Firmware Notice: EOS C50: Firmware Version 1.0.4.1
Firmware Version 1.0.4.1 incorporates the following fixes and enhancements:
  1. Adds [Ease In / Ease Out] to [Digital Zoom Speed].
    When set to On, this setting smooths the transitions at the start and end of digital zoom operations.
  2. Enables operation of the following camera functions from an external device via USB connection when the power switch is set to [VIDEO] and the camera is in camera mode:
    - Start/Stop Recording
    - One-Shot AF
    - Manual Focus Adjustment
    - Iris
    - Shutter Speed
    - ISO Speed
  3. Changes the color of the level indicator when the orientation of the camera is level.
  4. Enables automatic reconnection attempts during SRT protocol streaming if the connection is lost, continuing for the duration specified in the [SRT: Reconnection Timeout] setting.
  5. View Assist can now be applied and adjusted during playback.
  6. Supports the following transmission methods in the CV Protocol:
    -Broadcast
    -Multicast (Same segment only.)
  7. Adds a communication setting menu, making it now possible to select OpenLensIO-Equiv. Model.
  8. When registering a Look File, it is now possible to refer to the description in the Look File and reflect it in the Custom Picture settings.
  9. Fixes an issue that may cause certain CFexpress cards to be unable to format in the camera.
  10. Fixes an issue that may cause Digital IS metadata to not be output correctly under the following settings: [Recording Mode] set to [Slow & Fast Motion], the frame rate set to lower than 24P, and [Shutter Manual] to [Angle] with an angle of 180.00° or below.
  11. Fixes an issue that may cause the camera to not be recognized when connected to a smartphone via USB.
  12. Improves operational stability.
Support
Download Firmware Version 1.0.4.1 for the EOS C50.
To help obtain optimal performance of this camera, we recommend that you also download and install the most recent versions of Canon Software and the EOS C50 Advanced User Guide.
If you have not already done so, please register the EOS C50. By registering, we will be able to notify you via email about future announcements.
This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
Thank you,
Canon U.S.A., Inc.
Contact Information for Inquiries
Phone: 1-855-CINE-EOS / 1-855-246-3367
TDD: 1-855-270-3277
Email: CinemaEOS@cits.canon.com
For additional support options: https://www.usa.canon.com/support
