Canon Support for EOS M50 Mark II | Canon U.S.A., Inc.
EOS M50 Mark II
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital Single-Lens Non-Reflex AF/AE Camera With Built-In Flash Image Processor |
Recording Medium | SD/SDHC/SDXC Memory Cards &Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp; UHS-I Compatible |
Compatible Lenses | Canon EF-M Lens Group &Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp; Using Mount Adapter EF-EOS M: Canon EF Or EF-S Lenses. &Nbsp;&Nbsp;&Nbsp;&Nbsp;&Nbsp; RF Mount Lenses Cannot Be Used. |
Lens Mount | Canon EF-M Mount |
Type | CMOS Sensor (Supporting Dual Pixel CMOS AF) |
Pixels | Effective Pixels: Approx. 24.1 Megapixels Total Pixels: Approx. 25.8 Megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) Screen Size |
Type | Dual Pixel CMOS AF (1-Point AF, Spot AF, Face+Tracking Priority AF, Zone AF) | ||||
Af Points | Still Photo Shooting: Up To 143 Zones (Maximum) Video Shooting: Up To 117 Zones (Maximum) Focusing Brightness Range AF Operation Touch & Drag AF Tap To Select Subject
Af Assist Beam | Built-In LED Lamp |
Metering Modes | 384-Zone (24x16) Metering Using The Image Sensor. |
Metering Range | Stills: EV -220 (At Room Temperature 73&Deg;F/23&Deg;C, ISO 100) Video: EV 020 (At Room Temperature 73&Deg;F/23&Deg;C, ISO 100) |
Exposure Control Systems | Via SHOOTING MODE In Menu: Program AE, Shutter-Priority AE, Aperture-Priority AE, Or Manual (B Is Selected As Shutter Speed Setting In Manual Mode) |
Iso Speed Range | Stills: ISO 10025600 (In 1/3-Stop Increments) Video: ISO 100-12800; H: 25600 |
Exposure Compensation | Manual: &Plusmn;3 Stops In 1/3-Stop Increments |
Ae Lock | Manual, Auto (Exposure Locked After Focusing, In One-Shot AF With Evaluative Metering) |
Type | Electronically Controlled Focal-Plane Shutter * Electronic 1st / Mechanical 2nd Curtain * Except When Silent Mode Is Set Rolling Shutter, Using The Image Sensor * Electronic Shutter * When Silent Mode Is Set |
Shutter Speeds | Creative Zone: 1/4000 To 30 Sec., Bulb * X-Sync At 1/200 Sec. Basic Zone: 1/4000 To 1 Sec. * Varies Depending On Shooting Mode |
Type | Manual Pop-Up Flash (Max. Guide Number Approx. 16.4 [Ft] / 5.0 [M], At ISO 100) |
Flash Metering System | Evaluative (Face Priority) / Evaluative / Average |
Fe Lock | Provided |
Flash Exposure Compensation | &Plusmn;2 Stops In 1/3-Stop Increments Continuous Shooting Priority (CSP) Mode External Flash |
Continuous Shooting Speed |
*1 Conditions For Maximum Continuous Shooting Speed Are As Follows: Fully Charged Battery Pack LP-E12, Shutter Speed: 1/1000 Sec. Or Faster, Room Temperature (73°F/23°C), 12 Bit Self-Timer Mode |
File Format | Video: MPEG-4 AVC / H.264 Variable (Averaged) Bit Rate Audio: AAC Recording System Live Streaming Recording Size And Frame Rate
*1The Image Is Cropped Around The Center Of The Image Sensor. |
Continuous Shooting Time |
* Limitations Of Video Shooting: Continuous Shooting Is Possible Until The Memory Card Becomes Full Or The Recording Length For One Video Reaches Approx. 29 Minutes And 59 Seconds (Or 7 Min. 29 Sec. For A HD High Frame Rate Movie). |
Exposure Compensation | &Plusmn;3 Stops In 1/3-Stop Increments Movie Exposure Modes Metering Mode ISO Speed (Recommended Exposure Index) Miniature Effect Movie Still Image Shooting Sound Recording Card Performance Requirements
Type | TFT Color Liquid Crystal Monitor Menu Magnification Brightness Adjust-Ment Angle Of View Hints & Tips |
Screen Monitor Size | 3.0-Inch Type |
Pixels | Approx. 1.04 Million Dots |
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese) |
Image Display Format | Single Image, Or 4, 9, 36, Or 100-Image Index Viewing Options Via INFO Button: Full Image, Full Image With Basic Info, Thumbnail Image With Histogram And Detailed Shooting Info, RGB And Brightness Histograms With Lens Info Playback Methods Zoom Magnification Image Browsing Methods
Image Rotate Rating Video Playback Playback Time Slideshow
Compatible Printers | PictBridge |
Printable Images | JPEG RAW / C-RAW |
Custom Controls | Stills :Shutter Button, AE Lock Button, Multi-Function Button, Movie Button, Exposure Comp. Button, AF/MF Button, Flash Button, Erase Button. Movie:AE Lock Button, Multi-Function Button, Exposure Comp. Button, AF/MF Button, Flash Button, Erase Button Custom Functions Copyright Info |
Usb Terminal | USB Micro-B (Hi-Speed USB 2.0 Compliant) |
Video Out Terminal | HDMI Type D (Resolution Switches Automatically) HDMI Output While Recording (Shooting Screen Without Sound) Provided CEC Not Supported Wireless Remote Control |
Battery | Battery Pack LP-E12 | ||||||||||||||||||||||
Battery Life |
* With A Fully Charged LP-E12 Battery. |
Dimensions W X H X D | Approx. 4.58 X 3.47 X 2.31 In. (116.3 X 88.1 X 58.7mm) CIPA Compliant. |
Weight | Black: Approx. 13.65 Oz. / 387g (Including Battery Pack And Memory Card) Approx. 12.35 Oz. / 350g (Body Only) White: Approx. 13.69 Oz. / 388g (Including Battery Pack And Memory Card) Approx. 12.38 Oz. / 351g (Body Only) * Without Body Cap * 1: Based On CIPA Guidelines |
Operating Temperature Range | 32-104&Deg;F / 0-40&Deg;C |
Operating Humidity Range | 85% Or Less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
