Canon Support for EOS Digital Rebel | Canon U.S.A., Inc.
EOS Digital Rebel
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 06.10.08
File Size 5.33 MB
Date 04.01.07
File Size 3.48 MB
Date 04.16.09
File Size 6.96 MB
Date 10.15.10
File Size 8.08 MB
Date 06.10.08
File Size 10.99 MB
Date 07.23.12
File Size 6.38 MB
Date 01.25.12
File Size 10.69 MB
Date 10.15.10
File Size 8.41 MB
Date 10.01.07
File Size 11.53 MB
Date 07.23.12
File Size 6.88 MB
Date 04.01.07
File Size 268.11 KB
Date 04.14.09
File Size 7.50 MB
Date 10.21.10
File Size 11.20 MB
Date 03.05.10
File Size 12.70 MB
Date 04.01.07
File Size 2.88 MB
Date 01.01.04
File Size 207.90 MB
Date 01.01.04
File Size 292.78 MB
Date 06.10.08
File Size 4.94 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Type Digital AF/AE SLR
Recording Media Type I and II CF card
Image Format 0.89 x 0.59 in. (22.7 x 15.1mm)
Compatible Lenses Canon EF including EF-S lenses. (Focal length conversion factor: Equivalent to approx. 1.6x indicated focal length compared to 35mm format.)
Lens Mount Canon EF mount
Image Sensor
Type High-sensitivity, high-resolution, single-plate, color CMOS
Pixels Effective pixels: Approx. 6.3 megapixels
Total Pixels Approx. 6.5 megapixels
Aspect Ratio 2:3 (Vertical:Horizontal)
Color Filter System RGB primary color filter
Low Pass Filter Located in front of the imaging element, non-removable
Recording System
Recording Format Design rule for Camera File system (JPEG) and RAW. Exif 2.2 compliant
Image Format JPEG and RAW (CRW)
File Size JPEG: (1) Large/Fine: Approx. 3.1MB (3072 x 2048), (2) Large/ Normal: Approx. 1.8MB (3072 x 2048), (3) Middle/Fine: Approx. 1.8MB (2048 x 1360), (4) Middle/Normal: Approx. 1.2MB (2048 x1360), (5) Small/Fine: Approx. 1.4MB (1536 x 1024), (6) Small/Normal: Approx. 0.9MB (1536 x 1024).RAW: Approx. 7MB (3072 x 2048)
Folders Automatic setting
File Numbering (1) Serial numbering, (2) Auto reset
Interface USB
White Balance
Settings Preset: (Auto, daylight, shade, overcast, tungsten bulb, fluorescent light, flash.)Manual : (Custom: read off photo quality gray card or white subject.)
Viewfinder
Type Eye-level SLR (with fixed pentamirror)
Coverage Approx. 95% vertically and horizontally (Coverage against JPEG Large)
Magnification 0.8x (-1 diopter with 50mm lens at infinity)
Eye Point 21mm
Dioptric Adjustment Correction -3.0 - +1.0 diopter
Focusing Screen Fixed
Mirror Quick-return half mirror (Transmittance: reflectance ratio of 40:60, no mirror cut-off with lenses up to EF 600mm f/4)
Viewfinder Information AF points, AE lock, FE lock, AEB in progress, flash ready, improper FE lock warning, high-speed sync, shutter speed, bulb, FE lock, processing data, aperture, exposure level (exposure compensation, manual exposure level, AEB level, flash exposure compensation, red-eye reduction lamp-on indicator), Max. burst during continuous shooting, AF/MF focus confirmation, CF card full, CF card error and no CF card
Depth Of Field Preview Enabled with depth-of-field preview button
Eyepiece Shutter None (provided with neckstrap)
Autofocus
Type TTL-CT-SIR with AF-dedicated CMOS sensor
AF Frame 7
AF Points EV 0.5 -18 (at ISO 100)
Focusing Modes One-Shot AF, Predictive AI Servo AF, AI Focus AF (Automatically selects One-Shot AF or AI Servo AF selected according to shooting mode), Manual Focusing (MF)
AF Point Selection Automatic selection, manual selection
Selected AF Point Display Superimposed in viewfinder and indicated on LCD panel
AF Assist Beam Intermittent firing of built-in flash, effective range: approx. 13.1 ft/4m at center, approx. 11.5 ft/3.5m at periphery
Exposure Control
Metering Modes Metering Modes: Max. aperture TTL metering with 35-zone SPC. (1) Evaluative metering, (2) Partial metering at center (approx. 9% of viewfinder), (3) Center weighted average metering (in manual exposure mode)
Metering Range EV 1-20 (at 68&deg;F/20&deg;C with 50mm f/1.4 lens at ISO 100)
ISO Speed Range Equivalent to ISO 100-1600
Exposure Compensation Up to +/-2 stops in 1/3-stop increments (1) AEB (Auto exposure bracketing). (2) Manual exposure compensation. (3) Flash exposure compensation (Flash exposure compensation available only with Speedlite 550EX, Macro Ring Lite MR-14EX, or Macro Twin Lite MT-24EX)
AE Lock Auto: Operates in One-Shot AF mode evaluative metering when focus is achieved. Manual: Enabled with AE lock button. No AE lock in Basic Zone modes
Shutter Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled1/4000 to 30 sec. (1/3 increments), bulb, X-sync at 1/200 sec.Soft-touch electromagnetic release10-sec. delayRemote control with RS-60E3 terminal or wireless Remote Controller RC-1 and RC-5
Type Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds 1/4000 to 30 sec. (1/3 increments), bulb, X-sync at 1/200 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay
Remote Control Remote control with RS-60E3 terminal or wireless Remote Controller RC-1 and RC-5
Built in Flash
Type Auto pop-up, retractable, built-in flash in the pentamirror hump
Guide Number 13/43 (at ISO 100 in meters/feet)
Recycling Time Approx. 3 sec.
Flash Ready Indicator Flash-ready indicator lights on in viewfinder
Flash Coverage Up to 18mm focal length (equivalent to approx. 28mm in 35mm format)
External Speedlite
EOS Dedicated Speedlite E-TTL autoflash with EX-series Speedlite
Drive System
Drive Modes Single, Continuous selected automatically according to shooting mode, Self-timer
Continuous Shooting Speed Approx. 2.5 fps (at 1/250 sec. or faster for all recording qualities)
Maximum Burst 4 shots
LCD Monitor
Type TFT color LCD monitor
Monitor Size 1.8 inches
Pixels Approx. 118,000 pixels (Displayed pixels)
Coverage Approx. 100% (for JPEG images)
Brightness Control 5-levels (settable with menu's "LCD brightness")
Playback
Display Format (1) Single image, (2) Single image with information, (3) 9-image index, (4) Enlarged, (5) Auto play
Highlight Alert In the single image with information display mode, the highlight portions containing no image information will blink
Image Protection and Erase
Protection A single image can be protected or unprotected
Erase A single image or all images stored in a CompactFlash Card can be erased if they are unprotected
Menus
Menu Categories (1) Shooting Menus [8], (2) Playback Menus [4], (3) Setup Menus [14]
LCD Monitor Language English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Chinese (simplified), and Japanese.
Firmware Update Enabled by the user
Power Source
Battery One Battery Pack BP-511/512 (lithium ion rechargeable battery)
Number of Shots ConfigurationNo Flash Used50% With Flash BodyNormal temp (68&deg;F/20&deg;C)600 frames400 framesLow temp (32&deg;F/0&deg;c)450 frames350 frames w/BG-E1(BP-511x2)Normal temp (68&deg;F/20&deg;C)1200 frames800 framesLow temp (32&deg;F/0&deg;c)900 frames700 frames
Dimensions and Weight
Dimensions (W x H x D) (W x H x D): 5.6 x 3.9 x 2.9 in. / 142 x 99 x 72.4mm
Weight 19.7 oz. / 560g
Operating Environment
Working Temperature Range 0 - 40&deg;C / 32-104&deg;F
Working Humidity Range 85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Safety Notice: Lithium-Ion Battery Pack
Advisory Type
Date 12.31.08
Title Canon Support | Service Notice: EOS Utility
Advisory Type
Date 12.12.19
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
