Canon Support for EOS Digital Rebel | Canon U.S.A., Inc.
EOS Digital Rebel
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type
Type | Digital AF/AE SLR |
Recording Media | Type I and II CF card |
Image Format | 0.89 x 0.59 in. (22.7 x 15.1mm) |
Compatible Lenses | Canon EF including EF-S lenses. (Focal length conversion factor: Equivalent to approx. 1.6x indicated focal length compared to 35mm format.) |
Lens Mount | Canon EF mount |
Image Sensor
Type | High-sensitivity, high-resolution, single-plate, color CMOS |
Pixels | Effective pixels: Approx. 6.3 megapixels |
Total Pixels | Approx. 6.5 megapixels |
Aspect Ratio | 2:3 (Vertical:Horizontal) |
Color Filter System | RGB primary color filter |
Low Pass Filter | Located in front of the imaging element, non-removable |
Recording System
Recording Format | Design rule for Camera File system (JPEG) and RAW. Exif 2.2 compliant |
Image Format | JPEG and RAW (CRW) |
File Size | JPEG: (1) Large/Fine: Approx. 3.1MB (3072 x 2048), (2) Large/ Normal: Approx. 1.8MB (3072 x 2048), (3) Middle/Fine: Approx. 1.8MB (2048 x 1360), (4) Middle/Normal: Approx. 1.2MB (2048 x1360), (5) Small/Fine: Approx. 1.4MB (1536 x 1024), (6) Small/Normal: Approx. 0.9MB (1536 x 1024).RAW: Approx. 7MB (3072 x 2048) |
Folders | Automatic setting |
File Numbering | (1) Serial numbering, (2) Auto reset |
Interface | USB |
White Balance
Settings | Preset: (Auto, daylight, shade, overcast, tungsten bulb, fluorescent light, flash.)Manual : (Custom: read off photo quality gray card or white subject.) |
Viewfinder
Type | Eye-level SLR (with fixed pentamirror) |
Coverage | Approx. 95% vertically and horizontally (Coverage against JPEG Large) |
Magnification | 0.8x (-1 diopter with 50mm lens at infinity) |
Eye Point | 21mm |
Dioptric Adjustment Correction | -3.0 - +1.0 diopter |
Focusing Screen | Fixed |
Mirror | Quick-return half mirror (Transmittance: reflectance ratio of 40:60, no mirror cut-off with lenses up to EF 600mm f/4) |
Viewfinder Information | AF points, AE lock, FE lock, AEB in progress, flash ready, improper FE lock warning, high-speed sync, shutter speed, bulb, FE lock, processing data, aperture, exposure level (exposure compensation, manual exposure level, AEB level, flash exposure compensation, red-eye reduction lamp-on indicator), Max. burst during continuous shooting, AF/MF focus confirmation, CF card full, CF card error and no CF card |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Eyepiece Shutter | None (provided with neckstrap) |
Autofocus
Type | TTL-CT-SIR with AF-dedicated CMOS sensor |
AF Frame | 7 |
AF Points | EV 0.5 -18 (at ISO 100) |
Focusing Modes | One-Shot AF, Predictive AI Servo AF, AI Focus AF (Automatically selects One-Shot AF or AI Servo AF selected according to shooting mode), Manual Focusing (MF) |
AF Point Selection | Automatic selection, manual selection |
Selected AF Point Display | Superimposed in viewfinder and indicated on LCD panel |
AF Assist Beam | Intermittent firing of built-in flash, effective range: approx. 13.1 ft/4m at center, approx. 11.5 ft/3.5m at periphery |
Exposure Control
Metering Modes | Metering Modes: Max. aperture TTL metering with 35-zone SPC. (1) Evaluative metering, (2) Partial metering at center (approx. 9% of viewfinder), (3) Center weighted average metering (in manual exposure mode) |
Metering Range | EV 1-20 (at 68°F/20°C with 50mm f/1.4 lens at ISO 100) |
ISO Speed Range | Equivalent to ISO 100-1600 |
Exposure Compensation | Up to +/-2 stops in 1/3-stop increments (1) AEB (Auto exposure bracketing). (2) Manual exposure compensation. (3) Flash exposure compensation (Flash exposure compensation available only with Speedlite 550EX, Macro Ring Lite MR-14EX, or Macro Twin Lite MT-24EX) |
AE Lock | Auto: Operates in One-Shot AF mode evaluative metering when focus is achieved. Manual: Enabled with AE lock button. No AE lock in Basic Zone modes |
Shutter | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled1/4000 to 30 sec. (1/3 increments), bulb, X-sync at 1/200 sec.Soft-touch electromagnetic release10-sec. delayRemote control with RS-60E3 terminal or wireless Remote Controller RC-1 and RC-5 |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
Shutter Speeds | 1/4000 to 30 sec. (1/3 increments), bulb, X-sync at 1/200 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay |
Remote Control | Remote control with RS-60E3 terminal or wireless Remote Controller RC-1 and RC-5 |
Built in Flash
Type | Auto pop-up, retractable, built-in flash in the pentamirror hump |
Guide Number | 13/43 (at ISO 100 in meters/feet) |
Recycling Time | Approx. 3 sec. |
Flash Ready Indicator | Flash-ready indicator lights on in viewfinder |
Flash Coverage | Up to 18mm focal length (equivalent to approx. 28mm in 35mm format) |
External Speedlite
EOS Dedicated Speedlite | E-TTL autoflash with EX-series Speedlite |
Drive System
Drive Modes | Single, Continuous selected automatically according to shooting mode, Self-timer |
Continuous Shooting Speed | Approx. 2.5 fps (at 1/250 sec. or faster for all recording qualities) |
Maximum Burst | 4 shots |
LCD Monitor
Type | TFT color LCD monitor |
Monitor Size | 1.8 inches |
Pixels | Approx. 118,000 pixels (Displayed pixels) |
Coverage | Approx. 100% (for JPEG images) |
Brightness Control | 5-levels (settable with menu's "LCD brightness") |
Playback
Display Format | (1) Single image, (2) Single image with information, (3) 9-image index, (4) Enlarged, (5) Auto play |
Highlight Alert | In the single image with information display mode, the highlight portions containing no image information will blink |
Image Protection and Erase
Protection | A single image can be protected or unprotected |
Erase | A single image or all images stored in a CompactFlash Card can be erased if they are unprotected |
Menus
Menu Categories | (1) Shooting Menus [8], (2) Playback Menus [4], (3) Setup Menus [14] |
LCD Monitor Language | English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Chinese (simplified), and Japanese. |
Firmware Update | Enabled by the user |
Power Source
Battery | One Battery Pack BP-511/512 (lithium ion rechargeable battery) |
Number of Shots | ConfigurationNo Flash Used50% With Flash BodyNormal temp (68°F/20°C)600 frames400 framesLow temp (32°F/0°c)450 frames350 frames w/BG-E1(BP-511x2)Normal temp (68°F/20°C)1200 frames800 framesLow temp (32°F/0°c)900 frames700 frames |
Dimensions and Weight
Dimensions (W x H x D) | (W x H x D): 5.6 x 3.9 x 2.9 in. / 142 x 99 x 72.4mm |
Weight | 19.7 oz. / 560g |
Operating Environment
Working Temperature Range | 0 - 40°C / 32-104°F |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
