Canon Support for EOS 5D Mark III | Canon U.S.A., Inc.
EOS 5D Mark III
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Digital, AF/AE single-lens reflex, camera
Recording Media
CF Cards (Type I); Compatible with UDMA CF cards; SD, SDHC, and SDXC Memory Cards
Image Format
Approx. 36 mm x 24mm (35mm Full-frame)
Compatible Lenses
Canon EF Lenses (excluding EF-S Lenses)
Lens Mount
Canon EF mount
Type
High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels
Effective pixels: Approx. 22.3 megapixels
Pixel Unit
6.25 &micro;m square
Total Pixels
Total pixels: 23.4 megapixels
Aspect Ratio
3:2 (Horizontal: Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the image sensor
Dust Deletion Feature
(1)Self Cleaning Sensor Unit
&middot;Automatic Sensor Cleaning
&middot;Removes dust adhering to the infrared- and ultraviolet-blocking glass.
&middot;Self-cleaning executed automatically when power is turned on or off. Manual execution also possible.
&middot;Low-pass filter has a fluorine coating.
(2) Dust Delete Data acquisition and appending
&middot;The coordinates of the dust adhering to the infrared- and ultraviolet-blocking glass are detected by a test shot and appended to subsequent images.
&middot;The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
(3) Manual cleaning
Recording Format
Design Rule for Camera File System 2.0 and EXIF 2.3
Image Format
Still Image: JPEG, RAW (14-bit Canon Original), M-RAW, S-RAW, RAW+JPEG, M-RAW+JPEG, S-RAW+JPEG
Video: MOV (Image data: H.264/MPEG-4 AVC; Audio: Linear PCM)
File Size
(1)Large: Approx. 22.10 Megapixels (5760 x 3840)
(2)Medium: Approx. 9.80 Megapixels (3840 x 2560)
(3)S1 (Small 1): Approx. 5.50 Megapixels (2880 x 1920)
(4)S2 (Small 2): Approx. 2.50 Megapixels (1920 x 1280)
(5)S3 (Small 3): Approx. 350,000 Pixels (720 x 480)
(6)RAW: Approx. 22.10 Megapixels (5760 x 3840)
(7)M-RAW: Approx. 10.50 Megapixels (3960 x 2640)
(8)S-RAW: Approx. 5.50 Megapixels (2880 x 1920)Exact file sizes depend on the subject, ISO speed, Picture Style, etc.
Recording Functions
1.Standard
* Records to either the CF card or SD card.
2.Auto switch card
* When the current card becomes full, the camera switches to the other card automatically.
3.Record separately
* The CF card and SD card record the same image at a different image recording quality (L, M, S1, S2, S3, RAW, M-RAW, S-RAW)
4.Record to multiple
* Both the CF card and SD card record the same image at the same image recording quality. (Also applies to RAW+JPEG, M+JPEG, and SRAW+JPEG)
Backup Recording
Images recorded in a card can be copied to the other card
File Numbering
The following three types of file numbers can be set:
(1) Continuous numbering
* The continuous numbering of captured images will continue even after you replace the camera's card. (The numbering continues even when the folder changes.)
(2) Auto reset
* When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card.
(3) Manual reset
* Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording
The image-recording quality can be selected in any combination of the three RAW and eight JPEG recording quality settings.
Color Space
Selectable between sRGB and Adobe RGB
Picture Style
Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3
* Scene Intelligent Auto will set [Auto] automatically.
* [Standard] is the default setting for [User Def. 1-3]
Settings
(1)Auto (AWB)
(2)Daylight
(3)Shade
(4)Cloudy
(5)Tungsten light
(6)White fluorescent light
(7)Flash
(8)Custom (Custom WB)
(9)Color temperature
* With an EX-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000K if the flash unit does not have the color temperature communication feature.
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
Blue/amber bias: &plusmn;9 levels
&middot; Magenta/green bias: &plusmn;9 levels
* Corrected in reference to the current WB mode's color temperature.
Color Temperature Information Transmission
Provided
Type
Eye-level pentaprism
Coverage
Approx. 100% vertically and horizontally (At approx. 21mm eyepoint)
Magnification
Approx. 0.71x / Angle of view 34.1&deg; (with 50mm lens at infinity, -1 m-1 (dpt))
Eye Point
Approx. 21mm (At -1m-1 from the eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0m-1 (diopter)
Focusing Screen
Fixed
Mirror
Quick-return half mirror (transmission: reflectance ratio of 40:60)
Viewfinder Information
&middot;AF information
AF point, focus confirmation, AF status indicator
&middot;Exposure information
Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, exposure warning
&middot;Flash information
Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light
&middot;Image information
Highlight tone priority (D+), maximum burst (2-digit display), card information
&middot;Battery check
&middot;Composition information
Grid, electronic level
&middot;Warning symbol
Displayed if any of the following is set: Monochrome, white balance correction, One-touch recording quality switch, expanded ISO speed, or spot metering.
Depth Of Field Preview
Enabled with Depth-of-field preview button
Type
TTL secondary image - registration, phase detection
AF Points
61-point (up to 41 cross-type points)
* One to five cross-type AF points at f/2.8, 10 to 20 cross-type AF points at f/4, and 15 to 21 cross-type AF points at f/5.6. (The number of cross-type AF points will differ depending on the lens.)
AF Working Range
EV -2 - 18 (at 73&deg;F/23&deg;C and ISO 100)
Focusing Modes
(1) Autofocus
&middot;One-Shot AF
&middot;Predictive AI Servo AF
&nbsp;&nbsp;&nbsp;-For automatic AF point selection, the AF point to start the AI Servo AF operation can be selected.
&nbsp;&nbsp;&nbsp;-For automatic AF point selection, the active AF point can be displayed.
&middot;AI Focus AF
&nbsp;&nbsp;&nbsp;-(Switches between One-Shot AF and AI SERVO AF automatically)
&nbsp;&nbsp;&nbsp;-Automatically set in A+ Auto Mode
(2) Manual focus (MF)
AF Point Selection
1.Single-point AF (Manual selection)
2.Auto selection 61-Point AF
3.Single-point Spot AF (Manual selection)
4.AF point expansion (Manual selection, 4 points: Up, down, left, and right)
5.AF point expansion (Manual selection, surrounding 8 points)
6.Zone AF (Manual zone selection)
Selected AF Point Display
Displayed in viewfinder with transparent LCD and on LCD panel
Active AF Point Indicator
AF area used in horizontal/vertical (grip up or down) shooting and the manually-selected AF point position can be set separately
AF Assist Beam
(1)Enable
With an EOS-dedicated Speedlite, AF-assist beam is emitted automatically when necessary.
(2)Disable
(3)IR AF assist beam only
* No AF-assist beam with flash bursts.
Metering Modes
Max. aperture TTL metering with 63-zone SPC with the following selectable modes:
(1)Evaluative metering (linked to all AF points)
(2)Partial metering (center, approx. 7.2% of viewfinder)
(3)Spot metering (center, approx. 1.5% of viewfinder)
&middot;AF point-linked spot metering not provided.
(4)Center-weighted average metering
a.The selectable metering modes can be limited with a Custom Function.
Metering Range
EV 1-20 (at 73&deg;F / 23&deg;C with 50mm f/1.4 lens at ISO 100)
Exposure Control Systems
(1) Scene Intelligent Auto
(2) Program AE (shiftable)
(3) Shutter-priority AE (Safety shift possible)
(4) Aperture-priority AE (Safety shift possible)
(5) Manual exposure
* The metering mode can be specified with a Custom Function.
(6) Bulb
(7) E-TTL II autoflash program AE
* Evaluative metering, Averaged metering
ISO Speed Range
For Stills:
ISO 100-25600 (in 1/3-stop or whole-stop increments)
&middot;ISO speed expansion possible to ISO 50, 51200, and 102400.
&middot;For [Highlight tone priority], the settable ISO speed range will be 200-25600.
&middot;ISO speed safety shift possible with Custom Function.
&lowast;If fill flash will result in overexposure, minimum ISO 100 is set.
&lowast;For bounce flash, ISO 400-1600 is set automatically depending on the light level.
ISO Speed upper and lower limits:
(1) Manual setting range
* ISO speed expansion is set with this option.
(2) Auto ISO range
* ISO speed expansion not settable.
Shutter speed and automatic ISO speed control in P and Av Modes:
In the P and Av shooting modes with Auto ISO set, the ISO speed is set automatically so that a shutter speed slower than the one set with[Minimum shutter speed] (1/250, 1/125, 1/60, 1/30, 1/15, 1/8, 1/4, 0"5, 1") is not set.
Exposure Compensation
Manual: &plusmn;5 stops in 1/3 or 1/2-stop increments
AEB: &plusmn;3 stops in 1/3 or 1/2-stop increments
* Indicated up to ±3 stops on the LCD panel and in the viewfinder.
AE Lock
(1) Auto AE lock
&middot;In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
(2) Manual AE lock
&middot;With AE lock button. (AE lock is updated each time you press the button.) Enabled in all metering modes.
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds
1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.)
X-sync at 1/200 sec.
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. or 2-sec. delay
Shutter Lag Time
1) During SW-1 ON, time lag between SW-2 ON and start of exposure:
- Approx. 0.059 sec. (With the shutter-release time lag is shortened with the Custom Function, it will be approx. 0.036 sec.)
2) Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.2 sec.
- Time lag with the aperture stopped down by 3 stops or less. Excludes AF operation time.
EOS Dedicated Speedlite
E-TTL II autoflash with all EX Series Speedlites
Zooming to Match Focal Length
Provided
Flash Exposure Compensation
&plusmn;3 stops in 1/3- or 1/2-stop increments
FE Lock
Provided
External Flash Settings
The camera can set the following with Speedlite 600EX-RT, 580EX II, 430EX II, 320EX, 270EX II, or 270EX:
(1) External flash control
* Flash mode, sync setting, FEB (not possible with 270EX II/270EX), flash exposure compensation, E-TTL II, zoom, wireless master flash (not possible with 430EX II/ 270EX), and clear settings.
* With the Speedlite 600EX-RT, radio wireless control is possible.
(2) Flash Custom Function setting
PC Terminal
Provided (no polarity)
Drive Modes
Single, High-speed continuous, Low-speed continuous, Silent Single Shooting and Self-timer (10 sec. self-timer/remote control, or 2-sec. self-timer/remote control)
Continuous Shooting Speed
High-speed: Maximum approx. 6 shots/sec.
Low-speed: Maximum approx. 3 shots/sec.
Silent continuous shooting: Maximum approx. 3 shots/sec.
Maximum Burst
&middot;JPEG Large/Fine: Approx. 65 shots (approx. 16270 shots)
&middot;RAW: Approx. 13 shots (approx. 18 shots)
&middot;RAW+JPEG Large/Fine: Approx. 7 shots (approx. 7 shots)
*Figures are based on Canon's testing standards (ISO 100 and Standard Picture Style) and a 8 GB card.
*Figures in parentheses apply to an UDMA mode 7, 128 GB card based on Canon's testing standards.
Shooting Modes
Still photo and video recording
Focusing
(1) Autofocus (One-Shot AF)
&middot;Live mode
&middot;One-point, contrast AF. Switching to another AF point possible.
&middot;Face detection Live mode
&middot;Face detection, contrast AF. Face selectable.
&middot;Quick mode
61-point, phase-difference AF, same as normal shooting.
(2) Manual focus
* Magnify the image by 5x or 10x and focus manually.
Metering Modes
Real-time Evaluative metering with the image sensor
Metering Range
Real-time evaluative metering with image sensor:
&middot;Metering range: EV 0 - EV 20 (At 73&deg;F/23&deg;C, 50mm f/1.4 lens, ISO 100)
&middot;AE lock possible
&middot;The active metering time can be changed.
Grid Display
Three grid display provided
Exposure Simulation
Provided
Silent Shooting
Provided (Mode 1 and 2)
File Format
MPEG-4 AVC / H.264
Variable (averaged) bit rate
File Size
Recording Sizes:
1920 x 1080 (Full HD), 1280 x 720 and 640 x 480
Frame Rates
[1920 x 1080]: 30 fps / 25 fps / 24 fps
[1280 x 720]: 60 fps / 50 fps
[640 x 480]: 30 fps / 25 fps
Continuous Shooting Time
Based on 8GB Card:
[1920 x 1080]
30 fps ALL-I: 11 min. (685 MB/min.) / IPB: 32 min (235 MB/min.)
25 fps ALL-I: 11 min (685 MB/min.) / IPB: 32 min. (235 MB/min.)
24 fps ALL-I: 11 min. (685 MB/min.) / IPB: 32 min. (235 MB/min.)
[1280 x 720]
60 fps ALL-I: 12 min. (610 MB/min.) / IPB: 37 min. (205 MB/min.)
50 fps ALL-I: 12 min. (610 MB/min.) / IPB: 37 min. (205 MB/min.)
[640 x 480]
30 fps IPB: 97 min. (78 MB/min.)
25 fps IPB: 97 min. (78 MB/min.)
* If the recording time reaches 29 min. 59 sec., the movie shooting stops automatically.
* Movie shooting does not stop when the file size reaches 4GB.
Focusing
Same as focusing with Live View shooting
* During movie shooting or if movie cropping has been set, the image cannot be magnified for manual focusing.
Range
ISO Range
&middot;P, Av, and Bulb: Automatically set within ISO 100 - 12800, expandable to H (equivalent to ISO 25600)
&middot;A+ and Tv: Automatically set within ISO 100 - 12800
&middot;M: Auto ISO (automatically set within ISO 100 - 12800), ISO 100 - 12800 set manually (in 1/3- or whole-stop increments), expandable to H (equivalent to ISO 16000/20000/25600)
* If Highlight tone priority is set to enable, the settable ISO speed range will be ISO 200 - 12800.
Exposure Control
(1) Program AE for movie shooting
* For shooting modes other than manual exposure and bulb.
* Shutter speed (1/30 - 1/4000 sec., signal accumulation time), aperture, and ISO speed automatically set.
(2) Manual exposure
* For manual exposure.
* Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps.
Up to &plusmn;3 stops in 1/3-stop increments
* For movies, even if exposure compensation has been set beyond &plusmn;3 stops, exposure compensation up to only &plusmn;3 stops will be applied.
* For still photos, exposure compensation up to ±5 stops can be applied.
Type
TFT color, liquid-crystal monitor
Monitor Size
3.2-inches
Pixels
Approx. 1.04 million dots
Coverage
Approx. 100%
Approx. 170&deg; vertically and horizontally
Brightness Control
Auto: Brightness adjusted automatically by the light sensor
* Adjustable to one of three levels: Darker, Standard, Brighter
Manual: Adjustable to one of seven brightness levels
Coating
Clear View LCD II
* Glass surface has an anti-reflective AR coating.
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
On LCD Monitor
Electronic level indicates up to 360&deg; roll and &plusmn;10&deg; pitch in 1&deg; increments.
In Viewfinder
The AF point display is used to indicate up to &plusmn;6&deg; horizontal tilt and &plusmn;4&deg; vertical tilt in 1&deg; increments (During vertical shooting, up to &plusmn;1&deg; horizontal tilt and &plusmn;6&deg; vertical tilt).
Display Format
Single image, Single image + Image-recording quality/shooting information, histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image (auto/manual), image jump (by 10/100 images, index screen, by shooting date, by folder), two-image comparative display, slide show (all images/selected by date/folder), star rating
Highlight Alert
With single-image display (Info.) and single-image display, overexposed highlight areas will blink
Items
The following functions can be set:
Shutter speed, aperture, ISO speed, exposure compensation, AEB, flash exposure compensation, AF point selection (including AF area selection modes), Picture Style, White Balance, WB Correction, metering mode, Auto Lighting Optimizer, recording function switching, image-recording quality, AF mode, drive mode, and Custom Controls (camera controls/buttons customization).
Protection
Erase protection can be applied or canceled for a single image, all images in a folder or all images in the card
Erase
Erase a single image, selected images, all images in a folder, all images in a card or erase only unprotected images
Compatible Printers
PictBridge-compatible printers
Printable Images
RAW and JPEG images complying to Design rule for Camera File System
&middot;Movies cannot be printed
DPOF
Version 1.1 compatible
Compatible Images
JPEG and RAW images and movie
For RAW+JPEG, only the RAW or JPEG image or both images can be transferred
Custom Functions
13 Custom Functions settable with the camera
Custom Controls
The following camera controls can be customized by assigning the desired function: Shutter button halfway pressing, AF-ON button, AE lock button, Depth-of-field preview button, lens AF Stop button, Multifunction button, SET button, Main Dial, Quick Control Dial, and Multicontroller
Camera User Settings
Current camera settings can be registered to C1, C2 and C3 on the Mode Dial (Automatic registration update is possible)
My Menu Registration
Up to six top-tier menu options and Custom Function settings can be registered
USB Terminal
For personal computer communication and direct printing (USB 2.0 Hi-Speed)
Video Out Terminal
(1) Video OUT terminal: NTSC/PAL selectable
(2) mini-HDMI OUT terminal
Extension System Terminal
For connection to WFT-E7A (WFT) and GP-E2 (GPS)
Gigabit-Ethernet
The RJ-45 jack is not built-in and is only available via the Wireless File Transmitter WFT-E7A
Battery
One Battery Pack LP-E6
AC power can be supplied with the AC Adapter Kit ACK-E6
Battery Life
1)Camera body only:
2)With Battery Grip BG-E11:
&lowast;Based on CIPA testing standards
Battery Check
Automatic battery check when the power switch is turned on:
Displayed in 6 levels:
&middot;Battery level displayed on LCD panel and in viewfinder.
&middot;Battery information can be checked with the [Battery info.] menu
&middot;If Battery Grip BG-E11 is used with size AA/LR6 batteries; the battery level is displayed in four levels instead.
Power Saving
Power turns off after the set time (1, 2, 4, 8, 15 or 30 minutes) of non-operation elapses.
Date/Time Battery
CR1616 lithium battery
Start-up Time
Approx. 0.1 sec
Dimensions (W x H x D)
Approx. 6.0 x 4.6 x 3.0 in. (152.0 x 116.4 x 76.4 mm )
Weight
Approx. 33.5 oz. / 950g (Based on CIPA standards)
Approx. 30.3 oz./ 860g (Body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: Wireless File Transmitter WFT-E7A: Firmware Version 1.4.0
Advisory Type
Date 10.03.18
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Canon Support | Service Notice: EOS 5D Mark III and EOS-1D X
Advisory Type
Date 02.18.13
Title Canon Support | Firmware Notice: EOS 5D Mark III: Firmware Version 1.3.6
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: Wireless File Transmitter WFT-E7A: Firmware Version 1.3.0
Advisory Type
Date 08.30.16
Title Canon Support | Service Notice: Charging the Canon Battery Pack LP-E6
Advisory Type
Date 10.06.13
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Service Notice: The EF200 f/2L IS USM and EF800mm f/5.6L IS USM Lenses with the Canon EOS 5D Mark III Digital SLR Camera
Advisory Type
Date 06.22.14
Title Canon Support | Service Notice: EOS-5D Mark III RAW file processing with DPP ver. 3.11.10
Advisory Type
Date 04.02.12
Title Canon Support | Service Notice: EOS Utility
Advisory Type
Date 12.12.19
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Service Notice: EOS-5D Mark III change in displayed exposure value
Advisory Type
Date 06.22.14
Title Canon Support | Service Notice: Photo Culling App Version 2.0 for iOS
Advisory Type
Date 11.16.21
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
