Canon Support for EOS M10 | Canon U.S.A., Inc.
EOS M10
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
CMOS sensor (supporting Hybrid CMOS AF II)
Pixels
Effective Pixels: Approx. 18.0 Megapixels
Total Pixels: Approx. 18.5 Megapixels
Total Pixels
18.5 megapixels
Aspect Ratio
3:2 (Horizontal: Vertical)
Dust Deletion Feature
Self Cleaning Sensor Unit
(Ultrasonic vibration keeps the front layer of the CMOS sensor free of dust)
Auto / Manual
Recording Format
Design Rule for Camera File System 2.0, Exif 2.3 compliant
JPEG, RAW (14-bit, Canon original)
RAW+JPEG simultaneous recording possible
File Size
L (Large): Approx. 17.9 Megapixels (5184x3456)
M (Medium): Approx. 12.4 Megapixels (4320x2880)
S1 (Small 1): Approx. 5.5 Megapixels (2880x1920)
S2 (Small 2): Approx. 3.5 Megapixels (2304x1536)
S3 (Small 3): Approx. 350,000 pixels (720x480)
RAW: Approx. 17.9 Megapixels (5184x3456)
Folders
Monthly and daily can be selected
Continuous, Auto reset
Settings
Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3
Noise Reduction
Applicable to long exposures and high ISO speed shots
Automatic Image Brightness Correction
Auto Lighting Optimizer
Highlight Tone Priority
Provided
Lens Aberration Correction
Peripheral illumination correction, Chromatic aberration correction
Creative Assist
Background (Blurred-Sharp), Brightness (Dark-Light), Contrast (Low-High), Saturation (Neutral-Vivid), Color Tone (Cool-Warm), Monochrome
Auto White Balance
Auto, Preset (Daylight, Shade, Cloudy, Tungsten light, White fluorescent light, Flash), Custom white balance correction feature available
Type
Hybrid CMOS AF II method (1-point AF, Face+Tracking priority AF)
Focusing Brightness Range
EV 1-18 (at room temperature, ISO 100, with EF-M 22mm f/2 STM)
AF Operation
One-Shot AF, Servo AF
AF Points
49 points (Maximum)
AF Assist Beam
Built-in (LED lamp)
Metering Modes
Real-time metering using the image sensor
Evaluative metering
Partial metering
Spot metering
Center Weighted Avg.
Metering Range
EV 1-20 (at room temperature, ISO 100)
Exposure Control Systems
(1) Program AE (modes other than Tv, Av, and M)
(2) Shutter-priority AE
(3) Aperture-priority AE
(4) Manual exposure
ISO Speed Range
Automatically or manually set in a range of ISO 100-12800 (equivalent to 25600 when expanded)
Max. auto ISO speed can be configured when mode dial is set to P, Tv, Av, M, or Movie mode
* Flicker detection
Exposure Compensation
Manual: &plusmn;3 stops in 1/3-stop increments
AE Lock
(1) Auto AE lock in the One-Shot AF mode with evaluative metering, AE is locked as soon as subjects are in focus.(2) Manual AE lock Performed using the AE lock button.
Type
Electronically controlled focal-plane shutter
Shutter Speeds
1/4000 sec. to 30 sec. (total shutter speed range; available range varies by shooting mode), X-sync at 1/200 sec.
Type
Retracting, manual pop-up flash
Guide No. approx. 5m (at ISO 100)
Supports angle of view equivalent to focal length of approx. 15mm (35mm film equivalent: approx. 24mm)
Recharging time: approx. 3 sec.
* Safety FE supported
* Recharging time when using a fully charged battery pack
AF Operation
Range of Flash Photography (Approx.)
(Approx. ft. [m])
Flash Metering System
E-TTL II autoflash
FE Lock
Provided
Flash Exposure Compensation
&plusmn;stops in 1/3-stop increments
FE Lock
Provided
Drive Modes
Single shooting, Continuous shooting
Continuous Shooting Speed
(1) One-Shot AF (all lenses): Max. approx. 4.6 fps
(2) Servo AF (with EF-M 15-45mm f/3.5-6.3 IS STM at the telephoto end):
Max. approx. 2.2 fps
* Under default settings, with a shutter speed of 1/500 sec. or higher.
* Continuous shooting speed may be lower depending on shutter speed, aperture value, subject conditions, brightness, type of lens, flash use, battery level and other factors.
Maximum Burst
* Image file size, number of possible shots, and maximum burst during continuous shooting are measured based on Canon's testing standards (3:2 aspect ratio, ISO 200, and Standard Picture Style), using a UHS-I compatible, 16 GB memory card that meets Canon's testing standards. These values vary depending on the shooting conditions. Self-timer Mode
Off, 2-second self-timer, 10-second self-timer, Custom timer
Focusing
AF, MF, AF+MF (MF, and MF in AF+MF mode: approx. 5x/10x magnification and MF peaking supported)
Aspect Ratio Settings
3:2, 4:3, 16:9, 1:1
Continuous AF
Provided
Touch Shutter
Provided
Depth-of-Field Preview
Provided
Metering Modes
(1) Evaluative metering (384 zones)
(2) Partial metering (approx. 10%)
(3) Spot metering (approx. 2%)
(4) Center Weighted Avg.
Metering Range
Grid Display
Two types
File Format
Recording System
MP4
MPEG-4 AVC / H.264
Variable (averaged) bit rate
File Size
1920 x 1080 (Full HD): 29.97 fps / 23.98 fps*
1280 x 720 (HD): 59.94 fps
640 x 480 (SD): 29.97 fps
* Actual frame rate: 23.976 fps.
Continuous Shooting Time
*1 Recording bit rate of movie images only, sound data not included.
*2 Continuous shooting is possible until the memory card becomes full or the recording length for one movie reaches approx. 29 minutes 59 seconds.
*3 Actual frame rate is 23.976 fps.
Focusing
Hybrid CMOS AF II system (1-point AF, Face+Tracking priority AF)
Focus Mode
AF, MF, AF+MF (Manual focus after One-Shot AF)
(MF, and MF in AF+MF mode: MF peaking supported)
Servo AF
Can be paused and resumed.
Brightness Metering Range
Metering Mode
Evaluative metering
Miniature Effect Movie
Provided
Still Image Shooting
Provided
Grid Display
Grid Display
Sound Recording
Built-in stereo microphone, recording level adjustable, wind filter provided, attenuator provided
Range
EV 1-18 (at room temperature, ISO 100)
Exposure Control
Movie auto exposure mode, miniature effect movie mode, still image mode:
Shutter speed of 1/30 to 1/4000 sec.*, with aperture and ISO speed set automatically.
Movie manual exposure mode:
Shutter speed of 1/30 to 1/4000 sec.*, with aperture and ISO speed (auto or a specific value) set manually.* The minimum shutter speed is limited to 1/30 sec. at 24/25/30 fps or 1/60 sec. at 50/60 fps.
±3 stops in 1/3-stop increments
Type
TFT color, liquid-crystal monitor
Angle Adjustment
Tilt type: Approx. 180° upward
Monitor Size
Wide 3.0-inches (Screen aspect ratio 3:2)
Pixels
Approx. 1.04 million dots
Brightness Control
Manual (5 levels)
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
Single image display, single image + info display (basic info, shooting info, histogram, lens info, Picture Style, noise reduction, correction data), image index (6/12/42/110), image rotate possible
Zoom Magnification
Approx. 1.5x to 10x
Highlight Alert
Overexposed highlights blink
Image Browsing
Single image, jump by 10 or 100 images, filter images (by shooting date, by people, by movies, by stills, by rating), Scroll Display
Image Rotate
Rating
Rating
Provided
Image Search
Rating, Shot Date, People, Stills, Movie Digest
Movie Playback
Enabled
Protect Images
Provided
Slideshow
All images
* Playback is also possible after filtering the images using Image Search.
Compatible Printers
PictBridge (USB and Wireless LAN)
Printable Images
JPEG and RAW images (can print RAW images displayed as JPEG only with images taken with the same model), MP4
Custom Functions
6 types
Copyright Info
Entry and inclusion possible
USB Terminal
For communications with a computer and PictBridge (Hi-Speed USB equivalent)
Video Out Terminal
Type C (Switches resolution automatically)
Wi-Fi&reg; (Wireless LAN)
IEEE 802.11b/g/n
Transmission Method
DS-SS modulation (IEEE 802.11b), OFDM modulation (IEEE 802.11g/n)
Transmission Range
Approx. 15m (49 ft.)
When connected to a smartphone or tablet
With no obstructions between transmitting and receiving antennas, and there is no radio interference
Transmission Frequency (Central Frequency)
Frequency: 2412-2462 MHz, Channels: 1-11 ch
Connection Method
Infrastructure mode*, Camera access point mode, Ad hoc mode* Wi-Fi&reg; Protected Setup supported
Security
Authentication method: Open system, WPA-PSK, WPA2-PSKEncryption: WEP, TKIP, AES
Transfer Images Between Cameras
Transferring one image, transferring selected images, transferring resized images
Connection to Smartphones
Viewing, controlling, receiving images using a smartphone
Sending images to smartphone connected via NFC
Remote control of the camera using a smartphone
Print from Wi-Fi&reg; Printers
Images to be printed can be sent to a printer supporting Wi-Fi®
Send Images to a Web Service
Images in the camera or links to images can be sent to registered Web services
View Images Using a Media Player
Images can be viewed using a DLNA-compatible media player
Battery
One Battery Pack LP-E12
*AC power can be supplied with the AC Adapter Kit ACK-E12
Battery Life
Still images:
* Based on CIPA measurement methods.
* With fully charged battery pack LP-E12.
* When EF-M 15&#150;45mm f/3.5&#150;6.3 IS STM is used.
Movies:
*1 Maximum recordable time under default movie mode settings with repeated capture after the maximum recording time for one movie has been reached.
*2 Maximum recordable time under default movie mode settings with operation of record, pause, power on/off, zoom, and other controls.
Dimensions (W x H x D)
Approx. 4.25 x 2.62 x 1.38 in. (108.0 x 66.6 x 35.0mm)
Weight
Approx. 10.6 oz. / 301g (Including body + battery pack + card)
Approx. 9.35 oz./ 265g (Body only, excluding lens cap)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: EOS M10: Firmware Version 1.1.1
Advisory Type
Date 02.12.20
Title Canon Support | Firmware Notice: EOS M10: Firmware Version 1.1.0
Advisory Type
Date 05.21.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
