Canon Support for EOS-1D Mark IV | Canon U.S.A., Inc.
EOS-1D Mark IV
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.20.10
File Size 11.20 MB
Date 10.25.10
File Size 16.84 MB
Date 10.14.10
File Size 8.08 MB
Date 03.18.10
File Size 179.06 KB
Date 07.22.12
File Size 6.88 MB
Date 10.22.09
File Size 1.50 MB
Date 01.24.12
File Size 10.69 MB
Date 03.04.10
File Size 12.70 MB
Date 10.22.09
File Size 1.03 MB
Date 07.22.12
File Size 6.38 MB
Date 10.14.10
File Size 8.41 MB
Date 08.07.26
File Size 142.00 B
Date 08.07.26
File Size 142.00 B
Date 12.07.09
File Size 6.29 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
High-sensitivity, high-resolution, single-plate, CMOS sensor
Pixels
Approx. 16.10 Megapixels
Total Pixels
Approx. 17.00 Megapixels
Aspect Ratio
3:2 (Horizontal:Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the image sensor
Dust Deletion Feature
(1) Self Cleaning Sensor Unit
- Helps remove dust adhering to the low-pass filter.
- Automatic cleaning when power on and off, and manual cleaning.
- Low-pass filter has a fluorine coating.
(2) Dust Delete Data acquisition and appending
- The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images
- The dust coordinate data appended to the image is used by the provided software to automatically minimize the dust spots
(3) Manual cleaning
Recording Format
DCF 2.0 (Exif 2.21): JPEG, RAW and RAW+JPEG simultaneous recording possible. Multiple options for recording images on two memory cards, and onto compatible external USB hard drives (via optional Wireless File Transmitter WFT-E2/2A, E2 IIA*)
Image Format
JPEG, RAW, M-RAW, S-RAW (Canon .CR2) MOV
File Name
The file name can be set to one of three formats:
1. Factory-default, four-character alphanumeric name
2. Any four characters (User setting 1)
3. Any three characters plus the image size (User setting 2). If 3 is set and an M-RAW image is taken, the fourth character will be "M." The above three settings also apply to the file name for movies. If 3 is set, the forth character will be "_" (underscore).
File Size
JPEG
1) Large: Approx. 16.00 megapixels (4896 x 3264)
2) Medium 1: Approx. 12.40 megapixels (4320 x 2880)
3) Medium 2: Approx. 8.40 megapixels (3552 x 2368)
4) Small: Approx. 4.00 megapixels (2448 x 1632)LOSSLESS RAW
1) RAW: Approx. 16.00 megapixels (4896 x 3264)
2) M-RAW: Approx. 9.00 megapixels (3672 x 2448)
3) S-RAW: Approx. 4.00 megapixels (2448 x 1632)
Folders
Folder creation/selection enabled
Recording Functions
(1) Standard
- No automatic switching of recording media
(2) Automatic switching of recording media
- When the current recording media becomes full, it switches to another recording media automatically and continues recording
(3) Separate recording
- Set the desired image size (L, M1, M2, S, RAW, M-RAW, S-RAW) for each recording media before shooting
- The image size set for one captured image will be applied to all the recording media
(4) Recording of identical images
- The same image is recorded to all recording media. (Also possible with RAW+JPEG.)
- Movies cannot be recorded simultaneously to multiple recording media
- If simultaneous recording has been set, movies will be recorded to the recording media set with [Play] on the [Recording func+media/folder sel.] screen.
- If a still photo is taken during movie shooting and (3) or (4) has been set, the still photo will be recorded to each recording media in the image size that was set.
Backup Recording
Enabled
- With external recording media connected via WFT-E2 IIA* and WFT-E2/E2A (Firmware Ver. 2.0.0 or higher).
- Two options: 1. Quick backup (Backup folder created automatically and folder name set automatically.), 2. Backup (Backup folder created manually and folder name can be entered manually.)
- Images in the card are backed up in the external recording media's root directory based on the card's DCIM folder structure.
* This device has not been authorized as required by the rules of the Federal Communications Commission. This device is not, and may not be offered for sale or lease, or sold or leased, until authorization is obtained.
File Numbering
(1) Continuous numbering (2) Auto reset (3) Manual reset (the image numbering is reset to 0001, a new folder is created automatically)
Image Copy
Image copying between recording media enabled (images with checkmarks or all images in folder or card)
Color Space
sRGB, Adobe RGB
Picture Style
Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3
Auto White Balance
Auto white balance, taken from imaging sensor
Color Temperature Compensation
White balance bracketing: Three consecutive images, Up to +/- 3 levels in 1-stop increments White balance correction: blue/amber bias and/or magenta/green bias (Corrected in reference to the current WB mode's color temperature.) +/- 9 levels; manually set by user.
When blue/amber bias and magenta/green bias set with White balance correction, white balance bracketing cannot be set together during white balance correction
Color Temperature Information Transmission
Provided
Type
Eye-level SLR with fixed pentaprism
Coverage
Approx. 100% horizontally and vertically
Magnification
Approx. 0.76x (with 50mm lens at infinity, -1 m-1)
Angle of view: Approx. 28.3&deg;
Eye Point
20mm (at -1m-1, from eyepiece lens center)
Dioptric Adjustment Correction
Adjustable from -3.0 to +1.0 m-1 (dpt)
Mirror
Quick-return half mirror (Transmission: reflection ratio of 37:63)
Depth Of Field Preview
Enabled with depth-of-field preview button
Eyepiece Shutter
Built-in
Type
TTL-AREA-SIR AF-dedicated CMOS sensor
AF Points
Area AF with 45 AF points
- 8 mm (H) x 15 mm (W)
- All 45 AF points are horizontal-line sensitive at f/5.6 (vertical). Thirty-nine of the 45 AF points are vertical-line sensitive at f/2.8 for cross-type focusing. For automatic AF point selection, cross-type focusing with 19 AF points is used. (The 39 cross-type AF points are used only during manual AF point selection.)
- When using some f/4 lenses (including when using f/2.8 lens + Extender 1.4x), cross-type focusing with 39 AF point is possible.
AF Working Range
EV -1-18 (at 23&deg;C/73&deg;F with 50mm f/1.4 lens at ISO 100)
Focusing Modes
Autofocus
1) One-Shot AF
2) Predictive AI Servo AF
- The following can be set: C.Fn III -2: Focus-tracking sensitivity, C.Fn III -3:
Servo operation method and shutter-release timing, C.Fn III -4: Servo operation method in case a closer object enters the focus center during subject-tracking.
(2) Manual focus
AF Point Selection
1) The 45 AF points can be selected automatically or any one of them can be selected manually. To select an AF point, press the AF point selection button, then use the Multi-controller, Main Dial, or Quick Control Dial. With C.FN III -8-3, the 18 expanded AF points are instead used to search for the subject.
2) During manual AF point selection, the six AF points (or 26 AF points during automatic AF point selection) other than the 39 cross-type AF points will work as horizontal line-sensitive sensors at f/5.6. The two AF points at the immediate top and bottom of the center AF point have improved detection performance and precision due to the increase in the number of lines to two for the f/5.6 sensor. (The 39 cross-type AF points are used only during manual AF point selection.)
Selected AF Point Display
Superimposed in viewfinder and on LCD panel
AF Assist Beam
None
- When an external, EOS-dedicated Speedlite is attached to the camera, the AF-assist beam from the Speedlite will be emitted when necessary.
- Compatible with the 270EX's AF-assist beam (a series of small flashes)
Metering Modes
63-zone TTL full aperture metering
(1) Evaluative metering (linked to all AF points)
(2) Partial metering (approx. 13.5% of screen, at center)
(3) Spot metering (approx. 3.8% of screen, at center)
Center spot meteringAF point-linked spot metering Multi-spot metering (max. 8 spot metering entries)(4) Center-Weighted average metering
Metering Range
EV 0-20 (at 23&deg;C/73&deg;F with 50mm f/1.4 lens at ISO 100)
ISO Speed Range
Auto, ISO 100-12800 (1/3-stop or 1-stop increments: C.Fn I -2),Expandable
- ISO Auto set by default. With all C.Fn to their default setting, automatically set within ISO 100-12800.
- With C.Fn I -3 (ISO speed range), the highest and lowest settable ISO speed can be set. By setting L (ISO 50) for the lowest speed and H1 (ISO 25600), H2 (ISO 51200), H3 (ISO 102400) [TD] for the highest, ISO speed expansion is possible.
- In manual ISO setting, if the upper ISO speed limit is set to H1, H2, H3 [TD], and the lower ISO speed limit to L with C.Fn I-3, the settable ISO speed range will be ISO 100-12800.
- In ISO Auto, even if the upper ISO speed limit is set to H1, H2, H3 [TD], and the lower ISO speed limit to L with C.Fn I-3, ISO Auto speed range will be ISO 100-12800. However, if the lower and higher ISO speed limits have been set to a narrower range, ISO speed will be automatically set within that range.
- In P, Tv, Av modes and C.Fn I -8-2 (Tv/Av safety shift) is set, C.Fn I -3's ISO range limit will be canceled when the standard exposure cannot be obtained, even if C.Fn I-3 has set the lowest and highest settable ISO speed to a narrower range. It will be automatically controlled within the range of ISO100-12800.
- In ISO Auto and C.Fn I-8-1 (Tv/Av safety shift) is set, the C.Fn I-12's shutter speed range limit and C.Fn I-13's aperture range limit will be canceled when the standard exposure cannot be obtained. C.Fn I-3's upper and lower limits will be applied to control the ISO speed range. With C.Fn II-3 (Highlight tone priority) set, even if C.Fn I-3 has set the lower ISO speed limit to L and the upper ISO speed limit to H1, H2, H3, the ISO Auto range and manual ISO range will be ISO 200-12800. However, if the lower and higher ISO speed limits have been set to a narrower range with C.Fn I-3, the settable range will be ISO 200 to the higher speed limit set.
- When checking the ISO speed of still photos or movies shot at H3 (ISO 102400) in commercially available software, the correct ISO speed value may not be displayed (the EXIF information standard cannot record ISO 102400 settings).
- When imprinting the shooting information for images shot at H2, H3 ISO speeds during ISO speed range expansion, the ISO speed setting may not be correctly printed.
Exposure Compensation
Exposure Compensation (user-set): +/-3 stops in 1/3- or 1/2-stop increments.
Auto Bracketing (AEB): 3 shots, up to +/- 3 stops, in 1/3 or 1/2 stop increments, in all exposure modes. Can be changed via C.Fn I-6 to 2, 5, or 7 shots. Bracketing order can be changed via C.Fn I-5.
*Except during movie Manual exposure.
AE Lock
Auto: Applied in One-Shot AF mode with Evaluative metering when focus is achieved
Manual (user-set): By AE lock button in all metering modes
Shutter
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/8000 to 30 sec. (1/3-, 1/2-, or 1-stop increments: C.Fn I -1), X-sync at 1/300 sec.
- The shutter speed range can be limited with C.Fn I -12 and the aperture range limited with C.Fn I -13Soft-touch electromagnetic release10-sec. delay, 2-sec. delay Canon N3-type terminal
Type
Shutter Speeds
Shutter Release
Self Timer
Remote Control
EOS Dedicated Speedlite
E-TTL II autoflash with all EX Series Speedlites
Zooming to Match Focal Length
Provided
Flash Metering
E-TTL II autoflash
Flash Exposure Compensation
&plusmn;3 stops in 1/3- or 1/2-stop increments
FE Lock
Provided
External Flash Settings
Flash function settings, Flash C.Fn settings / Clear all Speedlite C.Fn's
PC Terminal
Provided; accepts third-party flash units with sync line voltages up to 250V maximum
Drive Modes
Single, silent, high-speed continuous (approx. 10 fps), low-speed continuous (approx. 3 fps), 10- or 2-sec. self-timer
Continuous Shooting Speed
Approx. 10 fps (at a shutter speed of 1/500 sec. or faster in all recording modes); fastest speed can be lowered if desired via Custom Function III-16
Maximum Burst
The maximum burst during continuous shooting is as follows:
JPEG Large (Compression rate 8): Approx. 85 shots, RAW: Approx. 26 shots,RAW+JPEG Large (Compression rate 8): Approx. 20 shots
Although the file size is larger than the EOS-1D Mark III due to the increase in pixels, the improved internal processing enables stress-free continuous shooting.
Shooting Modes
(1) Remote Live View shooting (with a personal computer installed with EOS Utility)
(2) Live View shooting
Focusing
1) Manual focus
2) Autofocus (One-Shot AF)
- AF enabled by pressing the shutter button halfway or pressing the AF-ON button.
1. Live mode
- One point, contrast AF. Switching to another AF point possible.
2. (Face detection) Live mode
- Face detection, Contrast AF. When multiple faces are detected, face selection is possible with the multi-controller.
- Magnified view not possible.
3. Quick mode
- 45-point, phase-difference AF (Same as viewfinder shooting), One-shot AF.
- Manual AF point selection enabled.
Metering Modes
Evaluative metering with the image sensor
Metering Range
EV 0-20 (at 23&deg;C/73&deg;F with EF 50mm f/1.4 USM lens, ISO 100)
Magnified View
Magnifiable by 5x or 10x at AF point
Grid Display
Provided
Exposure Simulation
Provided
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0 in.
Pixels
Approx. 920,000 dots (VGA)
Coverage
Approx. 100%
Brightness Control
Adjustable to one of seven brightness levels
- During playback, illumination adjustable by pressing the illumination button.
Display Format
Single image, 4-image index, 9-image index, Jump, Magnified zoom (approx. 1.5x to 10x), Histogram, Auto rotate, Rotate
Live view: view image before shooting on LCD monitor; live histogram and live simulation of exposure level possible with C.Fn IV-16-1
Protection
Single image, all images in a folder, or all images in the memory card can be protected or cancel the image protection
Erase
Single image, all images in a folder, all images in the memory card or check-marked images can be erased or unprotected
Compatible Printers
PictBridge-compatible printers
Printable Images
RAW/M-RAW/S-RAW and JPEG images complying to Design rule for Camera File System
- Regarding RAW/M-RAW/S-RAW images, only those captured by the EOS-1D Mark IV can be printed.
- Movies cannot be printed.
DPOF
Version 1.1 compatible
Custom Functions
A total of 62 Custom Functions from C.Fn I to IV can be set with the camera
My Menu Registration
Provided
Save Camera Settings
Provided
Register Basic Camera Settings
Provided
C.Fn Registration Settings
Provided
Recording Time
Max. 30 sec. per sound clip/voice memo
Menu Categories
(1) Shooting (2) Playback (3) Setup, (4) Custom function/My Menu
LCD Monitor Language
25: English, German, French, Dutch, Danish, Portuguese, Finnish, Italian,Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech,Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean and Japanese
Battery
Battery Pack LP-E4 x 1
* With the AC Adapter Kit ACK-E4, AC power is possible.
Battery Life
Viewfinder Shooting
- At 73&deg;F/23&deg;C: Approx. 1500
- At 32&deg;F/0&deg;C: Approx. 1200
Live View Shooting
- At 73&deg;F/23&deg;C: Approx. 270
- At 32&deg;F/0&deg;C: Approx. 230
* Based on a fully-charged LP-E4 and CIPA (Camera & Imaging Products Association) testing standards.
Battery Check
Automatic battery check when the power switch is turned ON Displayed in one of six levels
* Displayed on LCD panel, in the viewfinder, and battery information screen.
Power Saving
Provided. Power turns off after 1, 2, 4, 8, 15, 30 min.
Date/Time Battery
One CR2025 lithium battery x 1
Start-up Time
Approx. 0.1 sec. (Based on CIPA testing standards)
* Approx. 0.2 sec. based on previous specification standard.
Dimensions (W x H x D)
6.1 x 6.2 x 3.1 in./156 x 156.6 x 79.9mm
Weight
Approx. 1180 g / 41.6 oz.
Working Temperature Range
32-113&deg;F/0-45&deg;C
Working Humidity Range
85% or less
Type
For LP-E4
Rechargeable lithium ion battery
Rated Voltage
11.1 V DC
Battery Capacity
2300mHh
68.4 x 34.2 x 92.8mm/2.7 x 1.3 x 3.7 in.
Weight
180g/6.3 oz. (excluding protective cover)
Type
For LC-E4
Charger dedicated to the Battery Pack LP-E4
Recharging Time
Approx. 120 min. (for 1 pack)
Rated Input
100-240 V AC (50/60 Hz)
12 V/24 V DC
Rated Output
12.6 V DC, 1.55 A
0&deg;C-40&deg;C/32&deg;F - 104&deg;F
85% or less
155 x 52.3 x 95mm/6.1 x 2.1 x 3.7 in.
Weight
340g/12.0 oz. (excluding power cord and protective covers)
Type
For ACK-E4
* Car Battery Cable CB-570 connectable.
Rated Input
12.6 V DC
Rated Output
11.1 V DC
Cord Length
Approx. 2.3 m/7.5 ft.
Working Temperature
0&deg;C-45&deg;C/32&deg;F-113&deg;F
Working Humidity
85% or less
Weight (Approx.)
165g/5.8 oz. (excluding protective cover)
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Wireless File Transmitter WFT-E2IIA: Firmware Update Version 1.0.4
Advisory Type
Date 08.21.11
Title Canon Support | Service Notice: EOS-1D Mark IV: Firmware Update Version 1.1.0
Advisory Type
Date 05.29.11
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Firmware Notice: EOS-1D Mark IV: Firmware Version 1.1.5
Advisory Type
Date 11.27.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
