Canon Support for CanoScan LiDE 60 | Canon U.S.A., Inc.
CanoScan LiDE 60
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.15.08
File Size 2.83 MB
Date 04.01.07
File Size 832.00 KB
Products Windows 7 Windows 8 Windows 10 Windows 10s
CanoScan LiDE 60 1
Scanner Type Flatbed, color and monochrome
Scanning Element Contact Image Sensor (CIS)
Light Source Three-color RGB LEDs
Scanning Mode Color: 48-bit internal/48-bit external (selectable in driver)
Grayscale: 16-bit internal/8-bit external
Black & white
Text enhanced
Max. Document Size 8.5" x 11.7"
Interface USB 2.0 Hi-Speed* (cable included)
Dimensions (W x D x H) 10.1" x 14.7" x 1.5"
Weight 3.97 lbs.
OS Compatibility Windows&reg 2000/Me/Win 98/XP, Mac&reg OS X 10.2.7 to 10.4.x
Software ScanGear&reg; CS11.0(Windows/Mac), CanoScan Toolbox 4.9(Windows/Mac), ArcSoft&reg; PhotoStudio&reg; (Windows/Mac), ScanSoft&reg; OmniPage&reg; SE OCR**(Windows/Mac).
System requirements vary by application.
Power Source Powered through USB port, no AC adapter required
Max. Power Consumption 2.5W (1.4W standby)
Operating Temperature: 41&deg; to 95&deg;F
Operating Humidity: 10% to 90% RH
Warranty Toll-free technical phone support plus 1-year limited warranty with InstantExchange program (subject to certain conditions and restrictions. See www.canontechsupport.com for full details.)
* Windows 98 Systems operate at USB 1.1 speed only.
** ScanSoft OmniPage SE (OCR software) is not supported by Windows 98 First edition.
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canon-brand product ("Product") packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service (a) for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container or (b) for 90 days from the date of original purchase for refurbished Products. Defective parts or a defective Product returned to a Canon USA repair facility or a Canon USA Authorized Service Facility ("ASF"), and proven to be defective upon inspection, will be repaired, exchanged for new or comparable rebuilt parts, or exchanged for a refurbished Product, as determined by the Canon USA repair Facility or the ASF. Warranty repair or replacement shall not extend the original warranty period of the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold "as is" and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA’s user’s manual or other documentation, or services performed by someone other than a Canon USA repair facility or ASF. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user’s manual or other documentation for the Product.
  2. Use of parts or supplies (other than those sold by Canon USA) that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
Canon USA offers a full range of customer technical support* options:
    Interactive troubleshooting, e-mail technical support, the latest driver downloads and answers to frequently asked questions (www.canontechsupport.com)
    Toll-free live technical support within the limited warranty Monday—Saturday (excluding holidays) at 1-800-828-4040
    The location of the ASF nearest you for carry-in service (1-800-828-4040)
    Telephone Device for the Deaf (TDD-1-855-270-3277)
If the problem cannot be corrected by using one of the above technical support options, repair options (i.e. Carry-In/Mail-In Service*, InstantExchange Warranty Service*), along with details and conditions of each, are available at the time of your call to the live technical support number(s) above or via the website at www.canontechsupport.com. Please note that under the InstantExchange program, a replacement product will be provided to you prior to your return of the defective product. Since the defective product becomes the property of Canon USA at the time of the exchange, the defective product must be returned in the shipping materials provided. If the defective product is not returned, as directed, you will be responsible for the value of the replacement product, for which Canon USA may invoice you.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
Download Warranty (PDF)
InstantExchange Warranty Program*
The InstantExchange Warranty Program expedites the shipment of a Canon factory refurbished product in exchange for a non-working Canon product, freight prepaid both directions.
Call 1-800-828-4040 and follow the voice prompts for details and service. Hours of operation:
    M-F: 8:00 AM - midnight EST (excluding holidays)
The InstantExchange Warranty Program is available:
  1. only for certain printer, facsimile, multifunction, and scanner models;
  2. during the express limited warranty period for such products; and
  3. only in the continental United States, Alaska and Hawaii.
InstantExchange Warranty Program Service
A Canon Customer Care Center or ASF technician will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the problem cannot be corrected over the telephone, and you elect the InstantExchange option, a reference number will be issued to you. You will be asked for the Product serial number and other information pertaining to your defective Product and for a ship-to location for the replacement Product (must include street address).
The Canon USA repair facility will ship out the replacement Product, via 2nd day Air freight service, prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the enclosed instructions on how to ship the defective Product to the Canon USA repair facility. The defective Product must be returned in the shipping carton in which the replacement Product was packed and include the reference number, A COPY OF YOUR DATED PROOF OF PURCHASE (BILL OF SALE), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS WITH THE DEFECTIVE PRODUCT IN THE RETURN SHIPPING CARTON, AND BE SURE TO RETAIN YOUR PRINTHEAD AND INK CARTRIDGE(S) AND TANK(S).
InstantExchange  Warranty Program Service expedites, usually by the second business day, the exchange of a defective Product with a replacement Product, which will normally be shipped the same day if your request for this service is by 3 p.m. E.T. Monday through Friday, except holidays (three (3) business day InstantExchange Service for Alaska and Hawaii). Canon USA does not guarantee expedited shipping service in the event of the occurrence of factors beyond its reasonable control. The replacement Product you receive may be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE DEFECTIVE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA. InstantExchange Warranty Program Service is available only during the express limited-warranty period for your Product and only in the continental United States, Alaska and Hawaii during such period.
*Support program specifics are subject to change without notice. InstantExchange Warranty Program Service is subject to availability of refurbished replacement units.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
