Canon Support for EOS 7D | Canon U.S.A., Inc.
EOS 7D
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.20.10
File Size 11.20 MB
Date 02.11.10
File Size 6.63 MB
Date 10.14.10
File Size 8.08 MB
Date 03.18.10
File Size 179.06 KB
Date 07.22.12
File Size 6.88 MB
Date 01.24.12
File Size 10.69 MB
Date 06.27.12
File Size 6.52 MB
Date 04.01.25
File Size 142.00 B
Date 03.04.10
File Size 12.70 MB
Date 07.22.12
File Size 6.38 MB
Date 04.01.25
File Size 142.00 B
Date 10.14.10
File Size 8.41 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type
High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels
Effective pixels: Approx. 18.0 megapixels
Pixel Unit
4.3 &micro;m square
Total Pixels
Approx. 19.0 megapixels
Aspect Ratio
3:2 (Horizontal: Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the CMOS sensor
Dust Deletion Feature
(1)Automatic Sensor Cleaning Removes dust adhering to the low-pass filter. Self-cleaning executed automatically (taking 2 sec.) when power is turned on or off. Manual execution also possible (taking 6 sec.).Low-pass filter has a fluorine coating.(2)Dust Delete Data appended to the captured image The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots. (3) Manual cleaning of sensor
Recording Format
Design rule for Camera File System 2.0 and Exif 2.21
Image Format
Still: JPEG, RAW (14-bit, Canon original), sRAW, mRAW, RAW+JPEG
Video: MOV (Image data: H.264, Audio: Linear PCM)
File Size
(1) Large: Approx. 17.90 Megapixels (5,184 x 3,456)
(2) Medium: Approx. 8.00 Megapixels (3,456 x 2,304)
(3) Small: Approx. 4.50 Megapixels (2,592 x 1,728)
(4) RAW: Approx. 17.90 Megapixels (5,184 x 3,456)
(5) M-RAW: Approx. 10.10 Megapixels (3,888 x 2,592)
(6) S-RAW: Approx. 4.50 Megapixels (2,592 x 1,728)
Exact file sizes depend on the subject, ISO speed, Picture Style, etc.
Recording Functions
Images record directly to the CF card. With the WFT-E5A attached, image recording to the CF card and to the USB external media connected to the WFT-E5A will be possible as follows:(1) Standard No automatic switching of recording media.(2) Automatic switching of recording media When the current recording media becomes full, it switches to another recording media automatically and continues recording.(3) Separate recording Each recording media can be set to record a specific image-recording quality for each shot.(4) Recording of identical images Images can also be recorded at the same size to both recording media. (RAW+JPEG, M RAW+JPEG or S RAW+JPEG is possible).(5) Backup to external recording media Selected images, all images, and quick backup are possible.
Backup Recording
Enabled with Wireless File Transmitter WFT-E5A attached
File Numbering
Consecutive numbering, auto reset, manual reset.
Possible to create new folders and select folders in the CF card.
Firmware Version 2.0.X allows manually setting the file name, the first four alphanumeric characters, or the first three alphanumeric characters + image size.
Color Space
sRGB, Adobe RGB
Picture Style
Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3
Settings
Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom, Color Temperature setting
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
White Balance Correction: &plusmn; up to 9 levels, in 1-step increments
White Balance Bracketing: &plusmn; up to 3 levels, in 1-step increments
Color Temperature Information Transmission
Provided
Type
Eye-level pentaprism
Coverage
Approximately 100%
Magnification
Approx. 1.0x (-1m-1 with 50mm lens at infinity)/29.4&deg; angle of view
Eye Point
Approx. 22mm (from eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0m-1 (diopter)
Focusing Screen
Fixed
Mirror
Quick-return half mirror (transmission: reflection ratio of 40:60) with EF600mm f/4L IS USM or shorter lenses)
Viewfinder Information
AF information (AF points, focus confirmation light), Exposure information (Shutter speed, aperture, ISO speed, AE lock, exposure level, spot metering circle, exposure warning), Flash information (Flash-ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light), Image information (Highlight tone priority, Monochrome shooting, maximum burst, white balance correction, CF card information), Composition information (Grid, electronic level), Battery check
Depth Of Field Preview
Enabled with depth-of-field preview button
Type
TTL-CT-SIR AF-dedicated CMOS sensor
AF Points
19-point all cross-type AF (f/2.8 at center: Dual Cross Sensor)
AF Working Range
EV -0.5-18 (at 73&deg;F/23&deg;C, ISO 100)
Focusing Modes
(1) Autofocus
- One-Shot AF
- Predictive AI Servo AF
* For automatic AF point selection, the AF point to start the AI Servo II AF operation can be selected.
* For automatic AF point selection, the active AF point can be displayed.
- AI Focus AF (Switches between One-Shot AF and AI Servo II AF automatically)
(2) Manual focus (MF)
AF Point Selection
(1) Manual selection: Single point AF
(2) Manual selection: Spot AF
(3) Manual selection: AF point expansion
(4) Manual selection: Zone AF
(5) Automatic selection: 19 point AF
AF Function Registration/Switching
With a Custom Function, four types of AF function settings can be registered in a group: 1. AF area selection mode, 2. AI Servo tracking sensitivity, 3. AI Servo AF tracking method, and 4. AI Servo 1st/2nd img priority.
*This function can be assigned to the depth-of-field preview button or lens A stop button by customizing camera controls/buttons (Custom Controls).
Selected AF Point Display
Indicated by transmissive LCD display in the viewfinder and on the LCD panel
AF Assist Beam
When an external EOS-dedicated Speedlite is attached to the camera, the AF-assist beam from the Speedlite will be emitted when necessary.
Metering Modes
63-zone SPC TTL metering with selectable modes Evaluative metering (uses all 63 zones; linked to active AF point)Partial metering (approx. 9.4% of viewfinder at center)Spot metering (approx. 2.3% of viewfinder at center)Center-weighted average metering
Metering Range
EV 1-20 (at 73&deg;F/23&deg;C with EF50mm f/1.4 USM lens, ISO 100)
Exposure Control Systems
Program AE (Shiftable), Shutter-priority AE, Aperture-priority AE, Creative Auto, Full auto, Manual exposure, E-TTL II autoflash program AE
ISO Speed Range
Manually set by user, in P, Tv, Av, and M modes &mdash; ISO 100 thru 6400 (in 1/3 or full-stop increments)
Automatic ISO setting in P, Tv, Av, and M modes &mdash; ISO 1006400; User-defined maximum ISO limit can be set from 400 thru 6400, in full-step increments (Firmware Version 2.0.X is required)
When Highlight Tone Priority is active: minimum possible ISO is 200
Automatic ISO setting in Basic Zone modes &mdash; ISO 100 thru 3200
Note: In Creative Zone modes (P, Tv, Av, M, and B modes) the maximum settable ISO speed (4006400) will vary within the automatic automatic ISO speed range.*
*Firmware upgrade (Version 2.0.X) is required.
Exposure Compensation
Up to &plusmn;5 stops in 1/3- or 1/2-stop increments (AEB &plusmn;3 stops)
* Indicated up to ±3 stops on the LCD panel and in the viewfinder.
AE Lock
Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved
User-applied: By AE lock button
Type
Vertical-travel, mechanical, Electronically-controlled, focal-plane shutter
Shutter Speeds
30 seconds to 1/8000th second; user-settable in 1/3 or full-step increments (available shutter speeds vary by shooting mode); plus Bulb
X-sync at 1/250th second with EOS Speedlites
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. or 2-sec. delay
Shutter Lag Time
Approx. 0.059 sec., according to Canon Inc. test methods and criteria
Type
Retractable, auto pop-up flash
Flash Metering System
E-TTL II auto flash; Manual flash and Multi flash also possible.
Guide Number
12/39 (ISO 100, in meters/feet)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready icon lights in viewfinder
Flash Coverage
15mm lens angle of view (equivalent to approx. 24mm in 135 format)
FE Lock
Provided
Flash Exposure Compensation
&plusmn;3 stops in 1/3- or 1/2-stop increments
Zooming to Match Focal Length
Provided
Flash Metering
E-TTL II autoflash
FE Lock
Provided
External Flash Settings
Flash function settings, Flash C.Fn settings
PC Terminal
Provided
Drive Modes
Single, High-speed continuous, Low-speed continuous, and Self-timer (10 sec. self-timer/remote control, or 2-sec. self-timer/remote control)
Continuous Shooting Speed
High-speed: Max. 8.0 shots/sec.
Low-speed: Max. 3.0 shots/sec.
Maximum Burst
JPEG (Large/Fine): approx. 110*/approx. 130**
RAW: approx. 23*/approx. 25**
RAW+JPEG (Large/Fine): approx. 17*/approx. 17**
*Figures based on Firmware upgrade (Version 2.0.X), ISO 100, Standard Picture Style and with 8GB CF memory card.
**Figures apply to 128GB UDMA 7 CF memory card.
Note: UDMA 7 CF memory card read/write speeds are not fully supported with the EOS 7D Digital SLR camera, if using UDMA 7 memory cards, the read/write speeds will be equivalent to UDMA 6
Shooting Modes
Still photo shooting and video shooting
Focusing
Quick mode (Phase-difference detection)
Live mode/Face detection Live mode (Contrast detection)
Manual focusing (5x/10x magnification possible)
Metering Modes
Evaluative metering with the image sensor (still photos)
Center-weighted average metering (video)
Metering Range
EV 1-20 (at 73&deg;F/23&deg;C with EF 50mm f/1.4 USM lens, ISO 100)
Grid Display
Provided (Two-type grid displays)
Exposure Simulation
Provided
Silent Shooting
Provided (Mode 1 and 2)
File Format
MOV (image data: H.264; audio: Linear PCM (monaural))
File Size
Recording Size: 1920 x 1080 (Full HD), 1280 x 720 (SD), 640 x 480 (SD)
Frame Rates
1920 x 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p, 1280 x 720 (HD): 60p (59.94) / 50p, 640 x 480 (SD): 60p (59.94) / 50p
Continuous Shooting Time
Approx. 12 min. (Full HD); 12 min. (HD); 24 min. (SD)
Based on Canon's testing standards using a 4GB card.
Focusing
Autofocus: Quick mode, Live mode, Face Detection Live mode; manual
Exposure Control
Program AE, Manual exposure
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0 in.
Pixels
Approx. 920,000 dots (VGA)
Coverage
Approx. 100%
Viewing angle: 170&deg;
Brightness Control
Auto: Brightness adjusted automatically by the light sensor, Manual: 7 levels provided
Coating
Anti-reflection, anti-dust coatings
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
On LCD Monitor
Electronic level indicates up to 360&deg; roll and ±10&deg; pitch in 1&deg; increments.
In Viewfinder
The AF point display is used to indicate up to &plusmn;6&deg; roll and &plusmn;4&deg; pitch in 1&deg; increments (during vertical shooting, up to &plusmn;4&deg; roll and &plusmn;6&deg; pitch).
Display Format
Single image, Single image + Image-recording quality/shooting information, histogram, 4- or 9-image index, magnified view (approx. 1.5x-10x), rotated image (auto/manual), image jump (by 10/100 images, index screen, by shooting date, by folder), slide show (all images/selected by date/folder)
Highlight Alert
Provided (Overexposed highlights blink)
Items
The following functions can be set (Press "Q" button to access Menu):
Shutter speed, aperture, ISO speed, exposure compensation, AEB, flash exposure compensation, AF point selection (including AF area selection modes), Picture Style, white balance, metering mode, Auto Lighting Optimizer, image-recording quality, AF mode, drive mode, and Custom Controls (camera controls/buttons customization).
Protection
Single images can be erase-protected or not
Erase
Single image, check-marked images or all images in the CF card can be erased (except protected images)
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG images compliant to Design rule for Camera File System (DPOF printing possible) and RAW/sRAW images captured with the EOS 7D
Easy Print feature
Provided
DPOF
Version 1.1 compatible
Compatible Images
JPEG and RAW images
*Only JPEG images can be transferred as wallpaper on the personal computer screen
Custom Functions
Total 27
Custom Controls
The following camera controls can be customized by assigning the desired function: Shutter button halfway pressing, AF-ON button, AE lock button, depth-of-preview button, lens AF Stop button, Multifunction button, SET button, Main Dial, Quick Control Dial, and Multicontroller.
Camera User Settings
Register under Mode Dial's C1, C2 and C3 positions
My Menu Registration
Provided
USB Terminal
For personal computer communication and direct printing (USB 2.0 Hi-Speed), used for connecting the Canon GP-E2 GPS Receiver*
Video Out Terminal
(1) Video OUT terminal: NTSC/PAL selectable
(2) mini-HDMI OUT terminal
Extension System Terminal
For connection to optional Wireless File Transmitter WFT-E5A
Battery
One Battery Pack LP-E6
AC power can be supplied via AC Adapter Kit ACK-E6
With Battery Grip BG-E7 attached.
Number of Shots
Battery Life
The above figures apply with a fully-charged Battery Pack LP-E6 without a Battery Grip
The figures above are based on CIPA (Camera & Imaging Products Association) testing standards
Battery Check
6-level display on top LCD panel.
"Battery Info" in Set-up Menu provides precise charge remaining indication, in 1% increments.
Power Saving
Provided. Power turns off after 1, 2, 4, 8, 15 or 30 min.
Date/Time Battery
One CR1616 lithium-ion battery
Start-up Time
Approx. 0.1 sec. (based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 5.8 x 4.4 x 2.9 in./148.2 x 110.7 x 73.5mm
Weight
Approx. 28.9 oz./820g (body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: EOS 7D: Firmware Version 2.0.6
Advisory Type
Date 11.27.16
Title Canon Support | Service Notice: EOS 5D Mark II and EOS 7D: Locking mode dial modification
Advisory Type
Date 11.30.10
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Canon Support | Service Notice: Charging the Canon Battery Pack LP-E6
Advisory Type
Date 10.06.13
Title Canon Support | Service Notice: EOS 7D: Residual Image in Picture
Advisory Type
Date 11.04.09
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Service Notice: Wireless File Transmitter WFT-E5A: Firmware Update Version 1.0.6
Advisory Type
Date 08.21.11
Title Canon Support | Service Notice: Information on Original Data Security and Original Data Verification Kits
Advisory Type
Date 01.24.15
Title Canon Support | Service Notice: Photo Culling App Version 2.0 for iOS
Advisory Type
Date 11.16.21
Title Canon Support | Service Notice: EOS 7D, EOS 40D, EOS 50D, and EOS 60D: Peripheral AF points do not function as cross-type AF points
Advisory Type
Date 02.20.11
Title Canon Support | Service Notice: Wireless File Transmitter WFT-E5A: Firmware Version 1.0.7
Advisory Type
Date 08.05.12
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
