Canon Support for Color imageCLASS MF735Cdw | Canon U.S.A., Inc.
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
Wireless Setup
- USB Setup Instructions for Windows
- Wireless Setup Instructions for Windows
- Wireless Setup Instructions for Macintosh
Wireless Setup How-To Videos
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
WINDOWS
macOS X
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 | Golden Gate 27 |
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Printer Specifications
| Printer Type | All in One, Color, Wireless, Duplex Laser Printer |
| Print Speed | Up to 28 ppm (1-sided plain paper letter), Up to 23ppm (2-sided plain paper letter)1 (bw / color) |
| First Print Time | 9 seconds or less (letter)2 |
| Printer Language | UFR II (Host Based), PCL (6, 5c), Adobe® Postscript® |
| Print Resolution | Up to 600 x 600 dpi, 1200 x 1200 dpi equivalent |
| Maximum Print Size | Up to Legal |
| Duplex Print | Yes |
| Print Modes | Poster, Booklet, Watermark, Toner Saver, Page Composer |
| Print Memory | 1 GB (Shared) |
| Direct Print from USB | JPEG, TIFF, PDF |
Copier Specifications
| Copy Type | Color Laser |
| Copy Speed | Up to 28ppm (letter) |
| Duplex Copy Speed | Up to 23cpm (letter) |
| Copy Resolution | Up to 600 x 600 dpi |
| Original Type | Text/Photo, Text, Photo |
| Halftones | 256 Levels |
| Warm-up Time | 13 seconds or less from power on |
| First Copy Time | Approximately 10 / 11 seconds or less (bw/color, letter)3 |
| Recovery Time | Approximately 6 seconds |
| Maximum Number of Copies | Up to 999 copies |
| Reduction/Enlargement | 25 - 400% in 1% increments |
| Copy Size | Platen: Up to Letter / DADF: Up to Legal |
| Copy Features | Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
| Copy Memory | 1 GB (Shared) |
Fax Specifications
| Modem Speed | Up to 33.6 Kbps (Super G3)4 |
| Fax Resolution | Up to 406 x 391 (Ultrafine) |
| Transmission Time | Approx. 3 seconds |
| Memory Capacity | Up to 512 sheets5 |
| Speed Dials | 19 one-touch speed dials, Up to 281 coded dials |
| Group Dialing | 199 destinations |
| Sequential Broadcasting | 310 destinations |
| Duplex Fax | Yes |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Fax forwarding, Dual Access, Remote Reception, PC Fax (TX only), Distinctive Ring Pattern Detection, Error Detection Mode, Error Correction Mode, Auto Redial, Fax Activity / Activity Result Reports, Fax Activity Management Reports |
| Memory Backup | Permanent fax memory backup (Backup with flash memory) |
Scanner Specifications
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-bit |
| Scan Resolution | Up to 600 x 600 dpi (optical), 9600 x 9600 dpi (software interpolated resolution) |
| Scan Size | Platen: Up to Letter / ADF: Up to to Legal |
| Duplex Scan | Yes (One Pass Duplex Scan) |
| Compatibility | TWAIN, WIA 2.0, ICA |
| Output File Formats | JPEG, TIFF, PDF, Compact PDF, PDF (OCR) |
| Scan Features | Push Scan, Pull Scan, Scan to USB |
| Pull Scan | USB and Network |
| Push Scan (Scan to pC) | USB and Network |
Paper Handling Specifications
| Standard Paper Source(s) | 250-sheet cassette plus 50-sheet multipurpose tray6 |
| Optional Paper Source(s) | 550-sheet cassette6 |
| Document Feeder | 50-sheet duplex6 |
| Paper Output | 150 sheets (face down) |
| Paper Weight | 16-73 lb. bond (cassette/optional cassette/multipurpose tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
| Media Types | Plain / Heavy / Recycled / Color Paper, Label, Postcard, Envelope |
| Envelope Capacity | 5 envelopes (multipurpose tray) |
| Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
| Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11 b/g/n7, NFC (Near Field Communication)8 |
| WiFi Access Mode | Infrastructure Mode, WPS easy Setup, Wi-Fi® Direct Connection9 |
| WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP, AES), WPA2-PSK (AES), 802.1x (LEAP, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS) |
| WiFi Encryption Modes | WEP (64/128 bit), WPA-PSK (TKIP, AES), WPA2-PSK (AES) |
| WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
| Mobile Functions | Canon PRINT Business10, Apple® AirPrint®11, Mopria™ Print Service12, Google Cloud Print™13 |
| Network Functions | Print, Scan (SMB, E-mail, FTP), PC Fax |
| Embedded Web Server (Remote UI) | IE 7.0 or higher, Safari 3.2.1 or higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4, IPv6) |
| TCP/IP Set of Application Services | Bonjour (mDNS), HTTP, HTTPS, POP before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4, IPv6) |
| OS Compatibility | Windows® 10, 8.1, 8, 7, Windows Server® 2016, Windows Server® 2012, 2012 R2, 2008 R2, 2008, Windows Vista®, Mac OS 10.7.5 or later |
| Cable Included | Power Cord, Phone Cable (USB not included) |
| Bundled Software | Printer Driver, Fax Driver, Scanner Driver, Network Scan Utility, MF Scan Utility, AddressBook Tool, Toner Status |
Environmental Specifications
| Power Consumption | Approx: 520 W (during operation), 20.6 W (standby), Energy Saver Mode: .8 W (USB/wired/wireless) |
| Typical Energy Consumption | 1.1kWh |
General Specifications
| Dimensions | 18.5 inches (W) x 18.5 inches (D) x 18.1 inches (H) |
| Unit Weight (without/with cartridge) | 54 lbs. (w/o cartridge), 58.4 lbs. (w/cartridge) |
| Package Weight | Approx. 74.8 lbs. |
| Cartridge Type | Cartridge 046 (CMY yields 2,300 sheets / K yields 2,200 sheets, ISO/IEC standard) and Cartridge 046 Hi Capacity CMYK (CMY yields 5,000 sheets / K yields 6,300 sheets, ISO/IEC standard). Single Cartridge System *Yields based on ISO/IEC Standard |
| LCD Display | 5 Inch, Color Touch LCD |
| Duty Cycle | Up to 50,000 pages per month |
| Department ID Management | Up to 300 IDs |
| Security | IP / MAC Address Filtering, HTTPS, SNMPv3, IEEE802.1x |
| Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
| Warranty | 1 year limited exchange/carry-in warranty (Extended warranty available)14 |
| Other Features: Send Specifications Sending Method: SMB, E-mail, FTP, iFAX Simple Color Mode: Full Color, Monochrome Scan Resolution: 300 x 300 dpi, 200 x 200 dpi Recommended Monthly Print Volume: 750-4,000 pages Operating Temperature: 50-86°F Operating Humidity: 20-80% RH (no condensation) |
PRODUCT LIMITED WARRANTY
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
next to your download
