Canon Support for CanoScan LIDE 400 | Canon U.S.A., Inc.
CanoScan LIDE 400
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.07.25
File Size 78.41 KB
Date 09.13.18
File Size 1.05 MB
Date 09.13.18
File Size 1.45 MB
Date 09.13.18
File Size 1.43 MB
Date 09.13.18
File Size 1.05 MB
Products Windows 7 Windows 8 Windows 8 Windows 10 Windows 10s Windows 11
CanoScan LIDE 400 1 3
CanoScan LIDE 400
Scanner Type Flatbed
Scanning Element Contact Image Sensor (CIS)
Light Source Three Color (RBG) LED
Features 5 'EZ' Buttons, Advanced Z-lid™ Expansion Top, Auto Dust & Scratch Reduction (Windows Only), Auto Document Fix (Windows Only), Auto Scan ModeFootnote3, Digital Filing, Fading Correction (Windows Only), Grain Correction (Windows Only), Gutter Shadow Correction (Windows Only), High-Speed ScanningFootnote1, Image Correction, Low Power Consumption, Multi-Page PDF, OCR (Optical Character Recognition)Footnote4, One Cable For Data & Power, Send to CloudFootnote5, Upright Scanning
Scanner Buttons 5 'EZ' Buttons; Auto Scan, Copy, PDF x2 (Scan Start, Scan Finish), Send
Max. Resolutions Optical:4800 x 4800 dpiFootnote2Interpolated:19,200 x 19,200 dpiFootnote2
Scanning Speed Document: Approx. 8 Seconds (300 dpi/Letter Size/Color) 4"x6"Footnote1
Photo: Approx. 4 Seconds (300 dpi/Color)Footnote1
Scanning Mode Color: 48-bit Internal / 48-bit or 24-bit External
Grayscale: 16-bit Internal / 8-bit External
Max. Document Size 8.5" x 11.7" (Letter/A4)
Dimensions (W x D x H) 14.5" (W) x 9.9" (D) x 1.7" (H)
Weight 3.6 lbs.
OS Compatibility Windows: 7 Windows® 10, Windows 8.1, Windows 7 SP1
Mac: macOS® X v10.11 - macOS v10.13 (High Sierra)
Linux®:Footnote9 Requires ScanGear MP Driver Installed
Power Requirements USB Type-C™ (One Cable For Data & Power)
Software (WINDOWSFootnote7 /MACFootnote8/LINUXFootnote9)
CanoScan LiDE 400 Color Image Scanner Driver
IJ Scan Utility (Windows) / IJ Scan Utility Lite (Mac)
Auto Scan, Document Scan, Photo Scan, Custom Scan, Stitch Scan, and OCR (Optical Character Recognition)Footnote4
ScanGear MP DriverFootnote9
Quick Menu
Power Source USB Type-C™ (One Cable For Data & Power)
Max. Power Consumption 4.5 W (0.3 W Standby)
Operating Temperature: 41 - 95°F (Without Condensation)
Operating Humidity: 10 - 90% (Relative Humidity)
Warranty 1-Year Limited Warranty with InstantExchange Program.Footnote10
CERTIFICATION ENERGY STAR® Certified
SCANNER METHOD LiDE (LED Indirect Exposure)
 Limited Warranty & InstantExchange Program Details
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canon-brand product ("Product") packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service (a) for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container or (b) for 90 days from the date of original purchase for refurbished Products. Product returned to a Canon USA repair facility or a Canon USA Authorized Service Facility ("ASF"), and proven to be defective upon inspection will be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts (b) exchanged for new or; (c) exchanged for a refurbished Product, as determined by the Canon USA repair facility or the ASF. Warranty repair or replacement shall not extend the original warranty period of the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold "as is" and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or ASF. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user's manual or other documentation for the Product.
  2. Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink cartridges or refilled ink cartridges, that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROMS ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
Canon USA offers a full range of customer technical support* options:
    Interactive troubleshooting, e-mail technical support, the latest driver downloads and answers to frequently asked questions (www.canontechsupport.com)
    Toll-free live technical support within the limited warranty Monday—Friday (excluding holidays) at 1-800-828-4040
    Telephone Device for the Deaf (TDD-1-855-270-3277)
    Repair or Exchange Service Options: In the event service is required for the Product during the limited warranty period, Canon USA offers two hardware support options:
Canon USA's Carry-In/Mail-In Service provides repair or exchange, at Canon USA's option, through Canon USA's Authorized Service Facility (ASF) network. The name and telephone number of the ASF(s) near you may be obtained from Canon USA's Web site at www.canontechsupport.com or by calling the Canon USA Customer Care Center at 1-800-828-4040, or any time while speaking to a technical support person. A Product covered by this limited warranty will be repaired or exchanged, as determined by Canon USA, and returned without charge by the ASF.
InstantExchange Service **
The Canon USA repair facility will ship out the replacement Product prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the enclosed instructions on how to ship your product to the Canon USA repair facility. Your Product must be returned in the shipping carton in which the replacement Product was packed and include the reference number, A COPY OF YOUR DATED PROOF OF PURCHASE (BILL OF SALE), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS WITH THE YOUR PRODUCT IN THE RETURN SHIPPING CARTON, AND BE SURE TO RETAIN YOUR PRINTHEAD, INK CARTRIDGE(S) AND TANK(S).
InstantExchange Service exchanges your Product with a replacement Product, which will normally be shipped the same day if your request for this service is by 3 p.m. E.T. Monday through Friday, except holidays. Canon USA does not guarantee same day shipment in the event of the occurrence of factors beyond its reasonable control. The replacement Product you receive may be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA. InstantExchange warranty program service is available only during the express limited-warranty period for your Product and only in the continental United States, Alaska and Hawaii during such period.
InstantExchange warranty service is subject to the availability of refurbished or new replacement units.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
