Canon Support for Wireless File Transmitter WFT-E9A | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.31.22
File Size 156.00 B
Software Development Kit
Type Wireless LAN accessory
IEEE 802.11ac 2x2 MIMO/ac/n/a/g/b wireless LAN support; Image transfer accessory
Compatible Cameras EOS-1D X Mark III Camera
C500 Mark II Digital Cinema Camera
FTP Transfer Transfer images over a network to FTP servers
EOS Utility EOS Utility-based control of cameras over a network
WFT Server Browser Remote function is not available with EOS-1D X Mark III Camera firmware Ver.1.0.0. This function will be added to the future firmware update.
Linked Shooting Max. 10 receiver cameras
Transmission Range: Approx. 492 ft. / 150m from the sender camera (when signal strength is favorable)
WFT Server Start: Possible at manual connection with receiver camera
Transmission Range Using an access point: Max. approx. 492 ft./150m
Linked shooting: Max. approx. 164 ft. / 50m
Smartphone connection: Not supported
With no obstructions between the transmitting and receiving antennas and no radio interference
Camera Connection Terminal
Wired LAN Connection None
External Device Connection Available
Power Supply Powered by the camera
W x H x D Approx. 0.98 x 2.54 x 1.32 in. / 25.0 x 64.5 x 33.5mm
Ounces/grams Approx. 1.59 oz. / 45g
Temperature 32°F to 113°F/0°C to 45°C
Humidity 85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
