Canon Support for DP-V1830 | Canon U.S.A., Inc.
DP-V1830
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
| Panel Type | TFT LCD |
| Screen Size | 18.4 inch |
| Aspect Ratio | 16:9 |
| Resolution | 3840 x 2160 UHD |
| Active Display Area | Approximately 409.0x 230.0 mm |
| Pixel Pitch | 106.5 m |
| Brightness* | Standard:100 cd/m2 Peak,Full screen, White : 1000 cd/m2 * Brightness values are standard values and not guaranteed values |
| Viewing Angle (Up, Down, Left, Right) | 89°(Contrast ratio: 101 or higher) |
| Surface Treatment | Anti-glare coating |
| Backlight Type | LED |
| Power | 100 to 240 VAC, 50/60 Hz 24 VDC, maximum 10 A, XLR |
| Power Consumption | At maximum AC load1: Approx. 210 W At maximum DC load*1: Approx. 185 W Factory default status*2: Approx. 105 W In Standby mode2: 0.5 W or less *1 Including changes in brightness over time *2 When using AC power supply |
| Operation Conditions | Temperature and humidity: 040 (32104 ),2085 RH (no condensation) Recommended range of temperature and humidity: 1530 (5986 ), 20 80 RH (no condensation) Pressure: 7001060 hPa |
| Storage/Transporting Conditions | Temperature and humidity:-2040 (-4104 ),2085 RH (no condensation) 4160 (105140 ), 2030 RH (no condensation) Pressure: 7001060 hPa |
| Dimensions (Width x Height x Depth) | Including stands and handle: Approx.443x 372 x 180 mm (17.4x 14.6 x 7.1 in.) Main unit only, excluding protrusions: Approx.443x 310 x 130 mm (17.4 x 12.2 x 5.1 in.) |
| Weight | Approx. 16.5 lbs |
| Mounting Hole Pitch | VESAstandard100x 100 mm (3.9x 3.9 in.) |
| 12G/6G/3G/HD/SD-SDI | 4 BNC (75 ) receptacle terminal 12G-SDI: Compliant with SMPTE 2082 6G-SDI: Compliant with SMPTE 2081 3G-SDI: Compliant with SMPTE 2048-2/274M/296/372/425-5/425-3/425-1/428-19/428-9 HD-SDI: Compliant with SMPTE 2048-2/274M/292-1/296/428-19/428-9 SD-SDI*1: Compliant with SMPTE 259M |
| HDMI | 1type A terminal Contents protection standard: HDCP 2.3/1.4 |
| 12G/6G/3G/HD-SDI | 4 BNC (75 ) receptacle terminal, pass-thru |
| MULTIFUNC. SDI OUT | 1 BNC (75 ) receptacle terminal |
| Headphone | 2 stereo mini jack (front panel/rear panel), supported impedance: 32 to 64 |
| Speaker | 2W(Stereo) |
CANON PROFESSIONAL DISPLAY LIMITED WARRANTY | ||||||||||||||
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Display Equipment ('the 'Equipment') accompanying this limited warranty in the Equipment's original container, when purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. This Limited Warranty covers all defects encountered in normal use of the Equipment and does not apply in the following cases:
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state. |
next to your download
