Canon Support for Wireless File Transmitter WFT-R10A | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.31.22
File Size 145.00 B
Software Development Kit
Type Wireless / wired LAN accessory
Wireless File Transmitter (WFT)
Compatible Cameras EOS R5
EOS Utility EOS Utility-based control of cameras over a network
Linked Shooting Max. 10 receiver cameras
Transmission Range: Approx. 492 ft. / 150m from the sender camera (when signal strength is favorable)
WFT Server Start: Possible at manual connection with receiver camera
Transmission Range Using an access point: Max. approx. 492 ft./150m
Linked shooting: Max. approx. 164 ft. / 50m
Smartphone connection: Not supported
* With no obstructions between the transmitting and receiving antennas and no radio interference
Charging / Power Supply EOS R5+ WFT-R10A+ USB Power Adapter PD-E1 (Charging is not possible with WFT-R10A+ PD-E1)
W x H x D Approx. 5.64 x 4.50 x 3.19 in. / 143.2 x 114.4 x 81.0mm
Ounces/grams Approx. 13.93 oz. / 395g (Including battery magazine, and excluding batteries)
Temperature 32°F -104°F/0°C -40°C
Humidity
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: Wireless File Transmitter WFT-R10: Firmware Version 1.1.0
Advisory Type
Date 08.25.20
Title Firmware Notice: WFT-R10: Firmware Version 1.3.1
Advisory Type Firmware Notice
Date 03.26.24
Title Firmware Notice: WFT-R10A: Firmware Version 1.2.1
Advisory Type
Date 02.24.22
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
