Canon Support for EOS 10D | Canon U.S.A., Inc.
EOS 10D
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type
Type | Digital, single-lens reflex, AF/AE camera with built-in flash |
Recording Media | Type I and II CF card |
Image Format | 22.7 mm x 15.1 mm |
Compatible Lenses | Canon EF lenses(35mm-equivalent focal length is equal to approx.1.6 times the marked focal length.) |
Lens Mount | Canon EF mount |
Image Sensor
Type | High-sensitivity, high-resolution, single-plate CMOS sensor |
Pixels | Approx. 6.30 megapixels (3088x2056) |
Total Pixels | Approx. 6.50 megapixels (3152x2068) |
Aspect Ratio | 3:2 |
Color Filter System | RGB primary color filter |
Low Pass Filter | Located in front of the image sensor, non-removable |
Recording System
Recording Format | JPEG (except when Adobe RGB is set) supporting Design rule for Camera File system and RAW |
Image Format | JPEG and RAW (12-bit) |
File Size | (1) Large/Fine: Approx. 2.4 MB (3072x2048 pixels)(2) Large/Normal: Approx. 1.2 MB (3072x2048 pixels)(3) Medium/Fine: Approx. 1.3 MB (2048x1360 pixels)(4) Medium/Normal: Approx. 0.7 MB (2048x1360 pixels)(5) Small/Fine: Approx. 0.8 MB (1536x1024 pixels)(6) Small/Normal: Approx. 0.4 MB (1536x1024 pixels(7) RAW (3072x2048 pixels)RAW + Small/Normal: Approx. 6.0 MBRAW + Small/Fine: Approx. 6.4 MBRAW + Medium/Normal: Approx. 6.2 MBRAW + Medium/Fine: Approx. 6.8 MBRAW + Large/Normal: Approx. 6.7 MBRAW + Large/Fine: Approx. 8.0 MB* Exact file sizes depend on the subject and ISO speed. |
File Numbering | Consecutive numbering, auto reset |
Color Space | sRGB, Adobe RGB Standard parameters plus up to three sets of custom processing parameters (4 items with 5 settings each) can be set. |
White Balance
Settings | Auto, daylight, shade, cloudy, tungsten light, fluorescent light, flash, manual, color temperature setting |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | White balance bracketing: +/-3 stops in whole-stop increments |
Viewfinder
Type | Eye-level pentaprism |
Coverage | 95% vertically and horizontally with respect to the effective pixels |
Magnification | 0.88x (-1 diopter with 50mm lens at infinity) |
Eye Point | 20 mm |
Dioptric Adjustment Correction | -3.0 - +1.0 diopter |
Focusing Screen | Fixed, New Laser Matte screen |
Mirror | Quick-return half mirror (Transmission:reflection ratio of 40:60, no mirror cut-off with EF 600mm f/4 or shorter lens) |
Viewfinder Information | AF (AF points, focus confirmation light), exposure (shutter speed, aperture value, manual exposure, AE lock, exposure compensation amount, AEB level, partial metering area), flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, flash exposure compensation amount), warnings (exposure warning, improper FE lock warning, CF card full warning, CF card error warning, no CF card warning, busy), maximum burst for continuous shooting, shots remaining Depth-of-field preview: Enabled with depth-of-field preview button |
Autofocus
Type | TTL-CT-SIR with a CMOS sensor (TTL secondary image-registration, phase detection) |
AF Points | 7 |
AF Working Range | EV 0.5-18 (at 20°C, ISO 100) |
Focusing Modes | One-Shot AF, AI Servo AF, AI Focus AF, Manual focusing (MF) |
AF Point Selection | Automatic selection, manual selection, home position |
Active AF Point Indicator | Superimposed in viewfinder and indicated on LCD panel |
AF Assist Beam | Stroboscopic flash |
Effective Range | Approx. 4.0 m/13.1 ft. at center, approx. 3.5m/11.5ft. off-center |
Exposure Control
Metering Range | EV 1-20 (at 20°C with 50mm f/1.4 lens, ISO 100) |
ISO Speed Range | Basic Zone modes: Automatic |
Exposure Compensation | AEB: +/-2 stops in 1/2- or 1/3-stop increments |
AE Lock | Auto: Applied when focus is achieved in the One Shot AF mode with evaluative metering Manual: Applied with AE lock button |
Shutter | Electronically-controlled focal-plane shutter180SpecificationsShutter speeds: 1/4000 - 30 sec. (1/2- or 1/3-stop increments), bulb, X-sync at 1/200 sec.Soft-touch electromagnetic release10-sec. delayN3-type remote control |
Type | Electronically-controlled focal-plane shutter180SpecificationsShutter speeds: 1/4000 - 30 sec. (1/2- or 1/3-stop increments), bulb, X-sync at 1/200 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay |
Remote Control | N3-type remote control |
Built in Flash
Type | Auto pop-up E-TTL autoflash (retractable) |
Guide Number | 13 (ISO 100, meters), 43 (ISO 100, ft.) |
Recycling Time | Approx. 3 sec. |
Flash Ready Indicator | Flash-ready icon lights in viewfinder |
Flash Coverage | 18mm lens angle covered |
Flash Exposure Compensation | +/-2 stops in 1/2- and 1/3-stop increments |
External Speedlite
EOS Dedicated Speedlite | E-TTL autoflash set with EX-series Speedlites |
PC Terminal | Provided |
Drive System
Drive Modes | Single frame, continuous, self-timer |
Continuous Shooting Speed | Approx. 3 fps (at 1/250 sec. or faster speeds) |
Maximum Burst | 9 shots |
LCD Monitor
Type | TFT color liquid-crystal monitor |
Monitor Size | 1.8 inches |
Pixels | Approx. 118,000 |
Coverage | Approx. 100% with respect to the effective pixels |
Brightness Control | 5 levels |
Playback
Display Format | Single image, single image (Info), magnified view (approx. 1.5x - 10x in 15 steps, consecutive magnified image viewing enabled), 9-image index, autoplay, image rotation, and jump |
Highlight Alert | In the single image and single image (Info) modes, any overexposed highlight areas with no image information will blink |
Image Protection and Erase
Protection | Single images can be protected or cancelled |
Erase | Single image or all images in the CF card can be erased (except protected images) |
Menus
Menu Categories | Shooting menu: Red Playback menu: Blue Setup menu: Yellow |
LCD Monitor Language | 12 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, and Japanese.) |
Firmware Update | Update possible by the user |
Power Source
Battery | One Battery Pack BP-511/BP-512 AC power can be supplied via the DC coupler. |
Battery Life | At 20°C / 68°F: 650 (No Flash), 500 (50% Flash Use),At 0°C / 32°F: 500 (No Flash), 400 (50% Flash Use). These figures apply when a fully-charged Battery Pack BP-511/BP-512 is used. |
Battery Check | Automatic |
Power Saving | Provided. Power turns off after 1, 2, 4, 8, 15, or 30 min. |
Back-up Battery | One CR2025 lithium battery |
Dimensions and Weight
Dimensions (W x H x D) | 149.7 x 107.5 x 75.0mm / 5.9 x 4.2 x 3.0 in |
Weight | 790 g/ 27.9 oz (body only) |
Operating Environment
Working Temperature Range | 0 - 40°C / 32 - 104°F |
Working Humidity Range | 85% or lower |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
