4,IPv6) |
| ENCRYPTED COMMUNICATIONS | SSL/TLS, IPsec (Auto Key Exchange/Manual) |
| IEEE 802.1X | EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP |
| ONVIF Version | ONVIF Ver. 2.4 / Profile S |
| IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), ARP, ICMP, POP3, NTP, SMTP authentication, RTSP, WV-HTTP(Canon proprietary), ONVIF |
| IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client), ICMPv6, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon Proprietary), ONVIF |
| AUTO IP | Available |
| AUDIO COMPRESSION METHOD | G.711 µ-law (64 kbps) |
| AUDIO COMMUNICATION METHOD | Sound Transfer Protocol by Canon |
| AUDIO FILE PLAYBACK | N/A |
| PRIVACY MASK | Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors) |
| VIEW RESTRICTION | |
| PRESETS | Max. 20 positions |
| INTELLIGENT FUNCTION - VIDEO | Moving object detection, abandoned object detection, removed object detection, camera tampering detection, and passing detection |
| INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
| INTELLIGENT FUNCTION - VOLUME | Volume Detection |
| EVENT TRIGGER TYPE | External Device Input, Timer, Intelligent Function (Video),
Intelligent Function (Volume) |
| IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail)
Temporary storage memory in camera: Max. approx. 5 MB Frame Rate: Max. 10 fps (JPEG) Max. 30 fps (H.264) |
| EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
| ON-SCREEN DISPLAY | Available |
| IMAGE CROPPING FUNCTION | Digital PTZ
Cropping Sizes: 640x360, 512x288, 384x216, 256x144, 128x72 640x480, 512x384, 384x288, 256x192, 128x96 |
| DAYLIGHT SAVING TIME | Available |
| CUSTOM SETTINGS | Number of Registers: 4
Items to Register: Exposure, Smart Shade Control, White Balance, Image Quality Adjustment, Day/Night |
| NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
| AUDIO INPUT TERMINAL | F3.5mm (F0.14 in.) mini-jack connector (monaural) Switch LINE IN/MIC IN in the setting page. LINE IN x 1 (connect to an amplifier microphone) or MIC IN x 1 (connect to a microphone w/o amplifier) |
| AUDIO OUTPUT TERMINAL | N/A |
| EXTERNAL DEVICE I/O TERMINAL | Input x 1, Output x 1 |
| ANALOG VIDEO OUT | N/A |
| MEMORY CARD | MicroSD Memory Card, MicroSDHC Memory Card, MicroSDXC Memory
Card Compatible. Frame Rate: Max. 1 fps (JPEG) Max. 30 fps (H.264) |
| TEMPERATURE | Temperature: -10 ° C - +50 ° C (+14 ° F - +122 ° F) |
| HUMIDITY | Humidity: 5% - 85% (without condensation) |
| PoE | PoE: PoE power supply via LAN connector (IEEE802.3af compliant) |
| AC ADAPTER | N/A |
| EXTERNAL POWER SOURCE | N/A |
| WITH PoE | Max. approx. 4.1 W |
| WITH AC ADAPTER | N/A |
| WITH 12VDC | N/A |
| WITH 24VAC | N/A |
| DIMENSIONS | ((F x H) F120 x 54mm (F4.72 x 2.13 in.) |
| MOUNTING POSITION | Horizontal / Vertical |
| HEATER | N/A |
| WEIGHT | Approx. 240 g (.53 lb.) |
| OUTDOOR READY | No |
| IP RATING | N/A |
| VANDAL RESISTANT | No |
| IMPACT RESISTANCE | N/A |
ADDITIONAL SUPPORT
CONTACT US
next to your download
