Canon Support for Wireless File Transmitter WFT-E8A | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | IEEE 802.11ac/n/a/g/b wireless LAN support; Image transfer accessory |
Compatible Cameras | EOS-1D X Mark II Camera |
FTP Transfer | Transfer images over a network to FTP servers |
EOS Utility | EOS Utility-based control of cameras over a network |
WFT Server | Browser-based remote image/video capture with downloading, playback and browsing of images/video over a network |
Linked Shooting | Max. 10 receiver cameras Transmission Range: Approx. 328 ft. / 100m from the sender camera (when signal strength is favorable) WFT Server Start: Possible at manual connection with receiver camera |
Transmission Range | Linked Shooting: Approx. 328 ft. / 100m from the sender camera (when signal strength is favorable) Wireless LAN: Using an access point: Max. approx. 492 ft./150m Transmitting directly to a smartphone: Max. approx. 49.2 ft./15m In linked shooting: Max. approx. 328 ft. / 100m With no obstructions between the transmitting and receiving antennas and no radio interference |
Camera Connection | Terminal |
Wired LAN Connection | None |
External Device Connection | Available |
Power Supply | Powered by the camera |
Image Transfer Capacity | When a fully charged Wireless File Transmitter WFT-E8A is used with the EOS-1D X Mark II camera. Under Camera & Imaging Products Association (CIPA) conditions for testing shooting capacity, when using automatic image transfer with images that are approx. 6MB. Fewer images can be transferred if the wireless LAN transfer speed drops, and for consecutive image transfer over wireless LAN. If the remaining battery level drops below 19%, captured images cannot be transferred. |
W x H x D | Approx. 0.97 x 2.24 x 1.34 in. / 24.7 x 57.0 x 34.1mm |
Ounces/grams | Approx. 1.34 oz. / 38g |
Temperature | 32°F to 113°F/0°C to 45°C |
Humidity | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
