Canon Support for Cine-Servo 11-55mm T2.95 PL | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 11.04.25
File Size 43.65 MB
Date 11.04.25
File Size 271.76 KB
Model Name CINE-SERVO 11-55mm T2.95-3.95 PL
Mount Type PL mount
Lens Communication Cooke/i® Technology, ZEISS® eXtended Data
Zoom Ratio 5x
Built-in extender Yes (1.5x)
Focal Length 11-55mm / 16.5 - 82.5mmFootnote2
Maximum Diameter Ratio (T-number) T2.95 at 11 41 mm / T3.95 at 55 mm
T4.4 at 16.5 - 61.5 mm / T5.9 at 82.5 mmFootnote2
Number of Iris Blades 11 blades
Angle of View / Field of View
Angle of viewAspect ratio 1.78:1
Dimensions 24.6 x 13.8 mm
96.4°x 64.2°at 11 mm / 25.2°x 14.3°at 55 mm
73.4°x 45.4°at 16.5 mm / 17.0°x 9.6°at 82.5 mm2
Aspect ratio 1.9:1
Dimensions 26.2 x 13.8 mm
100.0°x 64.2°at 11 mm / 26.8°x 14.3°at 55 mm
76.9°x 45.4°at 16.5 mm / 18.0°x 9.6°at 82.5 mm2
Aspect ratio 1.9:1
Dimensions 38.1 x 20.1 mm
98.2°x 62.7°at 16.5 mm / 26.0°x 13.9°at 82.5 mm2
Aspect ratio 1.5:1
Dimensions 36 x 24 mm
95.0°x 72.1°at 16.5 mm / 24.6°x 16.6°at 82.5 mm2
M.O.D.0.6m / 2.0
Field of View at Minimum Shooting
Distance
Aspect ratio 1.78:1
69.7 x 39.1 cm at 11 mm / 13.3 x 7.5 cm at 55 mm
46.5 x 26.1 cm at 16.5 mm / 8.9 x 5.0 cm at 82.5 mm2
Aspect ratio 1.9:1
74.2 x 39.1cm at 11mm / 14.2 x 7.5cm at 55mm
49.5 x 26.1 cm at 16.5 mm / 9.5 x 5.0 cm at 82.5 mm2
Aspect ratio 1.9:1
72.0 x 38.0 cm at 16.5 mm / 13.8 x 7.3 cm at 82.5 mm2
Aspect ratio 1.5:1
68.0 x 45.3 cm at 16.5 mm / 13.1 x 8.7 cm at 82.5 mm2
Front Diameter 114mm
Image Circle 29.6mm / 43.3mm*
Filter Diameter: Hood/Lens 127 mm / 112 mm
Drive Unit (Detachable) 3x Hirose 20-pin: 1x Zoom, 1x Focus, 1x Virtual Lens Data
Outer Dimensions (W x H x D) Appx. 186.6 x 129.9 x 269.0mm
Weight Appx. 2.92 kg / 6.43 lbs
CINEMA EOS SYSTEM LENS LIMITED WARRANTY FOR PRODUCTS PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Cinema EOS System Lens (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
  1. Loss or damage to the Equipment due to abuse, mishandling, accident, improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
  2. If the Equipment is defective as a result of sand, dirt or water damage;
  3. If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
  4. If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
  5. Any internal modification to product hardware or firmware;
  6. Any applicable fee for Maintenance of the Equipment;
  7. If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU).THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
