Canon Support for EOS R6 Mark III | Canon U.S.A., Inc.
EOS R6 Mark III
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Type | Digital interchangeable lens mirrorless camera |
| Image Processor | (one) DIGIC X |
| Recording Media | Card 1: CFexpress Type B (2.0) memory card; 8TB maximum For firmware upgrades from CFexpress card, max. card size is 2TB Card 2: SDXC / SDHC / SD memory card; UHS-II compatible Eye-Fi and MultiMedia Cards (MMC) not compatible |
| Compatible Lenses | Canon RF and RF-S lenses Canon EF, EF-S, TS-E, and MP-E lenses (with optional Mount Adapter EFEOS R) |
| Lens Mount | Canon RF mount |
| Type | Canon full-frame CMOS sensor (compatible with Dual Pixel CMOS AF) |
| Effective Pixels | Approx. 32.5 million pixels |
| Sensor Size | Approx. 35.9 x 23.9mm |
| Pixel Size | Approx. 5.16µm square |
| Total Pixels | Approx. 34.2 million pixels |
| Aspect Ratio | 3:2 (Horizontal: Vertical) |
| Color Filter System | RBG primary colors |
| Low-pass Filter | Installed at front of sensor; non-removeable |
| Dust Deletion Feature Self Cleaning Sensor Unit | Auto cleaning: at Power Off / Enable (at power On Off) / Disable Clean now: User-activated cleaning Clean manually: Shutter opened to allow user cleaning by hand |
| Recording Format | DCIF (Design rule for Camera File system 2.0; EXIF 2.31) |
| Image Format | Still image format: RAW: Canon RAW / C-RAW JPEG / HEIF: L / M / S1 / S2 Movie image format: RAW XF-HEVC S YCC 422 10-bit XF-HEVC S YCC 420 10-bit XF-AVC S YCC 422 10-bit XF-AVC S YCC 420 8-bit |
| Folder | Automatically created when card is inserted: DCIM / CRM / XFVC / and MISC folders |
| Folder Actions | Select folder / Create folder / Change folder name |
| Still Images | DCF standards compliant Default (within DCIM folder) xxxxEOSR6 Can be changed by user to any 5-character string |
| Movies | XFVC folder: XF-HEVC S / XF-AVC S file formats REEL_xxxx (MP4 video file in XFVC folder) CRM folder: RAW video files (.CRM) REEL_xxxx Up to 999 files can be saved in each REEL_xxxx folder |
| News Metadata | Saved in same location as movie file on card (.XML file) |
| Settings | Auto (AWB); includes Ambience priority / White priority Daylight Shade Cloudy Tungsten light White fluorescent light Flash Custom WB Color Temp (four manual user settings available; K1 K4) |
| White Balance | Shift Blue / Amber bias: ±9 levels Magenta / Green bias: ±9 levels Blue/amber and magenta/green shift can be combined WB Bracketing available; ±3 levels |
| Type | OLED color electronic viewfinder / 0.5 inch / approx. 3.96 million dots |
| Coverage | Approx. 100% (H x V) |
| Magnification | Approx. 0.76x |
| Eyepoint | Approx. 23mm (at -1 m-1 from eyepiece end) |
| Exposure Simulation | Exposure + Depth-of-field / Exposure / Exposure only during DOF preview Can be disabled |
| Optical Viewfinder Simulation | (OVF simulation view assist) Available; applies to viewfinder and screen |
| Grid Display | Off / 3x3 / 6x4 / 3x3 + diagonal Available for viewfinder and LCD screen |
| Type | TFT color, liquid-crystal monitor |
| Size | 3.0 inch (3:2 aspect ratio); diagonal approx. 1.65 in. / 4.2 cm |
| Resolution | Approx. 1.62 million dots |
| Touch-Screen Operation | Yes (capacitive sensing) |
| Vari-Angle Adjustment | Opening angle: approx. 0 175° Rotating angle: forward approx. 0 90° / backward approx. 0 180° |
| Coatings | Anti-smudge coating (Anti-reflection coating not applied) |
| Magnified View (still images) | 1.5x 10x |
| AF Point Display (still images) | Available |
| Highlight Alert | Available (blinking highlights) |
| Auto Rotate | On (display + computer / On (computer only) / Off Video: via Change movie rotation information |
| Search (video files only) | By rating / Date / Folder / Protection / Type of file (1) / Type of file (2) Available for video files in XFVC or CRM folders only |
| Ratings Star: | Off / Star ratings 1 5 |
| Protect Images | Select images / Select range / All images in folder / Unprotect all images in folder / Unprotect all images on card / All found images / Unprotect all found images |
| Image Copy (to card in camera) | Select images / Select range / Selecct folder / All images Still images only |
| Focus Type | Dual Pixel CMOS AF (from CMOS imaging sensor) |
| AF Zones for Auto Selection | Still images: max. 1,053 zones Movies: max. 897 zones With focusing area approx. 100% x 100% |
| Selectable AF Point Positions | Still images: max. 6,097 positions Movies: max. 4,641 positions User-adjustable AF point positioning over approx. 90% (H) x 100% (V) |
| AF Brightness Range | Still images: EV -6.5 21 Movies: EV -4 21 With f/1.2 lens (except DS lenses); center AF point; One-shot AF; ISO 100 |
| AF Areas | Spot AF 1-point AF Expand AF (4-point expansion) Expand AF (8-point Around expansion) Flexible Zone AF 1 Flexible Zone AF 2 Flexible Zone AF 3 Whole Area Tracking OFF Spot AF Whole Area Tracking OFF 1-point AF Whole Area Tracking OFF Expand AF (4-point expansion) Whole Area Tracking OFF Expand AF (8-point Around expansion) |
| AF Subject Detection | Auto People Animals (dogs / cats / birds / horses) Vehicles (motorsports cars & motorcycles / aircraft / trains) Certain types of animals or vehicles may not be detectable |
| Eye Detect AF | Auto (camera selects most prominent eye for focusing) Right Eye (prioritizes subjects right eye) Left Eye (prioritizes subjects left eye) |
| Metering Modes (stills) | Evaluative metering (linked to active AF point / Area) Partial metering (approx. 6.2% of image area, at center of EVF / Screen) Spot metering (approx. 2.9% of image area, at center of EVF / Screen) Center-weighted average metering Partial and Spot metering: circle appears at center of EVF or LCD screen Spot metering cannot be linked to off-center AF point locations |
| Metering Modes (video) | Evaluative (only) |
| Metering Range | (still images) EV -3 20 (video) EV -1 20 |
| Exposure Modes (stills) | P (Program AE) Fv (Flexible-priority AE) Tv (Shutter-priority AE) Av (Aperture-priority) M (Manual exposure) B (Bulb exposure) C1 C3 (Custom shooting modes) |
| SCN (Special Scene Modes; Still Images) | Portrait / Smooth skin / Group photo / Landscape / Panoramic shot / Sports / Kids / Panning / Close-up / Food / Handheld Night Scene / HDR Backlight Control / Silent shutter |
| Exposure Modes (video) | P (Movie auto exposure) Tv (Movie shutter-priority) Av (Movie aperture priority) M (Movie manual exposure) Fv, B modes (Movie auto exposure) |
| SCN (Special Scene Modes; Video Recording) | Smooth skin movie / Movie for close-up demos / Movie IS / HDR movies |
| ISO Speed Range (stills) | Normal ISO 100 64,000 Expanded ISO 50 102,400 Minimum ISO 200 when Highlight Tone Priority is active |
| ISO Speed Range (video) ISO 100 25,600 | ISO range varies, depending on Custom Picture and similar settings Expanded max. ISO 102,400 (varies, depending on settings) |
| Auto ISO Range (stills) | Minimum: L (ISO 50) or 100 ISO 51,200 (expandable to ISO 102,400) B mode: ISO 400 With flash: ISO 100 6400 (minimum ISO 200, with Highlight Tone Priority) |
| Auto ISO Range (video) | ISO 100 25,600 (expandable up to ISO 102,400) Minimum and expanded ISO settings depend upon other video settings) |
| Exposure Compensation | ±0.3 3 stops, in 1/3 or 1/2 stop increments |
| Auto Exposure Bracketing | ±0.3 3 stops, in 1/3 or 1/2 stop increments Can be combined with Exposure compensation |
| AE Lock | Applied automatically: can be user-defined for different metering modes Applied manually: via AE Lock button (or button customized for AE Lock) |
| Type | Electronically-controlled focal-plane shutter |
| Shutter Modes (stills) | Electronic 1st-curtain Mechanical Electronic (flash shooting not possible) |
| Shutter Speeds (stills) | 1/8000 30 seconds (set in 1/3 or 1/2-stop increments, in M or Tv modes) (Maximum speed with Electronic shutter 1/16,000 sec.) |
| X-sync Speed | Electronic 1st-curtain 1/250 sec. Mechanical shutter 1/200 sec. Sync speed priority: maximum x-sync speed 1/320 (1st-curtain) or 1/250 (mechanical) Maximum flash power reduced with Sync Speed priority active |
| Self-timer | 10 sec. / 2 sec. / Continuous Continuous self-timer: 2 9 shots fired continuously, after 10 sec. delay |
| Shutter Type (movies) | Rolling shutter, using CMOS image sensor |
| Movie Shutter Speed Range | 1/8000 slowest speed (based on movie FPS rate) 179.8 FPS: 1/200 sec. 150.0 FPS: 1/160 sec. 119.9 FPS: 1/125 sec. 100.0 FPS: 1/100 sec. 59.94 FPS: 1/60 sec. 50.00 FPS: 1/50 sec. 29.97 FPS: 1/30 sec. 25.00 / 24.00 / 23.98 FPS: 1/25 sec. M (Manual) movie mode 1/8000 1/8 sec. |
| Shutter Durability | Tested to 500,000 exposures (Mechanical shutter mode), by Canon engineers |
| Drive Modes (still images) | High speed continuous+ (Mechanical / 1st-curtain Electronic shutter 12 FPS) (Electronic shutter 40 FPS) High Speed Continuous (Mechanical shutter 6.2 FPS; 1st-curtain Electronic 8.2 FPS) (Electronic shutter 20 FPS) Low Speed Continuous (Mechanical / 1st-curtain Electronic shutter 3.0 FPS) (Electronic shutter 5.0 FPS) |
| Pre-continuous Shooting (still images) | Records 20 shots (approx. 0.5 sec.) before shutter button fully pressed RAW, C-RAW or JPEG images available Electronic shutter automatically applied for Pre-continuous shooting Flash photography, AEB shooting, and some other functions not available |
| Still-image IS | In-body Image Stabilization (IBIS), using CMOS image sensor Coordinated IS combined IBIS + optical IS, with IS lenses Coordinated IS correction: Center 8.5 stops correction; Peripheral 7.5 stops Tested confirming to CIPA 2024 standards, using Canon RF24-105mm F2.8 L IS USM lens |
| Movie Digital IS | 5-axis digital stabilization, at CMOS image sensor Independently activated (vs. IBIS); Coordinated IS available (Movie Digital IS + IBIS + lens optical IS [if available]) |
| Accessory Shoe | Canon Multi-function accessory shoe Optional Canon AD-E1 adapter required for conventional flashes and shoe-mount accessories |
| Compatible Speedlites | Canon EL- and EX-series speedlites Optional Canon AD-E1 adapter required for speedlites without digital electronic contacts for Multi-function shoe |
| Auto Flash Exposure | E-TTL only (conventional off-the-film TTL not available) |
| E-TTL Balance | Ambience priority / Standard / Flash priority |
| Canon Wireless E-TTL | RT (radio transmission) only, with compatible Speedlites and RT Transmitters |
| Flash Exposure Compensation | ± 0.3 3 stops, in 1/3 or 1/2-stop increments |
| Continuous E-TTL Control | E-TTL each shot / E-TTL for 1st shot |
| HDR shooting (PQ) | Available Still images: 10-bit HEIF images; YCbCr 4:2:2; Rec. ITU-R BT-2100 (PQ) Video: Depends on recording format setting |
| HDR Mode | Still images: Off / Moving subject / Dynamic range Moving subject one image taken for each shutter press Dynamic range three source images taken, at Auto or user-defined bracketed exposure settings; processed result written to memory card |
| HDR Movie Mode | (MP4 movies only) HDR movie created; one exposure for each video frame Controls excessive highlight brightness Movie HDR mode also available when set to SCN modes |
| Maximum Recording Times | Less than 100.0 FPS: maximum 6 hours 00 minutes Over 100 FPS: maximum 2 hours 00 minutes Recording time can be shorter, from factors such as heat shut-down, power source depletion, camera settings, etc. |
| Overheating Shut-Down Times (at 73°F / 23°C, internal and external temperatures) | 4K DCI Fine / 59.94 FPS / Standard LGOP no restrictions 4K DCI Fine / 29.97 FPS / Standard LGOP no restrictions 4K DCI / 29.97 FPS / Standard LGOP no restrictions RAW 59.94 FPS / Light (RAW) and 2K Proxy / Std. LGOP 23 min. 4K DCI / 119.9 FPS / Standard LGOP 28 min. (35 min. at High temp) 4K DCI Fine / 59.94 FPS / Standard LGOP 23 min. Open Gate (MP4) / 29.97 FPS / Standard LGOP 24 min. |
| Overheat Warning | Thermometer icon, and 10-stage analog scale to indicate rising temperatures |
| Open Gate Recording | Video recorded from full area of CMOS image sensor (3:2 initial aspect ratio; 7K resolution) 7K RAW or MP4 recording possible with Open Gate, to 29.97/25.00 FPS) |
| Canon Log Recording | Canon Log 2 / Canon Log 3 available (in Custom Picture menu) |
| Custom Picture (CP) | Canon 709 / Canon Log 2 / Canon Log 3 / PQ / HLG / BT.709 Standard Available for video recording only |
| Video Recording Resolutions, FPS Speeds | RAW: Standard RAW; Light RAW 7K recording; 17:9 or Open Gate with 3:2 aspect ratio 7K ProRes RAW recording to compatible external recorders (HDMI) MP4: 4K (DCI or UHD) to 120 FPS (with sound) MP4 4K Fine (oversampled): DCI or UHD to 29.97/25.00 FPS MP4 4K Fine (oversampled): DCI or UHD to 59.94/50.00 FPS MP4 4K (not oversampled): DCI or UHD to 119.9/100.00 FPS (with sound) MP4 2K (DCI) or Full HD: to 119.9/100.00 FPS (with sound) |
| Video Recording Formats | RAW: Canon RAW (.CRM file extension); 12-bit MP4: XF-HEVC S H.265 / HEVC (YCbCr 4:2:2; 10-bit) XF-HEVC S H.265 / HEVC (YCbCr 4:2:0; 10-bit) XF-AVC S H.264 / MPEG-4 AVC (YCbCr 4:2:2; 10-bit) XF-AVC S H.264 / MPEG-4 AVC (YCbCr 4:2:0; 8-bit) |
| Proxy Movie Recording | Card 1 (Main movie) RAW, 4K (DCI or UHD), 2K, or Full HD recording Card 2 (Proxy file) 2K DCI (when Main movie set to DCI) or Full HD / UHD (when Main movie set to UHD aspect ratio) Available when Main movie set to 7K recording |
| Main / Sub Recording | Card 1 (Main movie) RAW or Light RAW only Card 2 (Sub movie) 4K DCI Fine (automatically set) User-selectable Sub movie format and compression available |
| S&F (Slow & Fast Recording) | Recording FPS: 180 1.0 FPS Some restrictions, depending on movie record format, resolution, etc. Playback FPS: (NTSC video system) 23.98, 24.00, 29.97, or 59.94 FPS (PAL video system) 24.00 FPS, 25.00 FPS, 50.00 FPS |
| Time-lapse Movie Recording | Interval between frames: 2 seconds 99:59:59 Shutter count: 2 frames 3,600 frames Recording size: 4K UHD / Full HD Playback speed 29.97 / 25.00 FPS (approx. 2 minutes for 3,600 frames) |
| Time Code | Available |
| Pre-recording (movies) | Records 3 or 5 seconds of video, before user begins video recording 3 / 5 seconds Pre-recording set by user |
| Video Displays (viewfinder + screen) | Grid display / Histogram / Waveform monitor / Zebra display / False color display / Electronic level / Recording emphasis / Aspect Marker 1 & 2 |
| Built-in Microphone | Stereo mic, on top of camera body (right and left of prism) 48 kHz; 24 or 16 bit; 2 channels |
| External Microphone Terminal | 3.5mm diameter stereo mini-jack (3-pin) Plug-in power supported |
| Multi-function Shoe Input | Compatible with Canon Directional Stereo Microphone DM-E1D |
| Headphone Terminal | 3.5mm diameter stereo mini jack Audio monitoring possible via headphone terminal, or HDMI |
| DPOF Compatibility | DPOF version 1.1 (Digital Print Order Format) PictBridge not available |
| Print Type | Standard / Index / Both |
| Photobook Set-Up | None |
| Start-up Password | 6-digit password (set by user) required first time camera turned on,
or when [Clear Entered Information] is performed in-camera Password normally required at each start-up, or when awakening from sleep Password request can be set to OFF, by user Password can be changed at any time by user |
| Wi-Fi (Wireless LAN) | 5.0 GHz / 2.4 GHz band FTP transfer / EOS Utility / Image.canon / Canon Camera Connect / Content Transfer Professional / Camera Control API |
| Maximum Link Speed | 5.0 GHz: (IEEE 802.11ac) 433 Mbps (IEEE 802.11n) 150 Mbps (IEEE 802.11a) 54 Mbps 2.4 GHz: (IEEE 802.11n) 72 Mbps (IEEE 802.11g) 54 Mbps |
| Frequency; Channels | 5.0 GHz: 5180 5825 MHz; 36 to 165 channels 2.4 GHz: 2412 2462 MHz; 1 to 11 channels |
| Wireless LAN Setting Method | Connect via wizard / Connect via Wi-Fi Protected Setup |
| Wired LAN | None |
| Version | Bluetooth Specification Version 5.1 compliant |
| Transmission Method | GFSK modulation |
| Bluetooth Communication Functions | Canon Camera Connect App / Canon Bluetooth remote controller BR-E1 |
| Bluetooth Pairing | Smartphone up to 10 units; BR-E1 remote controller 1 unit |
| Live Streaming via USB | Possible via compatible computers, using software on computer and USB cord USB Power Delivery supported; requires power supply 5 V / 1.5 A or more) Video only; not possible during S&F recording, or still-image shooting Only P / M / Smooth skin movie modes can be set |
| Live Streaming Formats | Video: Motion JPEG compression method; YCC 4:2:2 color sampling; 8-bits; Custom Picture supported; Recording range Full range |
| Resolution / FPS Rates | 4K 30 FPS; 4K 60 FPS (not available in Smooth skin movie mode); Full HD 60 FPS; Full HD 30 FPS 60 or 30 FPS, regardless of NTSC / PAL settings |
| USB Terminal | USB-C (equivalent to USB 10 Gbps / SuperSpeed Plus USB / USB 3.2 Gen 2) |
| HDMI Terminal | Type A size |
| Remote Control Terminal | Canon E3 type terminal (single-pin connector into camera Optional Canon RA-E3 Remote Controller Adapter allows Canon 3-pin (N3) to be connected |
| External Mic IN Terminal | 3.5mm diameter stereo mini jack (3-pin) |
| Headphone Terminal | 3.5mm diameter stereo mini jack |
| Flash Sync Terminal | None |
| Battery | Canon LP-E6P battery pack Canon LP-E6N and LP-E6NH battery packs compatible, with limitations in features and performance Canon LP-E6 battery pack cannot be used Canon Battery Charger LC-E6 (included) charges all LP-E6 type batteries |
| Optional Battery Grip | Canon Battery Grip BG-R20 (optional accessory) Canon Battery Grip BG-R20EP can be used, but Ethernet not available) Canon Battery Grip BG-R10 can be used, but functionality is limited, regardless of battery type installed in grip |
| USB Charging | Canon USB Power Adapter PD-E2 or PD-E1 recommended (other USB power supplies cannot be guaranteed for proper operation) Requires an authenticated battery pack in-camera |
| USB Power to Camera | Requires a battery to be installed in-camera Switches to charging installed battery, when camera main power turned off |
| AC Power Supply | Canon DC Coupler DR-E6P and USB Power Adapter PD-E2 Canon Power Adapter PD-E1 cannot be used DC Coupler DR-E6 cannot be used AC Adapter kit ACK-E6 cannot be used |
| Number of Shots Available | Viewfinder shooting: Power saving 390 shots; Smooth 270 shots LCD screen shooting: Power saving 620 shots; Smooth 510 shots Based on CIPA test standards, at 73°F / 23°C Using new, fully-charged Canon LP-E6P battery pack Number of shots can vary greatly, depending on shooting conditions, etc. |
| Video Recording Time Available | RAW (Light RAW) approx. 1 hr. 00 min. 4K DCI (59.94 / 50.00 FPS) approx. 1 hr. 00 min. Full HD (29.97 / 25.00 FPS) approx. 2 hr. 40 min. Movie playback time (4K DCI at 59.94 / 50.00 FPS) approx. 3 hr. 40 min. At 73°F / 23°C, using new, fully-charged Canon LP-E6P battery pack |
| Dimensions: W x H x D | 5.45 x 3.87 x 3.48 in. / 138.4 x 98.4 x 88.4 mm |
| Weight | Approx. 24.66 oz. / 1.54 lbs. / 699g Body only, with battery and one card installed |
| Operating Environment | 32°F 104°F / 0°C 40°C Relative humidity 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
next to your download
