Canon Support for CanoScan 8400F | Canon U.S.A., Inc.
CanoScan 8400F
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 04.01.07
File Size 3.65 MB
Date 04.01.07
File Size 1.80 MB
Products Windows 7 Windows 8 Windows 10 Windows 10s
CanoScan 8400F 1
Scanner Type Flatbed, color and monochrome
Scanning Element Charge-Coupled Device (CCD)
Light Source Cold Cathode Fluorescent Lamp
Scanning Mode Color: 48-bit internal/48-bit external
Grayscale: 16-bit input/8-bit output (16-bit output when scanning film); Black & white; Text enhanced
Max. Document Size 8.5" x 11.7"
Max. Film Size 35mm x 12 frames (negatives), 35mm x 4 frames (mounted slides), Film Strip (120 roll film)
Interface USB 2.0 Hi-Speed* (Cable included)
Dimensions (W x D x H) 10.9"(W) x 4.8"(H) x 19.7"(D)
Weight 10.6 lbs.
Software CanoScan Setup CD-ROM*** including: ScanGear® CS, CanoScan Toolbox CS, Adobe® Photoshop® Elements 2.0, ArcSoft® PhotoStudio®, ScanSoft® OmniPage® SE OCR, NewSoft® Presto! Page Manager®
Power Source 120V AC, 60Hz
Max. Power Consumption 20W (4.5W standby)
Operating Temperature: 50° - 95°F
Operating Humidity: 20% - 80% RH
Warranty Toll-free telephone support. 90-day limited warranty (subject to certain terms and conditions, see www.canontechsupport.com for details)
* USB 2.0 Hi-Speed is not supported by Windows 98.
** Systems with Pentium® III or higher, Celeron® (566MHz or higher), AMD: Athlon™, Athlon MP, Athlon XP or Duron are recommended.
*** System requirements vary by application.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
