Canon Support for Color imageCLASS X MF1538C | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 08.31.21
File Size 3.99 MB
Date 09.16.24
File Size 1.32 MB
Date 01.30.23
File Size 2.16 MB
Date 08.31.21
File Size 3.12 MB
Date 12.19.23
File Size 1.85 MB
Date 01.30.23
File Size 2.26 MB
Date 12.19.23
File Size 4.07 MB
Date 09.16.24
File Size 1.85 MB
Date 04.26.23
File Size 1.72 MB
Date 12.19.23
File Size 1.32 MB
Date 01.30.23
File Size 1.63 MB
Date 03.21.22
File Size 11.75 MB
Date 09.11.25
File Size 1.32 MB
Date 03.02.26
File Size 1.85 MB
Date 03.02.26
File Size 1.33 MB
Date 03.02.26
File Size 1.86 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Products ChromeOS
MAIN UNIT
CORE FUNCTIONS
Standard: Print, Copy, Scan, Send, Fax
PROCESSOR
1 GHz Dual Core Processor
CONTROL PANEL
7" TFT LCD WVGA Color Touch Panel
MEMORY
2 GB
STANDARD INTERFACE CONNECTION
USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 650 Sheets
Maximum: 2,300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 550-sheet Paper Cassettes
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard: 200 Sheets
SUPPORTED MEDIA TYPES
Cassette: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Labels
Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Bond, Pre-punched, Envelope, PostCard
SUPPORTED MEDIA SIZES
Cassette: Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" x 5" to Max. 8.5" x 14")
Stack Bypass: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
Stack Bypass: 16 lb. Bond to 58 lb. Bond (60 to 216 g/m2)
WARM-UP TIME
From Power On: 12 Seconds or Less
From Sleep Mode: 10 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop): 19.7" x 21.9" x 25.2" (500 mm x 556 mm x 640 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 28.2" x 31" (717 mm x 785 mm)
Fully Configured: 32.1" x 34" (815 mm x 864 mm) (With two Paper Feeder PF-D1
and Cassette Feeding Unit-AV1)
WEIGHT4
Unit: Approx. 90.4 lb. (41 kg)
OPERATING SYSTEM
Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 /Mac OS X v10.10 (or later)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED (COLOR)5
Up to 40 ppm (Letter)
FIRST PRINT OUT TIME
Approx. 6 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
2,000 - 4,000 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, PCL®5, Adobe PostScript® 3TM
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1
Apple® AirPrint®, Canon PRINT Business, Mopria™ Print Service, Universal Print, uniFLOW Secure Mobile Printing6
FONTS
PCL: 93 Fonts
PS : 136 Fonts
PRINT FEATURES
Secure Print, Secure Watermark, Header/Footer, Page Layout, Two-sided Printing, Mixed Paper Sizes/ Orientations, Toner Reduction, Poster Printing, Forced Hold Printing, Print Date, Scheduled Printing, Printing Using a Virtual Printer
COPY SPECIFICATIONS
FIRST-COPY-OUT TIME (LETTER)
Approx. 5.9 Seconds/6.9 seconds or Less (BW/Color)
COPY RESOLUTION (dpi)
600 x 600
COPY SIZE
Platen: Up to Legal
ADF: Up to Legal
MULTIPLE COPIES
Up to 999 Copies
MAGNIFICATION
25% - 400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 70%
PRESET ENLARGEMENTS
141%, 200%, 400%
COPY FEATURES
Preset R/E Ratios by Area, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Two-sided Original, Sort, Job Build, N on 1, Sharpness, Erase Frame, Copy ID Card, Skip Blank Pages, Color Mode, Reserved Copy, Copy Sample
SCAN SPECIFICATIONS
TYPE
Single-Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY
100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Letter, Legal, Statement, Custom Size: 1.9" x 5" to 8.5" x 14"(48 mm x 128 mm to 216 mm x 355.6 mm)
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
15.5 lb. Cover to 47.3 lb. Cover (42 to 128 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book
PULL SCAN
Color Network ScanGear 2 for both TWAIN and WIA
SCAN RESOLUTION (dpi)
Up to 600 x 600
SCAN-TO-MOBILE DEVICES
SCAN SPEED (LETTER) (BW/COLOR)
Single-sided: 100/100 (300 dpi), 50/50 (600 dpi)
Double-sided: 155/150 (300 dpi), 50/50 (600 dpi)
MEMORY MEDIA
Standard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATION
E-mail/Internet FAX (SMTP), Super G3 FAX, SMB3.0, FTP, WebDAV
ADDRESS BOOK
LDAP (2,000)/Local (1,600)/Speed dial (200)
SEND RESOLUTION (dpi)
Push/Pull: Up to 600 x 600
COMMUNICATON PROTOCOL
File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
Email/iFax: SMTP (Send), POP3 (Receive)
FILE FORMAT
Standard: TIFF ,JPEG, PDF (Compact, Searchable, Encrypted), XPS (Compact, Searchable), PDF/XPS (Device Signature, Office Open XML (PowerPoint®, Word)
Optional: PDF (Trace & Smooth), PDF/XPS (User Signature)
FAX SPECIFICATIONS
MODEM SPEED
Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD
MH, MR, MMR, JBIG
RESOLUTION (dpi)
400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING/RECORDING SIZE
Statement to Legal
FAX MEMORY
Up to 30,000 Pages
SPEED DIALS
Max. 200
GROUP DIALS/DESTINATIONS
Max. 199 Dials
SEQUENTIAL BROADCAST
Max. 256 Addresses
MEMORY BACKUP
Yes
SECURITY SPECIFICATIONS
AUTHENTICATION AND ACCESS CONTROL
User Authentication (Picture Login, Picture and PIN Login, Username and Password Login, Function Level Login, Mobile Login), Department ID Authentication (Department ID and PIN Login, Function Level Login), uniFLOW Online Express (PIN Login, Picture Login, Picture and PIN Login, Card Login, Card and PIN Login, Username and Password Login, Department ID and PIN Login, Function Level Login), Access Management System (Access Control)
DOCUMENT
Print Security (Secure Print, Encrypted Secure Print, Forced Hold Printing, uniFLOW Secure Print6 ), Recieve Data Security (Confidential Fax Inbox Forwarding Received Documents Automatically), Scan Security (Encrypted PDF, Device Signature, User Signature PDF/XPS7), Send Data Security (Setting for requesting password input per transmission, Restricted E-mail/File send functions, Confirming FAX Number, Allow/Restrict Fax Driver Transmissions, Allow/Restrict Sending from History, S/MIME Support)
NETWORK
TLS 1.3, IPSec, IEEE802.1X authentication, SNMPv3, Firewall Functionality (IP/MAC Address Filtering), Dual Network Support (Wired LAN/Wireless LAN, Wired LAN/Wired LAN), Enabling/Disabling (Network Applications, Remote UI, USB Interface), G3 FAX separation from LAN, USB Port separation from LAN, Scan and Send -Virus Concerns for E-mail Reception
DEVICE
Standard Storage Initialize, Job Log Conceal Function, Verify System at Startup, Runtime Intrusion Detection
DEVICE MANAGEMENT AND AUDITING
Administrator Password, Digital Certificate and Key Management, Audit Log, Cooperating with External Security Audit System (Security Information and Event Management), Security Policy Setting
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F
Humidity: 20 to 80% RH (Relative Humidity)
POWER REQUIREMENTS
110-127V, 60Hz, 7.2A
POWER CONSUMPTION
Maximum: Approx. 1500 W
Standby: Approx. 33.9 W
Sleep Mode: Approx. 1.1 W
Typical Electricity Consumption (TEC) Rating:8 0.43 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver3
CONSUMABLES
TONER
Toner T10 Black  Yields 13,000 Pages
Toner T10 Cyan  Yields 10,000 Pages
Toner T10 Magenta  Yields 10,000 Pages
Toner T10 Yellow - Yields 10,000 Pages
CANON imageCLASS SERIES ON-SITE LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser (“Purchaser”) by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider (“Service Provider”) to, without charge, repair or replace any defective part with a new or comparable rebuilt part. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
Canon USA offers assistance for installation, operation and support* of the Product as follows:
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads at www.usa.canon.com/support (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
If Canon USA's remote assistance above cannot fix your Product's malfunction, Canon USA shall schedule an on-site service call via a Service Provider, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product.
If on-site service is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then current service rates of Canon USA or the Service Provider.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
This warranty shall be limited void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon USA who are acting in accordance with Canon USA's service bulletins, (d) use of supplies or parts (other than those distributed by Canon USA) which damage the Product or cause abnormally frequent service calls or service problems, or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this limited warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE CD- ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
CANON U.S.A., INC.
One Canon Park
Melville, NY 11747
Cartridge Warranty
** In Canada
CAUTION:
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
