Canon Support for Color imageCLASS MF624Cw | Canon U.S.A., Inc.
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 12.24.20
File Size 2.92 MB
Date 07.13.21
File Size 652.14 KB
Date 01.06.23
File Size 144.76 KB
Date 10.12.22
File Size 1.60 MB
Date 01.06.23
File Size 145.47 KB
Date 04.24.19
File Size 2.92 MB
Date 10.04.19
File Size 2.92 MB
Date 02.04.20
File Size 652.13 KB
Date 04.20.22
File Size 2.92 MB
Date 12.22.17
File Size 647.92 KB
Date 09.22.17
File Size 2.92 MB
Date 04.24.19
File Size 647.96 KB
Date 04.20.22
File Size 1.50 MB
Date 01.06.23
File Size 2.27 MB
Date 08.28.15
File Size 6.20 MB
image icon
Canon PRINT Business - iOS
Easily print from and scan to your iCloud accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
image icon
Canon PRINT Business - Android
Easily print from and scan to your Dropbox, Google Drive accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
Wireless Setup How-To Videos
Was this video helpful?
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0
Printer Specifications
Printer Type Color Laser MFP
Print Speed Color/Black: Up to 14 ppm (1-sided, plain paper letter)1
First Print Time Color/Black: 18 seconds (letter)2
Printer Language UFR II LT (Host Based)
Print Resolution 600 x 600 dpi,
1200 x 1200 dpi equivalent
Maximum Print Size Up to Legal
Print Modes Poster, Watermark, Page Composer, Toner Saver
Print Memory 512 MB (shared)
Direct Print from USB via USB Host v1.1 Print File format: JPEG, TIFF
Copier Specifications
Copy Type Color Laser
Copy Speed LTR/A4: Up to 14ppm (1-sided, Black/Color )1
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo/Map
Halftones 256 Levels
Warm-up Time 23 sec or less from power-on
First Copy Time Color/Black: Approx. 19 seconds (letter/A4)3
Recovery Time Approx. 8 sec
Maximum Number of Copies Up to 99 copies
Reduction/Enlargement 25 - 400% in 1% increments
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Letter,
ADF: 5.5" x 5" to Legal
Copy Features Frame Erase,
Memory Sort,
2 on 1,
4 on 1,
ID Card Copy
Copy Memory 512 MB (shared)
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Optical: Up to 600 x 600 dpi
Driver(digital): Up to 9600 x 9600 dpi
Scan Size Platen: Up to Letter
Compatibility TWAIN, WIA (Scan Driver Compatibility)
Output File Formats JPEG, TIFF, PDF, Compact PDF, PDF (OCR)
Scan Features Push Scan, Pull Scan
Pull Scan Yes, USB and Network
Push Scan (Scan to pC) Yes, USB and Network
Paper Handling Specifications
Standard Paper Source(s) 150-sheet cassette, 1-sheet multipurpose tray6
Document Feeder 50-sheet simplex6
Paper Output 125 sheets (face down)
Paper Weight 16-58 lb. bond (cassette / multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Executive
Media Types Plain, Heavy, Recycled, Color, Coated, Transparency, Label, Envelope, Index
Envelope Capacity 10 envelopes (cassette), 1 envelope (multipurpose tray)
Envelope Types Com 10, Monarch, DL, C5, B5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 High-Speed, 10/100 Base-T Ethernet, Wi-Fi 802.11b/g/n Wireless7
WiFi Access Mode Infrastructure Mode
WiFi Authentication Methods Open System, Shared Key, WPA-PSK, WPA2-PSK
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon PRINT Business8, Apple AirPrint™9, Mopria Print Service10, Google Cloud Print™11
Network Functions Print, Copy, Scan, Print/Scan to USB
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6), WSD-Scan (IPv4,IPv6)
TCP/IP Set of Application Services Bonjour(mDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1, SNMPv3 (IPv4,IPv6)
OS Compatibility Windows® 10, Windows® 8.1, Windows® 8, Windows® 7, Windows Server® 2012R2, Windows Server® 2012, Windows Server® 2008 R2, Windows Server® 2008, Windows Vista®, Windows Server® 2003, Mac® OS X 10.5.8 & up, Linux (print only)
Cable Included Power Cord (USB not included)
Bundled Software Printer driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager
Environmental Specifications
Power Consumption Max: 900W or less.
During Operation: Approx. 400W
Standby: Approx. 20W.
Energy Saver: Approx. 2W
Typical Energy Consumption 0.4 kWh
General Specifications
Dimensions 17" (W) x 19.1"(D) x 16.9"(H)
Unit Weight (without/with cartridge) 52.9 lbs. (w/o cartridge),
57.3 lbs (w/cartridge)
Package Weight Approx. 67.2 lbs.
Cartridge Type Cartridge 131 H Black (Yields approximately 2,400 sheets)
Cartridge 131 Black (Yields approximately 1,400 pages)
Cartridge 131 YMC (Yields approximately 1,500 pages)
*Yields based on ISO/IEC Standard
LCD Display 7-line QVGA Color Touch LCD
Duty Cycle Up to 30,000 pages per month
Department ID Management Yes, Up to 300 ID's
Security IEEE802.1x, SNMPv3, HTTPS, IPSEC, Department ID Management
Languages English, French, Spanish, Portuguese
One-Touch Keys Favorites Settings
Warranty 1 Year Exchange / Carry-in (Extended warranty available)12
Scanning Software Included: MF Scan Utility
Sending Method: SMB, E-mail, FTP, iFAX Simple
Color Mode: Full Color, Grayscale, Monochrome
Scan Resolution: 300 x 300 dpi, 200 x 200 dpi
Other Features: EPEAT Silver Rating
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Click Here to download the Color imageCLASS MF624Cw, Color imageCLASS MF628Cw, Color imageCLASS MF726Cdw, Color imageCLASS MF729Cdw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
