Canon Support for EOS 5D | Canon U.S.A., Inc.
EOS 5D
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Type Digital AF/AE SLR
Recording Media CompactFlash (CF) Card Type I and II
Image Format 1.41 x 0.94 in./35.8 x 23.9mm
Compatible Lenses Canon EF lenses (except EF-S lenses)
Lens Mount Canon EF mount
Image Sensor
Type High-sensitivity, High-resolution, Single-plate CMOS Sensor
Pixels Approx. 12.8 megapixels
Total Pixels Approx. 13.3 megapixels
Aspect Ratio 3:2 (Horizontal : Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Fixed position in front of the image sensor
Recording System
Recording Format JPEG, RAW and RAW+JPEG simultaneous recording provided. Backup image recording enabled (Same image recordable on CF card standards)
Image Format JPEG, RAW
File Size (1) Large/Fine: Approx. 4.6MB (4,368 x 2,912) (2) Large/Normal 2.3MB (4,368 x 2,912) (3) Medium/Fine: Approx. 2.7MB (3,168 x 2,112) (4) Medium/Normal: Approx. 1.4MB (3,168 x 2,112) (5) Small/Fine: Approx. 2.0MB (2,496 x 1,664) (6) Small/Normal: Approx. 1.0MB (2,496 x 1,664) (7) RAW: Approx. 12.9MB (4,368 x 2,912)
Folders Folder creation/selection enabled
File Numbering (1) Continuous numbering (2) Auto reset (3) Manual reset
Color Space Selectable between sRGB and Adobe RGB
Picture Style Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1, 2, 3
Interface Hi-Speed USB (Print/PTP/PC connect, selectable)
Video output (NTSC/PAL)
White Balance
Settings Auto, Preset (Daylight, Shade, Cloudy/Twilight/Sunset, Tungsten Light, White Fluorescent Light, Flash), Manual (Custom, Color Temperature)
Auto White Balance Auto white balance with the image sensor
Color Temperature Compensation White balance bracketing: +/-3 stops in full-stop increments
White Balance Correction: Blue/Amber bias +/- 9 levels
Magenta/Green bias +/- 9 levels
Blue/Amber bias and Magenta/Green bias cannot be set together during White Balance Bracketing
Color Temperature Information Transmission Provided
Viewfinder
Type Eye-level SLR with fixed pentaprism
Coverage Approx. 96% horizontally and vertically (coverage against JPEG Large)
Magnification 0.71x (-1 dpt with 50mm lens at infinity)
Eye Point 20mm
Dioptric Adjustment Correction -3.0 to +1.0 diopter
Focusing Screen Standard focusing screen: Ee-A
Mirror Quick-return half mirror (Transmission: reflection ratio of 40:60, no mirror cut-off with EF 600mm f/4 or shorter lens)
Viewfinder Information AF (AF points, focus confirmation light), Exposure (shutter speed, aperture, spot metering circle, exposure level, AE lock, exposure compensation, AEB level), Flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, FEB shooting, flash exposure compensation, insufficient flash warning during FE lock), White balance correction, Maximum burst, CF card full warning, CF card error warning, No CF card warning
Depth Of Field Preview Enabled with depth-of-field preview button (with Speedlite 580EX, 550EX, 430EX, MR-14EX, or MT-24EX, pressing the depth-of-field preview button fires a modeling flash)
Eyepiece Shutter None (eyepiece cover provided on strap)
Autofocus
Type TTL-CT-SIR AF-dedicated CMOS Sensor
AF Points 9 AF points (plus 6 invisible Supplemental AF points)
AF Working Range EV -0.5-18 (at ISO 100 at 20&degC/68&degF)
Focusing Modes Autofocus, (One-Shot AF, Predictive AI Servo AF, AI Focus AF (automatic switching between One-Shot/Predictive AI Servo AF)), Manual Focus (MF)
AF Point Selection Manual selection, Automatic selection
Selected AF Point Display Superimposed in viewfinder and indicated on LCD screen
AF Assist Beam Emitted by the dedicated Speedlite
Exposure Control
Metering Modes Max. aperture TTL metering with 35-zone SPC
(1) Evaluative metering (link to all AF points)
(2) Partial metering (approx. 8% of viewfinder)
(3) Spot metering (approx. 3.5% of viewfinder)
(4) Center-weighted average metering
Metering Range EV 1-20 (at 68&degF/20&degC with 50mm f/1.4 lens, ISO 100)
ISO Speed Range Equivalent to ISO 100-1600 (in 1/3-stop increments), ISO speed can be expanded to ISO 50 and 3200
Exposure Compensation (1) Manual, (2) AEB (Auto Exposure Bracketing)Bracketing range: &plusmn;2 stops in 1/2- or 1/3-stop increments
AE Lock Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved
Manual: By AE lock button
Shutter Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled1/8000 to 30 sec. (1/3-stop increments), X-sync at 1/200 sec.Soft-touch electromagnetic release10 sec. delayRemote control with N3 type terminal
Type Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds 1/8000 to 30 sec. (1/3-stop increments), X-sync at 1/200 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10 sec. delay
Remote Control Remote control with N3 type terminal
External Speedlite
EOS Dedicated Speedlite E-TTL II autoflash with EX-series Speedlite
Zooming to Match Focal Length Provided
Flash Exposure Compensation &plusmn;2 stops in 1/3- or 1/2-stop increments
FE Lock Provided
PC Terminal Provided
Drive System
Drive Modes Single, Continuous (approx. 3 fps), Self-timer
Continuous Shooting Speed Approx. 3 fps (at 1/250 sec. or faster for all recording quality settings)
Maximum Burst JPEG: Approx. 60 frames (JPEG/Large)
RAW: Approx. 17 frames
RAW+JPEG: Approx. 12 frames
LCD Monitor
Type TFT color liquid-crystal monitor
Monitor Size 2.5 in.
Pixels Approx. 230,000
Coverage 100% for JPEG images
Brightness Control 5 levels provided
Interface Languages 15
Playback
Display Format Single image, 9-image index, Magnified zoom (approx. 1.5x to 10x), Auto play, Auto play right after shooting, Rotated, Jump
Highlight Alert In the single image (INFO) mode, the highlight portions containing no image information will blink
AF Point Display Enabled
Histogram Brightness, RGB
Image Protection and Erase
Protection A single image can be protected or unprotected
Erase A single image or all images stored in a CF card can be erased if they are unprotected
Direct Printing
Compatible Printers CP Direct, Bubble Jet Direct, and PictBridge-compatible printers
Printable Images JPEG images (DPOF printing possible)
Easy Print feature Provided
DPOF: Digital Print Order Format
DPOF Version 1.1 compatible
Customization
Custom Functions 21 Custom Functions with 57 settings
Register Basic Camera Settings Under Mode Dial's setting
Sound Recording
Recording Methods None
File Format N/A
Recording Time N/A
Power Source
Battery One Battery Pack BP-511A/BP-514/BP-511/BP-512
Battery Life Approx. 800 (68&degF/20&degC), approx. 400 (32&degF/0&degC)
* The above figures comply with CIPA standard and apply when a fully-charged Battery Pack BP-511A is used.
Battery Check Automatic
Power Saving Provided. Power turns off after 1, 2, 4, 8, 15, 30 min.
Date/Time Battery One CR2016 Lithium Battery
Dimensions and Weight
Dimensions (W x H x D) 6.0 x 4.4 x 3.0 in./152 x 113 x 75mm
Weight 28.6 oz./810g (Body only. Battery: 2.9 oz./82g)
Operating Environment
Working Temperature Range 32-104&degF/0-40&degC
Working Humidity Range 85% or less
Battery Pack
Type For BP-511A
Rechargeable lithium-ion battery
Rated Voltage 7.4 V DC
Battery Capacity 1390 mAh
Dimensions (W x H x D) 38 x 21 x 55mm/1.5 x 0.8 x 2.2 in.
Weight Approx. 82g/2.9 oz.
Battery Charger
Type For CG-580
Compatible Battery Battery pack BP-511A, BP-514, BP-511, or BP-512
Recharging Time BP-511A, BP-514: Approx. 100 min.
BP-511, BP-512: Approx. 90 min.
Rated Input 100 - 240 V AC
Rated Output 8.4 V DC
Working Temperature Range 0&deg;C - 40&deg;C/32&deg;F - 104&deg;C
Dimensions (W x H x D) 91 x 67 x 31mm/3.6 x 2.6 x 1.2 in.
Weight Approx. 115/4.0 oz.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: EOS Utility
Advisory Type
Date 12.12.19
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Service Notice: Information on Original Data Security and Original Data Verification Kits
Advisory Type
Date 01.24.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
