Canon Support for EOS 5D Mark II | Canon U.S.A., Inc.
EOS 5D Mark II
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | High-sensitivity, high-resolution, large single-plate CMOS sensor |
Pixels | Effective pixels: Approx. 21.1 megapixels |
Total Pixels | Total pixels: Approx. 22.0 megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the CMOS sensor |
Dust Deletion Feature | (1) Automatic sensor cleaning (2) Manual cleaning of sensor (3) Dust Delete Data appended to the captured image |
Recording Format | Design rule for Camera File System 2.0 |
Image Format | Still: JPEG, RAW (14-bit, Canon original), sRAW1, sRAW2, RAW+JPEG Video: MOV |
File Size | (1) Large/Fine: Approx. 6.1MB (5616 x 3744 pixels) (2) Large/Nomal: Approx. 3.0MB (5616 x 3744 pixels) (3) Medium/Fine: Approx. 3.6MB (4080 x 2720 pixels) (4) Medium/Normal: Approx. 1.9MB (4080 x 2720 pixels) (5) Small/Fine: Approx. 2.1MB (2784 x 1856 pixels) (6) Small/Normal: Approx. 1.0MB (2784 x 1856 pixels) (7) RAW: Approx. 25.8MB (5616 x 3744 pixels) (8) sRAW 1: Approx. 14.8MB (3861 x 2574 pixels) (9) sRAW 2: Approx. 10.8MB (2784 x 1856 pixels) Exact file sizes depend on the subject, ISO speed, Picture Style, etc. |
Recording Functions | With the WFT-E4A attached, image recording to the CF card and to the USB external media connected to the WFT-E4A will be possible as follows: (1) Standard (2) Automatic switching of recording media (3) Separate recordings according to image-recording quality (4) Recording images having the same size |
Backup Recording | Enabled with WFT-E4A attached |
File Numbering | Consecutive numbering, auto reset, manual reset. Possible to create new folders and select folders in the CF card |
RAW + JPEG Simultaneous Recording | Provided (RAW/sRAW+JPEG also possible) |
Color Space | sRGB, Adobe RGB |
Picture Style | Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3 |
Settings | Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom, Color Temperature setting |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | White balance correction: ±9 stops in full-stop increments White balance bracketing: ±3 stops in full-stop increments Blue/amber direction or magenta/green direction possible |
Color Temperature Information Transmission | Provided |
Type | Eye-level pentaprism |
Coverage | Vertical/Horizontal approx. 98% |
Magnification | Approx. 0.71x (-1m-1 with 50mm lens at infinity) |
Eye Point | Approx. 21mm (from eyepiece lens center) |
Dioptric Adjustment Correction | -3.0 to +1.0m-1 (diopter) |
Focusing Screen | Interchangeable (Eg-D: Grid lines, Eg-S [point of Focus], Eg-A standard focusing screen provided |
Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60, no mirror cutoff with EF600mm f/4L IS USM or shorter lenses) |
Viewfinder Information | AF information (AF points, focus confirmation light), Exposure information(shutter speed, aperture, ISO speed, AE lock, exposure level, spot metering circle), Flash information (flash ready, flash exposure compensation, High-speed sync, FE lock), Image information (Highlight tone priority, monochrome shooting, maximum burst, white balance correction, CF card information),battery information |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Type | TTL-CT-SIR AF-dedicated CMOS sensor |
AF Points | 9 AF Points (1 Cross Type) + 6 AF Assist Points |
AF Working Range | EV -0.5-18 (at 73°F/23°C, ISO 100) |
Focusing Modes | Auto, One-Shot AF, Predictive AI Servo AF, AI Focus AF, Manual focusing (MF) |
AF Point Selection | Automatic selection, manual selection |
Selected AF Point Display | Superimposed in viewfinder and indicated on LCD panel |
AF Assist Beam | When an external EOS-dedicated Speedlite is attached to the camera, the AF-assist beam from the Speedlite will be emitted when necessary. |
Metering Modes | 35-zone TTL full-aperture metering Evaluative metering (linkable to any AF point)Partial metering (approx. 8% of viewfinder at center)Spot metering (approx. 3.5% of viewfinder at center)Center-weighted average metering |
Metering Range | EV 1-20 (at 73°F/23°C with EF50mm f/1.4 USM lens, ISO 100) |
ISO Speed Range | ISO 100-6400 (in 1/3-stop or 1-stop increments) ISO 100-3200 set automatically Extension settable (with C.Fn.I-3-1): ISO 50 (L), 12800 (H1), 25600 (H2) High Tone Priority settable: ISO 200-6400 |
Exposure Compensation | Manual: ±2 stops in 1/3- or 1/2-stop increments (can be combined with AEB) |
AE Lock | Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved Manual: By AE lock button |
Shutter | Vertical-travel, mechanical, Electronically-controlled, focal-plane shutter1/8000 to 1/60 sec., X-sync at 1/200 sec. 1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode)Soft-touch electromagnetic release10-sec. or 2-sec. delayRemote control with N3-type terminal. (Wireless remote controller RC-1/RC-5 can also be used.) |
Type | Vertical-travel, mechanical, Electronically-controlled, focal-plane shutter |
Shutter Speeds | 1/8000 to 1/60 sec., X-sync at 1/200 sec. 1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode) |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay |
Remote Control | Remote control with N3-type terminal. (Wireless remote controller RC-1/RC-5 can also be used.) |
Zooming to Match Focal Length | Provided |
Flash Metering | E-TTL II autoflash |
Flash Exposure Compensation | ±2 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings | Flash function settings, Flash C.Fn settings |
Drive Modes | Single, Continuous, and Self-timer (10-sec. or 2-sec. delay) |
Continuous Shooting Speed | Max. 3.9 shots/sec. |
Maximum Burst | JPEG (Large/Fine): approx. 78 (CF)/approx. 310 (UDMA CF) RAW: approx. 13/approx. 14 (UDMA CF) RAW+JPEG (Large/Fine): approx. 8 (CF/UDMA CF) Based on Canon's testing standards with a 2GB CF card, continuous shooting, ISO 100 and Standard Picture Style Varies depending on the subject, CF card brand, image-recording quality,ISO speed, drive mode, Picture Style, etc. |
Shooting Modes | Still photo shooting and video shooting |
Focusing | Quick mode (Phase-difference detection) Live mode/Face Detection Live mode (Contrast detection) Manual focusing (5x/10x magnification possible) |
Metering Modes | Evaluative metering with the image sensor (still photos) Center-weighted average metering (video) |
Metering Range | EV 0-20 (at 73°F/23°C with EF 50mm f/1.4 USM lens, ISO 100) |
Grid Display | Provided (Two-type grid displays) |
Exposure Simulation | Provided |
Silent Shooting | Provided (Mode 1 and 2) |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0 in. |
Pixels | Approx. 920,000 (VGA) |
Coverage | Approx. 100% (viewing angle: approx. 170°) |
Brightness Control | Auto, 7 levels provided |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian,Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese,Korean, Japanese) |
Display Format | Single image, Single image + Image-recording quality/shooting information,histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image (auto/manual), image jump (by 10/100 images, index screen, by shooting date, by folder), slide show (all images/selected by date/folder) |
Highlight Alert | Provided (Overexposed highlights blink) |
Protection | Single images can be erase-protected or not |
Erase | Single image, check-marked images or all images in the CF card can be erased (except protected images) |
Compatible Printers | PictBridge-compatible printers |
Printable Images | JPEG images compliant to Design rule for Camera File System (DPOF printing possible) and RAW/sRAW images captured with the EOS 5D Mark II |
Easy Print feature | Provided |
DPOF | Version 1.1 compatible |
Compatible Images | JPEG and RAW images Only JPEG images can be transferred as wallpaper on the personal computer screen |
Custom Functions | Total 25 |
Camera User Settings | Register under Mode Dial's C1, C2 and C3 positions |
My Menu Registration | Provided |
Battery | One Battery Pack LP-E6 AC power can be supplied via AC Adapter Kit ACK-E6 with Battery Grip BG-E6 attached. |
Battery Check | Auto |
Power Saving | Provided. Power turns off after 1, 2, 4, 8, 15 or 30 min. |
Date/Time Battery | One CR1616 lithium-ion battery |
Start-up Time | Approx. 0.1 sec. |
Dimensions (W x H x D) | Approx. 6.0 x 4.5 x 3.0 in./152.0 x 113.5 x 75.0mm |
Weight | Approx. 28.6 oz./810g (body only) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
