Canon Support for EOS 30D | Canon U.S.A., Inc.
EOS 30D
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type
| Type | Digital AF/AE SLR |
| Recording Media | CompactFlash (CF) Card Type I & II |
| Image Format | 0.89 x 0.59 in./22.5 x 15.0mm (APS-C size sensor) |
| Compatible Lenses | Canon EF lenses (including EF-S lenses) |
| Lens Mount | Canon EF mount |
Image Sensor
| Type | High-sensitivity, high-resolution, single-plate, CMOS sensor |
| Pixels | Approx. 8.20 megapixels |
| Total Pixels | Approx. 8.50 megapixels |
| Aspect Ratio | 3:2 (Horizontal : Vertical) |
| Color Filter System | RGB primary color filters |
| Low Pass Filter | Fixed position in front of the CMOS sensor |
Recording System
| Recording Format | JPEG, RAW and RAW+JPEG simultaneous recording provided. The RAW and JPEG images are saved as separate files in the CF card. |
| Image Format | JPEG, RAW, Canon .CR2 |
| File Size | (1) Large/Fine: Approx. 3.6MB (3,504 x 2,336) (2) Large/Normal: Approx. 1.8MB (3,504 x 2,336) (3) Medium/Fine: Approx. 2.2MB (2,544 x 1,696) (4) Medium/Normal: Approx. 1.1MB (2,544 x 1,696) (5) Small/Fine: Approx. 1.2MB (1,728 x 1,152) (6) Small/Normal: Approx. 0.6MB (1,728 x 1,152) (7) RAW: Approx. 8.7MB (3,504 x 2,336) |
| Folders | Automatic folder creation/selection; up to 9,999 images per folder (new folder can be created with Manual reset option at any time) |
| File Numbering | (1) Continuous numbering (2) Auto reset (3) Manual reset (new folder created, with file numbering reverting to 0001) |
| Color Space | Selectable between sRGB and Adobe RGB |
| Interface | USB 2.0 Hi-Speed, NTSC/PAL for video output |
White Balance
| Settings | Auto, Preset (Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash), Manual (Custom, or user-set Color Temperature) |
| Auto White Balance | Auto white balance with the image sensor |
| Color Temperature Compensation | White balance bracketing: +/- 3 stops in 1-stop increments White balance correction: blue/amber bias +/- 9 magenta/green bias +/- 9 levels When blue/amber bias and magenta/green bias set with White balance correction, white balance bracketing cannot be set to more than +/- 9 levels |
Viewfinder
| Type | Eye-level SLR with fixed pentaprism |
| Coverage | Approx. 95% horizontally and vertically (coverage against JPEG Large) |
| Magnification | 0.9x (-1 dpt with 50mm lens at infinity) |
| Eye Point | Approx. 20mm |
| Dioptric Adjustment Correction | -3.0 to +1.0 diopter |
| Focusing Screen | Fixed, Precision Matte screen (non-interchangeable) |
| Mirror | Quick-return half mirror (Transmission: reflection ratio of 40:60, no mirror cut-off with lenses up to EF 600mm f/4L USM) |
| Viewfinder Information | AF (AF points, focus confirmation light), Exposure (shutter speed, aperture, spot metering circle, exposure level, AE lock, exposure compensation, AEB level, bulb, ISO speed), Flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, FEB shooting, flash exposure compensation, insufficient flash warning during FE lock), White balance correction, Maximum burst, CF card full warning, CF card error warning, No CF card warning |
| Depth Of Field Preview | Enabled with depth-of-field preview button (with Speedlite 580EX, 430EX, MR-14EX or MT-24EX; pressing the depth-of-field preview button fires a modeling flash) |
| Eyepiece Shutter | None (eyepiece cover provided on strap) |
Autofocus
| Type | TTL-CT-SIR AF-dedicated CMOS sensor |
| AF Points | 9 AF points |
| AF Working Range | EV -0.5-18 (ISO 100 at 68°F/20°C) |
| Focusing Modes | Autofocus: One-Shot AF, Predictive AI Servo AF, AI Focus AF (automatic switching between One-Shot/Predictive AI Servo AF); Manual Focus (MF) |
| AF Point Selection | Automatic selection, Manual selection |
| Selected AF Point Display | Superimposed on viewfinder and LCD panel |
| AF Assist Beam | Intermittent firing of built-in flash (must be manually raised in P, Tv, Av, M and A-DEP Exposure modes) |
Exposure Control
| Metering Modes | Max. aperture TTL metering with 35-zone SPC (1) Evaluative metering (linked to all AF points) (2) Partial metering (approx. 9% at center of viewfinder) (3) Spot metering (approx. 3.5% at center of viewfinder)( 4) Center-weighted average metering |
| Metering Range | EV 1-20 (ISO 100 at 68°F/20°C with EF 50mm f/1.4 USM lens) |
| ISO Speed Range | Basic Zone: automatically set by the camera; Creative Zone: equivalent to ISO 100-1,600 (in 1/3-stop increments, ISO speed can be expanded to ISO 100-3,200) |
| Exposure Compensation | (1) User-set with multi-controller (2) AEB (Auto Exposure Bracketing) Bracketing range: +/- 2 stops in 1/3- or 1/2-stop increments |
| AE Lock | Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved User-set: Applied with AE lock button |
| Shutter | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/8000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/250 sec. Shutter durability: Approx. 100,000 exposuresSoft-touch electromagnetic release; shutter "lag time" approx. 65 msec.10 sec. delay, 2 sec. delay with C.Fn-12-1 (mirror lockup)Remote control with N3-type terminal |
| Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled |
| Shutter Speeds | 1/8000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/250 sec. Shutter durability: Approx. 100,000 exposures |
| Shutter Release | Soft-touch electromagnetic release; shutter "lag time" approx. 65 msec. |
| Self Timer | 10 sec. delay, 2 sec. delay with C.Fn-12-1 (mirror lockup) |
| Remote Control | Remote control with N3-type terminal |
Built in Flash
| Type | Auto pop-up, retractable, built-in flash in the pentaprism |
| Guide Number | 43 ft./13m (ISO 100) |
| Recycling Time | Approx. 3 sec. |
| Flash Ready Indicator | Flash-ready indicator lights in viewfinder |
| Flash Coverage | 17mm lens focal length (equivalent to 27mm in 35mm format) |
| Flash Exposure Compensation | +/-2 stops in 1/3- and 1/2-stop increments |
External Speedlite
| EOS Dedicated Speedlite | E-TTL II autoflash with EX Series Speedlites |
| PC Terminal | Provided; not sensitive to flash polarity |
Drive System
| Drive Modes | Single, Continuous (high-speed approx. 5 fps / low-speed approx. 3 fps), Self-timer |
| Continuous Shooting Speed | High-speed approx. 5 fps / low-speed approx. 3 fps (at a shutter speed of 1/250 sec. or faster) |
| Maximum Burst | JPEG: high-speed approx. 30 frames (Large/Fine) RAW: high-/low-speed approx. 11 frames RAW+JPEG: high-/low-speed approx. 9 frames |
LCD Monitor
| Type | TFT color, liquid-crystal monitor |
| Monitor Size | 2.5 in. diagonal with a viewing angle of approx. 170° vertically and horizontally |
| Pixels | Approx. 230,000 pixels |
| Coverage | 100% |
| Brightness Control | 5 levels provided |
Playback
| Display Format | Single image, 9-image index, Magnified zoom (approx. 1.5x to 10x), Auto play, Auto play right after shooting |
| Highlight Alert | In the single image (INFO) display mode, the areas with highlights containing no image information will blink |
Image Protection and Erase
| Protection | A single image can be protected or unprotected |
| Erase | A single image or all images stored in a CF card can be erased if they are unprotected |
Menus
| Menu Categories | Shooting menu: red Playback menu: blue Setup menu: yellow |
| LCD Monitor Language | 15 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Russian, Simplified Chinese, Traditional Chinese, Korean, Japanese) |
| Firmware Update | Enabled by the user (in Creative Zone only) |
Power Source
| Battery | One Lithium-Ion Battery Pack BP-511A/BP-514/BP-511/BP-512 |
| Number of Shots | Approx. 1,100 (68°F/20°C, flash off), approx. 900 (32°F/0°C, flash off) The above figures comply with CIPA testing standards and apply when a fully-charged Battery Pack BP-511A is used. |
| Battery Check | Automatic |
| Power Saving | Provided; power turns off after set time of 1, 2, 4, 8, 15 or 30 min. |
| Back-up Battery | One CR2016 Lithium Battery |
Dimensions and Weight
| Dimensions (W x H x D) | 5.7 x 4.2 x 2.9 in./144 x 105.5 x 73.5mm |
| Weight | 24.7 oz./700g (body only) |
Operating Environment
| Working Temperature Range | 32-104°F/0-40°C |
| Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
