Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 02.25.09
File Size 3.68 MB
Date 01.03.08
File Size 3.97 MB
Date 03.04.10
File Size 6.23 MB
Camera Connect
Camera Connect
image.canon
image.canon
Standard Definition or High Definition High Definition
Television System NTSC
Video Recording system MPEG4-AVC / H.264
Image Sensor 1/2.6-inch CMOS, RGB Primary Color Filter
Total Pixels Approx. 8.59 Megapixels
Maximum recording Time 32GB SDHC Memory Card (not supplied)
LP (5 Mbps) 12 hours 15 minutes
SP (7 Mbps) 9 hours 35 minutes
XP+ (12 Mbps) 5 hours 45 minutes
FXP (17 Mbps) 4 hours 10 minutes - Allows 1920 x 1080 Full HD Recording
MXP (24 Mbps) 2 hours 55 minutes - Allows 1920 x 1080 Full HD Recording
Lens Zoom Ratio 10x Optical / 200x Digital
Focal Length f=6.4- 64mm (35mm equivalent: 43.5 - 435mm)
Zoom Speed Variable / 3 Fixed Zoom Speeds
Max. F/Stop f/1.8-3.0
Focusing System Instant AF, Face Priority AF, TTL (through the lens)
Manual Exposure Yes
Programmed AE AUTO, P, Av, Tv, Portrait, Sports, Night, Snow, Beach,Sunset, Spotlight, Fireworks
Max Shutter Speed Movie: 1/2000, Still image: 1/500
Focusing System 10mm (wide) / 1m (tele)
White Balance Auto, Daylight, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Manual
Frame Rate 60i, 24p Progressive (records at 60i), 30p Progressive (records at 60i)
Minimum Illumination 0.3 lx (Night mode)
Image Stabilization SuperRange Optical (lens shift)
Filter Diameter 58mm
Viewfinder None
LCD Screen 2.7-inch Multi-Angle Vivid widescreen color LCD (Approx. 211,000 dots)
Flash Built-in
Recording Media SDHC Memory Card
USB Terminal USB 2.0 Hi-Speed
Video Terminal component (output), composite (output)
Audio Dolby Digital 2 channels (AC-3 2 ch)
Accessory Shoe mini Advanced
Supplied Video Editing Software Pixela ImageMixer 3SE
HDMI Terminal HDMI Mini Connector (output), CEC and x.v. Color
Microphone Terminal 3.5 mm stereo mini-jack
AV Mini Terminal/Headphone Terminal 3.5 mm 4 pole mini-jack (video/audio output only)
Dimensions (W X H X D) 2.8 x 2.7 x 5.4in. (70 x 69 x 136mm)
Weight (not including lens and battery pack) 15.9 oz. (450g)
Weight 1.1 lb. (500g)
CANON DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY
FOR THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Consumer Digital Video Equipment (the 'Equipment') purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted under normal, non-commercial, personal use, against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase, except for a defective Video Head, which will be exchanged for a period of three months from the date of purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by our factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be return-shipped to you. (shipping charges apply). If you disapprove, we will return-ship the equipment at no charge to you.
Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and incompatible software. In order to obtain warranty service, contact the authorized Canon retail dealer from whom you purchased the Equipment or call the CANON INFORMATION CENTER AT 1800-OK-CANON). You will be directed to the nearest service facility for your Equipment.
  1. Loss or damage to the Equipment due to abuse, mishandling, accident, improper maintenance, or failure to follow operating instructions;
  2. If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
  3. If defects or damages are caused by the use of unauthorized parts or by service other than by Canon USA's factory service centers or authorized service facilities;
This Limited Warranty does not cover cabinet (exterior finish), video cassette tape, head cleanings, nor does it apply to Equipment purchased outside the United States. This warranty does not cover units sold to rental firms, military operations, hotels, schools, hospitals or for other commercial, industrial, or institutional applications. These uses are covered only by such specific warranty as Canon may issue with such sales. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold “AS IS”, without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card is most important in order to be sure you are contacted right away should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT’S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU).THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state. CANON U.S.A., INC
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
