Canon Support for CanoScan 8000F | Canon U.S.A., Inc.
CanoScan 8000F
Language
Download Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 04.01.07
File Size 2.07 MB
Date 12.27.11
File Size 2.47 MB
Date 04.01.07
File Size 2.60 MB
Products Windows 7 Windows 8 Windows 10 Windows 10s
CanoScan 8000F 1
Scanner Type Flatbed, color and monochrome
Scanning Element Charge-Coupled Device (CCD)
Light Source Cold Cathode Fluorescent Lamp
Scanning Mode 48-bit internal/external, Grayscale - 16-bit internal/external, Black & White, Text Enhanced
Max. Document Size 8.5" x 11.7"; Film - 35mm x 12 frames (negatives), 35mm x 4 frames (mounted slides)
Interface USB 2.0 Hi-Speed
Dimensions (W x D x H) 11.2" x 19.5" x 4.2"
Weight 8.8 lbs.
OS Compatibility Windows® 98/2000/Me/XP, Mac® OS 9.0 - 9.x, Mac OS X v10.1 or later (classic mode), Mac OS X v10.1.3 (native mode)
Software CanoScan Setup CD-ROM****** Including: ScanGear® CS (Windows/Mac), CanoScan Toolbox (Windows/Mac), ArcSoft® PhotoStudio® (Windows/Mac), ArcSoft PhotoBase™ (Windows/Mac), ScanSoft® OmniPage® SE OCR™ (Windows/Mac OS 9.1 to 9.x, Mac OS X (classic mode)), NewSoft® Presto! PageManager® (Windows only) and NewSoft Presto! BizCard® (30-day trial version, Windows only); Adobe® Photoshop® Elements
Power Source 120V AC, 60 Hz
Max. Power Consumption 15 W (10.6 W standby)
Operating Temperature: 50° - 95°
Operating Humidity: 20% - 80% RH
Warranty 1-year limited warranty with InstantExchange program (subject to certain conditions and restrictions. See www.canontechsupport.com for full details.)
* Based on Canon Inc. testing, using Pentium 4, 1.7 GHz, 256MB RAM, using Adaptec DUO CONNECT. Scanning an approx. 8.5" x 11" image at 600 dpi. Results may vary.
** Available only when using 2400 dpi or less.
*** Windows users only.
**** Systems with Pentium® III or higher, Celeron® (566MHz or higher), AMD: Athlon™, Athlon MP, Athlon XP or Duron are recommended for optimal performance.
***** ScanGear CS driver (Plug-in compatible) and CanoScan Toolbox, quick scanning utility are available in Mac OS X native mode.
****** System requirements vary by application.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
