Canon Support for EOS-1D | Canon U.S.A., Inc.
EOS-1D
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 06.10.08
File Size 5.33 MB
Date 04.16.09
File Size 6.96 MB
Date 10.15.10
File Size 8.08 MB
Date 06.10.08
File Size 10.99 MB
Date 07.23.12
File Size 6.38 MB
Date 01.25.12
File Size 10.69 MB
Date 10.15.10
File Size 8.41 MB
Date 10.01.07
File Size 11.53 MB
Date 07.23.12
File Size 6.88 MB
Date 04.14.09
File Size 7.50 MB
Date 10.21.10
File Size 11.20 MB
Date 03.05.10
File Size 12.70 MB
Date 04.01.07
File Size 6.47 MB
Date 06.10.08
File Size 4.94 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Type Digital AF SLR (CCD sensor/Direct imaging)
Recording Media Type I and II CF card
Image Format 28.7 x 19.1 mm
Compatible Lenses Canon EF lenses
Lens Mount Canon EF lens mount
Image Sensor
Type High-sensitivity, high-resolution, large-area single-plate CCD sensor
Pixels Effective pixels: Approx. 4.15 megapixels (2496 x 1665)
Aspect Ratio 2:3
Color Filter System RGB primary colors
Low Pass Filter Located in front of the CCD sensor, fixed
Recording System
Recording Format Design rule for Camera File system
Image Format JPEG and RAW, 36-bit true color (12 bits/RGB color), RAW + JPEG simultaneous recording
File Size (1) Large/Fine: approx. 2.4 MB (2464 x 1648 pixels)(2) Large/Normal: approx. 1.3 MB (2464 x 1648 pixels)(3) Small/Fine: approx. 1.1 MB (2464 x 1648 pixels)(4) RAW: approx. 4.8 MB (2496 x 1662 pixels)* Exact file sizes depend on the subject and ISO speed.
Folders Folder creation and selection possible
File Numbering Consecutive numbering, Auto reset, Manual reset
Interface IEEE 1394 (with dedicated cable)
White Balance
Settings 10 Settings: Auto, daylight, shade, overcast, tungsten light, fluorescent light, flash, custom, manual color temperature setting, personal white balance
Auto White Balance Hybrid auto balance with the CCD sensor and a dedicated, external sensor
Color Temperature Compensation White balance bracketing: +/- 3 steps in whole step increments (1 step = 5 mireds)
Viewfinder
Type Glass pentaprism, eye-level type with eyesight correction
Coverage 100% vertically and horizontally with respect the effective pixels
Magnification 0.72x (-1 diopter with 50mm at infinity)
Eye Point 20mm
Dioptric Adjustment Correction -3.0 - +1.0 diopter
Focusing Screen Interchangeable (9 types)Standard focusing screen: Ec-CIII
Mirror Quick-return half mirror (Transmission: reflection ratio of 63:37, no mirror cut off with EF 1200mm f/5.6 or shorter lens)
Viewfinder Information AF information (AF points, focus confirmation light), exposure information (shutter, speed, aperture, manual exposure, metering range, ISO speed, exposure level, exposure warning), flash information (flash ready, FP flash, FE lock, flash exposure level), JPEG format, number of remaining shots,CF card information
Depth Of Field Preview Enabled with depth-of-field preview button
Eyepiece Shutter Built-in
Autofocus
Type TTL-AREA-SIR with CMOS sensor
AF Frame 45-point Area AF (W x H: 15mm x 8mm)
AF Working Range EV 0-18 (at ISO 100)
Focusing Modes One-Shot AF, AI Servo AF, Manual focusing (MF)
AF Point Selection Automatic selection, manual selection, home position (switch to registered AF point)
Selected AF Point Display Superimposed in viewfinder and indicated on top LCD panel
AF Assist Beam Emitted by the dedicated Speedlite's built-in AF-assist beam
Exposure Control
Metering Modes TTL full aperture metering with 21-zone SPC
(1) Evaluative metering (linkable to any AF point)(2) Partial metering (approx. 13.5% of viewfinder at center)(3) Spot metering a. Center spot metering (approx. 3.8% of viewfinder at center) b. AF point-linked spot metering (approx. 3.8% of viewfinder at center) c. Multi-spot metering (Max. 8 spot metering entries)(4) Center weighted average metering
Metering Range EV 0-20 (at 20 &deg;C/68 &deg;F with 50mm f/1.4 lens, ISO 100)
ISO Speed Range Equivalent to ISO 200-1600 (in 1/3 stop increments), ISO speed can be expanded to ISO 100 and 3200
Exposure Compensation Auto exposure bracketing (AEB): +/- 3 stops in 1/3 stop increments
AE Lock Auto: Operates in One-shot AF mode with evaluative metering when focus is achieved Manual: By AE lock button in all metering modes
Shutter Electronic shutter with the CCD sensor and vertical-travel, local-plane shutter with all speeds electronically-controlled1/16,000 to 30 sec. (1/3 stop increments), bulb, X-synch at 1/500th sec.Soft-touch electromagnetic release10-sec. or 20-sec. delayRemote switch N3-type terminal provided
Type Electronic shutter with the CCD sensor and vertical-travel, local-plane shutter with all speeds electronically-controlled
Shutter Speeds 1/16,000 to 30 sec. (1/3 stop increments), bulb, X-synch at 1/500th sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. or 20-sec. delay
Remote Control Remote switch N3-type terminal provided
External Speedlite
EOS Dedicated Speedlite Speedlite EX series E-TTL autoflash
PC Terminal Provided; operates regardless of sync polarity
Drive System
Drive Modes Single-frame, low-speed continuous, high-speed continuous
Continuous Shooting Speed Low-speed continuous: 3 fps. High-speed continuous: 8 fps
Maximum Burst 21 shots in Large/Fine, Large/Normal, Small/Fine modes16 shots in RAW, RAW+Large/Fine, RAW+Large/Normal,RAW+Small/Fine modes*Maximum shots per burst depends on the subject shooting mode, and ISO speed.
LCD Monitor
Type TFT color LCD monitor
Monitor Size 2.0 inches
Pixels Approx. 120,000
Coverage Approx. 100% with respect to the effective pixels
Brightness Control Adjustable to one of five levels
Playback
Display Format (1)Single image with information(2) Single image(3) 4-image index(4) 9-image index
Highlight Alert In display formats (1) and (2) above, any overexposed highlight areas will blink in the image display
AF Point Display Displayed in the single image with information display format
Image Protection and Erase
Protection Erase protection of one image, all images in folder, or all images in the CF card can be applied or cancelled at one time.
Erase One image, all images in folder, or all images in the CF card can be erased (except protected images) at one time
Sound Recording
Recording Methods The voice narration recorded with the built-in microphone is attached to the image
File Format WAV
Recording Time Max. 30 sec. per recording
Menus
Menu Categories (1) Shooting menu(2) Image reviewing menu(3) Setup menu(4) Custom/Personal functions
LCD Monitor Language Japanese, English, French, German, Spanish
Firmware Update Update possible by the user
Power Source
Battery One Ni-MH Pack NP-E3*AC power can be supplied via the AC adapter and DC coupler
Number of Shots At 20&deg;C/68&deg;F: approx. 500. At 0&deg;C/32&deg;F: approx. 350 When a fully-charged Ni-MH Pack NP-E3 battery and EF 50mm f/1.4 USM lens are used; the photo image confirmation function is "on"; the confirmation display time is 2 sec.; and the file format is RAW + Large/Fine)
Battery Check Automatic
Power Saving Provided, Power turn off after 1, 2, 4, 8, 15, or 30 min.
Back-up Battery One CR2025 lithium battery
Dimensions and Weight
Dimensions (W x H x D) 156 x 157.6 x 79.9 mm/6.1 x 6.2 x 3.1 in.
Weight 1250 g/44.1 oz. (Body only. Battery: 335 g/11.8 oz.)
Operating Environment
Working Temperature Range 0 - 45&deg;C/32 - 113&deg;F
Working Humidity Range 85% or lower
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Safety Notice: Lithium-Ion Battery Pack
Advisory Type
Date 12.31.08
Title Canon Support | Service Notice: TIFF Image Loss with Microsoft Windows Vista
Advisory Type
Date 02.21.07
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Service Notice: Mistaken Origin Displayed on Packaging of Optional Interface Cables
Advisory Type
Date 02.19.08
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
