Canon Support for VB-S805D Mark II | Canon U.S.A., Inc.
VB-S805D Mark II
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Mobile Camera Viewer Operation Guide
File Name
Network Camera Operation Guide
File Name
File Name
Camera Management Tool User Manual
File Name
File Name
Network Camera Appendix – Specifications
File Name
Data Size and Bit Rate Estimates
SELECT ERROR CODE
| IMAGE SENSOR | 1/3" CMOS (RGB) |
| NUMBER OF EFFECTIVE PIXELS | Approx. 1.3 million pixels |
| SCANNING METHOD | Progressive Scan |
| LENS | Fixed focal length lens |
| FOCAL LENGTH | 2.7mm |
| F-NUMBER | F1.6 |
| DIGITAL ZOOM | 4x |
| HORIZONTAL VIEWING ANGLE (16:9) | 95° |
| VERTICAL VIEWING ANGLE (16:9) | 60° |
| DAY/NIGHT MODE | Yes |
| I/R CUT FILTER | Digital Night Mode |
| MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.45 lux (F1.6, shutter speed 1/30 sec) |
| MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0.25 lux (F1.6, shutter speed 1/30 sec) |
| FOCUS MODES | - |
| SHOOTING DISTANCE | 0.5m (1.6 ft.) - infinity (W) |
| SHUTTER SPEED | 1 - 1/16000 sec. |
| EXPOSURE MODES | Auto/ Auto (Flickerless)/Auto (Flickerless2)/Auto (shutter-priority AE)/ Manual (Shutter Speed, Gain) |
| WHITE BALANCE | Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/Manual(One-shot WB/R Gain/B Gain) |
| METERING MODES | Center-Weighted/Average/Spot |
| EXPOSURE COMPENSATION | 9 levels |
| SMART SHADE CONTROL | Auto / Manual / Disable
Auto: 3 Levels Manual: 7 Levels |
| HAZE COMPENSATION | Auto/Manual/Disable
Auto: 3 levels Manual: 7 levels |
| AGC LIMIT | 6 levels |
| IMAGE STABILIZER | Digital (2 Levels) |
| MOTION ADAPTIVE NOISE REDUCTION | Available |
| CLEAR IR | N/A |
| PAN ANGLE RANGE | 3350° (±175°) |
| TILT ANGLE RANGE | 90° (ceiling-mounted position: -90° - 0°) |
| ROTATION ANGLE RANGE | 180° (±90°) |
| IR ILLUMINATION RANGE | N/A |
| MOVING SPEED | N/A |
| VIDEO COMPRESSION METHOD | JPEG, H.264 |
| BIT RATE CONTROL | - |
| VIDEO SIZE | JPEG, H.264: 1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240 |
| VIDEO QUALITY | JPEG, H.264: 10 levels |
| FRAME RATE | JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps |
| MAXIMUM FRAME RATE | JPEG, H.264 (1920 x 1080): 30fps |
| ADSR: AREA-SPECIFIC DATA SIZE REDUCTION | - |
| I-FRAME INTERVAL | 0.5/1/1.5/2/3/4/5 sec. |
| SIMULTANEOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients |
| CAMERA CONTROL | Administrator, Authorized user, Guest user |
| ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4, IPv6) |
| ENCRYPTED COMMUNICATIONS | SSL/TLS, IPsec (Auto Key Exchange/Manual) |
| IEEE 802.1X | EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP |
| ONVIF Version | ONVIF Profile S |
| IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary) |
| IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary) |
| AUTO IP (LINK-LOCAL) | Yes |
| AUDIO COMPRESSION METHOD | G.711 µ-law (64 kbps) |
| AUDIO COMMUNICATION METHOD | Audio Reception Only |
| AUDIO FILE PLAYBACK | Available |
| PRIVACY MASK | Number of registration: Max. 8 places,
Number of mask colors: 1 (select from 9 colors) |
| VIEW RESTRICTION | Available |
| PRESETS | Number of registers: Max. 20 positions (+Home Position)
Number of Preset Tour Route: Max. 1 |
| INTELLIGENT FUNCTION - VIDEO | Moving object detection, abandoned object detection, removed object
detection, camera tampering detection, passing detection and intrusion detection |
| INTELLIGENT FUNCTION - AUDIO | Volume Detection & Scream Detection |
| INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
| EVENT TRIGGER TYPE | External Device Input, Timer, Intelligent Function (Video),
Intelligent Function (Volume) |
| IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail) |
| EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
| ON-SCREEN DISPLAY | Available |
| IMAGE CROPPING FUNCTION | Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96 |
| ENHANCED DIGITAL ZOOM | Available |
| DAYLIGHT SAVINGS TIME | Available |
| CUSTOM SETTINGS | Available |
| NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
| AUDIO INPUT TERMINAL | F3.5mm (F0.14 in.) mini-jack connector (monaural)
Switch LINE IN/MIC IN in the setting page. |
| AUDIO OUTPUT TERMINAL | F3.5mm (F0.14 in.) mini-jack connector (monaural)
LINE OUT x 1 (connect to an amplifier speaker) |
| EXTERNAL DEVICE I/O TERMINAL | Input x 1, Output x 1 |
| ANALOG VIDEO OUT | N/A |
| MEMORY CARD TYPE | MicroSD Memory Card, MicroSDHC Memory Card, MicroSDXC Memory Card Compatible. |
| MEMORY CARD RECORDED CONTENT | Log, Video (Event, Manual, ONVIF, Timer, Upload) |
| MEMORY CARD RECORDED FRAME RATE | Frame Rate: Max. 1 fps (JPEG)
Max. 30 fps (H.264) |
| TEMPERATURE | Temperature: -10°C - +50°C (+14°F - +122°F) |
| HUMIDITY | Humidity: 5% - 85% RH (without condensation) |
| TEMPERATURE | -30°C - +60°C (-22°F - +140°F) |
| HUMIDITY | 5% - 90% RH (without condensation) |
| PoE | PoE: PoE power supply via LAN connector (IEEE802.3af compliant) |
| AC ADAPTER | N/A |
| EXTERNAL POWER SOURCE | N/A |
| WITH PoE | Max. approx. 4.1 W |
| WITH AC ADAPTER | N/A |
| WITH 12VDC | N/A |
| WITH PoE + | - |
| WITH 24VAC | N/A |
| DIMENSIONS | (F x H) F120 x 54mm (F4.72 x 2.13 in.) |
| MOUNTING POSITION | Ceiling mount / Surface Mount |
| HEATER | N/A |
| WEIGHT | Approx. 240 g (.53 lb.) |
| OUTDOOR READY | No |
| IP RATING | N/A |
| VANDAL RESISTANT | No |
| IMPACT RESISTANCE | N/A |
ADDITIONAL SUPPORT
CONTACT US
next to your download
