Canon Support for Wireless File Transmitter WFT-E6A | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type
Image transfer accessory compatible with IEEE 802.11a, IEEE 802.11b, IEEE802.11g and IEEE 802.11n wireless LAN support (IPsec-compatible). Can support GPS devices with an internal Bluetooth function.
Compatible Cameras
EOS-1D X, EOS C300, EOS C300 Mark II, EOS C500, EOS-1D C
FTP Transfer
Transfer images over a network to FTP servers
EOS Utility
EOS Utility-based control of cameras over a network
WFT Server
Browser-based remote capture and downloading of images over a network
Linked Shooting
Wirelessly trigger shooting by Slave cameras linked to a Master camera
Transmission Range
Linked Shooting: Approx. 328 ft. / 100 m from the master camera when signal strength is favorable
Wireless LAN: Approx. 492 ft. / 150 m
- With no obstructions between the transmitting and receiving antennas and no radio interference
- When a large, high-performance antenna is installed at a wireless LAN access point
Wireless Time Syncing
- Master camera time is set for the EOS-1D X units (up to 10 units) connected in the wireless LAN.
- Setting margin of error with master camera: Maximum Approx. ±TBA sec.
Camera Connection
System expansion terminal
Wired Lan Connection
Not Available; Wireless LAN function only
External Device Connection
USB host function is not included since this device is intended for wireless LAN function only
Power Supply
Powered by the camera
Battery Level Indicator
6-level indicator
W x H x D
TBA
Ounces/grams
TBA
Temperature
32°F to 104°F/0°C to 40°C
Humidity
85% or less
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
next to your download
