Canon Support for EOS 7D | Canon U.S.A., Inc.
        EOS 7D
- Windows 11
 - Windows 10 (x64)
 - Windows 10
 - Windows 8.1 (x64)
 - Windows 8.1
 - Windows 8 (x64)
 - Windows 8
 - Windows 7 (x64)
 - Windows 7
 - Windows Vista (x64)
 - Windows Vista
 - Windows Me
 - Windows XP (x64)
 - Windows XP
 - Windows 98
 - Windows 95
 - Windows Server 2022
 - Windows Server 2019 (x64)
 - Windows Server 2016 (x64)
 - Windows Server 2012 (x64)
 - Windows Server 2008 (x64)
 - Windows Server 2003 (x64)
 - Windows Server 2003 R2
 - macOS Tahoe v26
 - macOS Sequoia v15
 - macOS Sonoma v14
 - macOS Ventura v13
 - macOS Monterey v12
 - macOS Big Sur v11.0
 - macOS Catalina v10.15
 - macOS Mojave v10.14
 - macOS High Sierra v10.13
 - macOS Sierra v10.12
 - OS X El Capitan v10.11
 - OS X Yosemite v10.10
 - OS X Mavericks v10.9
 - OS X Mountain Lion v10.8
 - OS X Lion v10.7
 - Mac OS X Snow Leopard v10.6
 - Mac OS X v10.1
 - Mac OS 9
 - Linux ARM
 - Linux MIPS
 - Linux 64bit
 - Linux 32bit
 - SAP
 - Windows Server 2025
 - Windows NT
 - Linux
Camera Connect
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Type | High-sensitivity, high-resolution, large single-plate CMOS sensor  |
| Pixels | Effective pixels: Approx. 18.0 megapixels  |
| Pixel Unit | 4.3 µm square  |
| Total Pixels | Approx. 19.0 megapixels  |
| Aspect Ratio | 3:2 (Horizontal: Vertical)  |
| Color Filter System | RGB primary color filters  |
| Low Pass Filter | Fixed position in front of the CMOS sensor  |
| Dust Deletion Feature | (1)Automatic Sensor Cleaning Removes dust adhering to the low-pass filter. Self-cleaning executed automatically (taking 2 sec.) when power is turned on or off. Manual execution also possible (taking 6 sec.).Low-pass filter has a fluorine coating.(2)Dust Delete Data appended to the captured image The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots. (3) Manual cleaning of sensor  |
| Recording Format | Design rule for Camera File System 2.0 and Exif 2.21  |
| Image Format | Still: JPEG, RAW (14-bit, Canon original), sRAW, mRAW, RAW+JPEG Video: MOV (Image data: H.264, Audio: Linear PCM)  |
| File Size | (1) Large: Approx. 17.90 Megapixels (5,184 x 3,456) (2) Medium: Approx. 8.00 Megapixels (3,456 x 2,304) (3) Small: Approx. 4.50 Megapixels (2,592 x 1,728) (4) RAW: Approx. 17.90 Megapixels (5,184 x 3,456) (5) M-RAW: Approx. 10.10 Megapixels (3,888 x 2,592) (6) S-RAW: Approx. 4.50 Megapixels (2,592 x 1,728) Exact file sizes depend on the subject, ISO speed, Picture Style, etc.  |
| Recording Functions | Images record directly to the CF card. With the WFT-E5A attached, image recording to the CF card and to the USB external media connected to the WFT-E5A will be possible as follows:(1) Standard No automatic switching of recording media.(2) Automatic switching of recording media When the current recording media becomes full, it switches to another recording media automatically and continues recording.(3) Separate recording Each recording media can be set to record a specific image-recording quality for each shot.(4) Recording of identical images Images can also be recorded at the same size to both recording media. (RAW+JPEG, M RAW+JPEG or S RAW+JPEG is possible).(5) Backup to external recording media Selected images, all images, and quick backup are possible.  |
| Backup Recording | Enabled with Wireless File Transmitter WFT-E5A attached  |
| File Numbering | Consecutive numbering, auto reset, manual reset. Possible to create new folders and select folders in the CF card. Firmware Version 2.0.X allows manually setting the file name, the first four alphanumeric characters, or the first three alphanumeric characters + image size.  |
| Color Space | sRGB, Adobe RGB  |
| Picture Style | Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3  |
| Settings | Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom, Color Temperature setting  |
| Auto White Balance | Auto white balance with the image sensor  |
| Color Temperature Compensation | White Balance Correction: ± up to 9 levels, in 1-step increments White Balance Bracketing: ± up to 3 levels, in 1-step increments  |
| Color Temperature Information Transmission | Provided  |
| Type | Eye-level pentaprism  |
| Coverage | Approximately 100%  |
| Magnification | Approx. 1.0x (-1m-1 with 50mm lens at infinity)/29.4° angle of view  |
| Eye Point | Approx. 22mm (from eyepiece lens center)  |
| Dioptric Adjustment Correction | -3.0 to +1.0m-1 (diopter)  |
| Focusing Screen | Fixed  |
| Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60) with EF600mm f/4L IS USM or shorter lenses)  |
| Viewfinder Information | AF information (AF points, focus confirmation light), Exposure information (Shutter speed, aperture, ISO speed, AE lock, exposure level, spot metering circle, exposure warning), Flash information (Flash-ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light), Image information (Highlight tone priority, Monochrome shooting, maximum burst, white balance correction, CF card information), Composition information (Grid, electronic level), Battery check  |
| Depth Of Field Preview | Enabled with depth-of-field preview button  |
| Type | TTL-CT-SIR AF-dedicated CMOS sensor  |
| AF Points | 19-point all cross-type AF (f/2.8 at center: Dual Cross Sensor)  |
| AF Working Range | EV -0.5-18 (at 73°F/23°C, ISO 100)  |
| Focusing Modes | (1) Autofocus - One-Shot AF - Predictive AI Servo AF * For automatic AF point selection, the AF point to start the AI Servo II AF operation can be selected. * For automatic AF point selection, the active AF point can be displayed. - AI Focus AF (Switches between One-Shot AF and AI Servo II AF automatically) (2) Manual focus (MF)  |
| AF Point Selection | (1) Manual selection: Single point AF (2) Manual selection: Spot AF (3) Manual selection: AF point expansion (4) Manual selection: Zone AF (5) Automatic selection: 19 point AF  |
| AF Function Registration/Switching | With a Custom Function, four types of AF function settings can be registered in a group: 1. AF area selection mode, 2. AI Servo tracking sensitivity, 3. AI Servo AF tracking method, and 4. AI Servo 1st/2nd img priority. *This function can be assigned to the depth-of-field preview button or lens A stop button by customizing camera controls/buttons (Custom Controls).  |
| Selected AF Point Display | Indicated by transmissive LCD display in the viewfinder and on the LCD panel  |
| AF Assist Beam | When an external EOS-dedicated Speedlite is attached to the camera, the AF-assist beam from the Speedlite will be emitted when necessary.  |
| Metering Modes | 63-zone SPC TTL metering with selectable modes Evaluative metering (uses all 63 zones; linked to active AF point)Partial metering (approx. 9.4% of viewfinder at center)Spot metering (approx. 2.3% of viewfinder at center)Center-weighted average metering  |
| Metering Range | EV 1-20 (at 73°F/23°C with EF50mm f/1.4 USM lens, ISO 100)  |
| Exposure Control Systems | Program AE (Shiftable), Shutter-priority AE, Aperture-priority AE, Creative Auto, Full auto, Manual exposure, E-TTL II autoflash program AE  |
| ISO Speed Range | Manually set by user, in P, Tv, Av, and M modes — ISO 100 thru 6400 (in 1/3 or full-stop increments) Automatic ISO setting in P, Tv, Av, and M modes — ISO 1006400; User-defined maximum ISO limit can be set from 400 thru 6400, in full-step increments (Firmware Version 2.0.X is required) When Highlight Tone Priority is active: minimum possible ISO is 200 Automatic ISO setting in Basic Zone modes — ISO 100 thru 3200 Note: In Creative Zone modes (P, Tv, Av, M, and B modes) the maximum settable ISO speed (4006400) will vary within the automatic automatic ISO speed range.* *Firmware upgrade (Version 2.0.X) is required.  |
| Exposure Compensation | Up to ±5 stops in 1/3- or 1/2-stop increments (AEB ±3 stops) * Indicated up to ±3 stops on the LCD panel and in the viewfinder.  |
| AE Lock | Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved User-applied: By AE lock button  |
| Type | Vertical-travel, mechanical, Electronically-controlled, focal-plane shutter  |
| Shutter Speeds | 30 seconds to 1/8000th second; user-settable in 1/3 or full-step increments (available shutter speeds vary by shooting mode); plus Bulb X-sync at 1/250th second with EOS Speedlites  |
| Shutter Release | Soft-touch electromagnetic release  |
| Self Timer | 10-sec. or 2-sec. delay  |
| Shutter Lag Time | Approx. 0.059 sec., according to Canon Inc. test methods and criteria  |
| Type | Retractable, auto pop-up flash  |
| Flash Metering System | E-TTL II auto flash; Manual flash and Multi flash also possible.  |
| Guide Number | 12/39 (ISO 100, in meters/feet)  |
| Recycling Time | Approx. 3 sec.  |
| Flash Ready Indicator | Flash-ready icon lights in viewfinder  |
| Flash Coverage | 15mm lens angle of view (equivalent to approx. 24mm in 135 format)  |
| FE Lock | Provided  |
| Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments  |
| Zooming to Match Focal Length | Provided  |
| Flash Metering | E-TTL II autoflash  |
| External Flash Settings | Flash function settings, Flash C.Fn settings  |
| PC Terminal | Provided  |
| Drive Modes | Single, High-speed continuous, Low-speed continuous, and Self-timer (10 sec. self-timer/remote control, or 2-sec. self-timer/remote control)  |
| Continuous Shooting Speed | High-speed: Max. 8.0 shots/sec. Low-speed: Max. 3.0 shots/sec.  |
| Maximum Burst | JPEG (Large/Fine): approx. 110*/approx. 130** RAW: approx. 23*/approx. 25** RAW+JPEG (Large/Fine): approx. 17*/approx. 17** *Figures based on Firmware upgrade (Version 2.0.X), ISO 100, Standard Picture Style and with 8GB CF memory card. **Figures apply to 128GB UDMA 7 CF memory card. Note: UDMA 7 CF memory card read/write speeds are not fully supported with the EOS 7D Digital SLR camera, if using UDMA 7 memory cards, the read/write speeds will be equivalent to UDMA 6  |
| Shooting Modes | Still photo shooting and video shooting  |
| Focusing | Quick mode (Phase-difference detection) Live mode/Face detection Live mode (Contrast detection) Face detection Live mode Manual focusing (5x/10x magnification possible)  |
| Metering Modes | Evaluative metering with the image sensor (still photos) Center-weighted average metering (video)  |
| Metering Range | EV 1-20 (at 73°F/23°C with EF 50mm f/1.4 USM lens, ISO 100)  |
| Grid Display | Provided (Two-type grid displays)  |
| Exposure Simulation | Provided  |
| Silent Shooting | Provided (Mode 1 and 2)  |
| File Format | MOV (image data: H.264; audio: Linear PCM (monaural))  |
| File Size | Recording Size: 1920 x 1080 (Full HD), 1280 x 720 (SD), 640 x 480 (SD)  |
| Frame Rates | 1920 x 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p, 1280 x 720 (HD): 60p (59.94) / 50p, 640 x 480 (SD): 60p (59.94) / 50p  |
| Continuous Shooting Time | Approx. 12 min. (Full HD); 12 min. (HD); 24 min. (SD) Based on Canon's testing standards using a 4GB card.  |
| Focusing | Autofocus: Quick mode, Live mode, Face Detection Live mode; manual  |
| Exposure Control | Program AE, Manual exposure  |
| Type | TFT color, liquid-crystal monitor  |
| Monitor Size | 3.0 in.  |
| Pixels | Approx. 920,000 dots (VGA)  |
| Coverage | Approx. 100% Viewing angle: 170°  |
| Brightness Control | Auto: Brightness adjusted automatically by the light sensor, Manual: 7 levels provided  |
| Coating | Anti-reflection, anti-dust coatings  |
| Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)  |
| On LCD Monitor | Electronic level indicates up to 360° roll and ±10° pitch in 1° increments.  |
| In Viewfinder | The AF point display is used to indicate up to ±6° roll and ±4° pitch in 1° increments (during vertical shooting, up to ±4° roll and ±6° pitch).  |
| Display Format | Single image, Single image + Image-recording quality/shooting information, histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image (auto/manual), image jump (by 10/100 images, index screen, by shooting date, by folder), slide show (all images/selected by date/folder)  |
| Highlight Alert | Provided (Overexposed highlights blink)  |
| Items | The following functions can be set (Press "Q" button to access Menu): Shutter speed, aperture, ISO speed, exposure compensation, AEB, flash exposure compensation, AF point selection (including AF area selection modes), Picture Style, white balance, metering mode, Auto Lighting Optimizer, image-recording quality, AF mode, drive mode, and Custom Controls (camera controls/buttons customization).  |
| Protection | Single images can be erase-protected or not  |
| Erase | Single image, check-marked images or all images in the CF card can be erased (except protected images)  |
| Compatible Printers | PictBridge-compatible printers  |
| Printable Images | JPEG images compliant to Design rule for Camera File System (DPOF printing possible) and RAW/sRAW images captured with the EOS 7D  |
| Easy Print feature | Provided  |
| DPOF | Version 1.1 compatible  |
| Compatible Images | JPEG and RAW images *Only JPEG images can be transferred as wallpaper on the personal computer screen  |
| Custom Functions | Total 27  |
| Custom Controls | The following camera controls can be customized by assigning the desired function: Shutter button halfway pressing, AF-ON button, AE lock button, depth-of-preview button, lens AF Stop button, Multifunction button, SET button, Main Dial, Quick Control Dial, and Multicontroller.  |
| Camera User Settings | Register under Mode Dial's C1, C2 and C3 positions  |
| My Menu Registration | Provided  |
| USB Terminal | For personal computer communication and direct printing (USB 2.0 Hi-Speed), used for connecting the Canon GP-E2 GPS Receiver* *Firmware upgrade (Version 2.0.X) is required  |
| Video Out Terminal | (1) Video OUT terminal: NTSC/PAL selectable (2) mini-HDMI OUT terminal  |
| Extension System Terminal | For connection to optional Wireless File Transmitter WFT-E5A  |
| Battery | One Battery Pack LP-E6 AC power can be supplied via AC Adapter Kit ACK-E6 With Battery Grip BG-E7 attached.  |
| Number of Shots | |
| Battery Life | The above figures apply with a fully-charged Battery Pack LP-E6 without a Battery Grip The figures above are based on CIPA (Camera & Imaging Products Association) testing standards  |
| Battery Check | 6-level display on top LCD panel. "Battery Info" in Set-up Menu provides precise charge remaining indication, in 1% increments.  |
| Power Saving | Provided. Power turns off after 1, 2, 4, 8, 15 or 30 min.  |
| Date/Time Battery | One CR1616 lithium-ion battery  |
| Start-up Time | Approx. 0.1 sec. (based on CIPA testing standards)  |
| Dimensions (W x H x D) | Approx. 5.8 x 4.4 x 2.9 in./148.2 x 110.7 x 73.5mm  |
| Weight | Approx. 28.9 oz./820g (body only)  |
| Working Temperature Range | 32-104°F/0-40°C  |
| Working Humidity Range | 85% or less  |
| USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
 - Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
 next to your download
