Canon Support for EOS R8 Mark II Camera (Body) | Canon U.S.A., Inc.
EOS R8 Mark II
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type Full-frame, mirrorless interchangeable lens camera
Image Processor (one) DIGIC X
Recording Media (one) SDXC / SDHC / SD card; UHS-II compatible
Eye-Fi and MultiMedia Cards (MMC) not compatible
Compatible Lenses Canon RF and RF-S lenses
Canon EF, EF-S and TS-E lenses
(with optional Mount Adapter EFEOS R)
Lens Mount Canon RF mount
Type Canon full-frame CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective Pixels Approx. 24.2 million pixels
Pixel Size Approx. 6.0 microns square
Total Pixels 25.6 million pixels
Aspect Ratio 3:2 (Horizontal : Vertical)
Color Filter System RGB primary colors
Low-pass Filter Installed at front of sensor; non-removeable
Dust Deletion Feature (Self Cleaning Sensor Unit) Auto cleaning: at Power Off / Enable (at power On Off) / Disable
Clean now (user-activated cleaning)
Clean manually (shutter blades held open for user cleaning of sensor)
Video resolutions RAW: none
4K UHD (oversampled) estimated recording time, video bit rate, file size, and SD card requirements
Recording formatCompression methodFrame rate (FPS)Total recording time (approx)Video bit rate
(approx. Mb/sec.)
File size
(approx. MB/min.)
SD card performance requirements (minimum)
64GB256GB1 TB
XF-HEVC S YCC 422 10 bitStandard LGOP59.9437 min.2 hr. 31 min.9 hr. 51 min.2251,612U3
50.00
29.971 hr. 3 min.4 hr. 12 min.16 hr. 25 min.135968
25.00
24.00
23.98
XF-HEVC S YCC 420 10 bit
XF-AVC S YCC 420 8 bit
Standard LGOP59.9456 min.3 hr. 47 min.14 hr. 47 min.1501,075U3
50.00
29.971 hr. 25 min.5 hr. 40 min.22 hr. 9 min.100718
25.00
23.98
XF-AVC S YCC 422 10 bitStandard LGOP59.9434 min.2 hr. 16 min.8 hr. 52 min.2501,791V60
50.00
29.9756 min.3 hr. 47 min.14 hr. 47 min.1501,075U3
25.00
23.98
Video bit rate indicates video only; audio and metadata are not included
Figures above are obtained when [Audio format: AAC / 16 bit / 2CH] is set
Movie recording stops when maximum time per movie is reached
Full HD
(approx. Mb/sec.)
File size
(approx. MB/min.)
64GB256GB1 TB
XF-HEVC S
YCC 422
10 bit
Standard LGOP179.856 min3 hr. 47 min.14 hr. 47 min.1501,075U3
150.0
119.91 hr. 25 min.5 hr. 40 min.22 hr. 9 min.100718
100.0
59.942 hr. 49 min.11 hr. 19 min.44 hr. 12 min.50360
50.00
29.97
25.00
23.98
XF-HEVC S
YCC 420
10 bit
XF-AVC S
YCC 420
8 bit
Standard LGOP179.81 hr. 21 min.5 hr. 24 min.21 hr. 6 min.105753U3
150.0
119.92 hr. 1 min.8 hr. 5 min.31 hr. 37 min.70503
100.0
59.944 hr. 2 min.16 hr. 7 min.63 hr. 1 min.35253
50.00
29.97
25.00
23.98
XF-AVC S
YCC 422
10 bit
Standard LGOP179.856 min.3 hr. 47 min.14 hr. 47 min.1501,075U3
150.0
100.0
50.00
29.97
25.00
23.98
FPS speeds MP4: 4K (UHD 16:9 only) 23.98 to 59.94 FPS (with sound)
MP4: Full HD 23.98 to 179.8 FPS (w/ sound)
4K video oversampled from 6K, at all FPS speeds
[Fine] not user-selectable
24.00 FPS not available
Recording Format DCIF (Design rule for Camera File system 2.0; EXIF 3.0
Image Format Still image format:
RAW: Canon RAW / C-RAW (.CR3)
JPEG / HEIF: L / M / S1 / S2
Movie image format (user-selectable in red Shooting Menu):
XF-HEVC S YCC 422 10-bit
XF-HEVC S YCC 420 10-bit
XF-AVC S YCC 422 10-bit
XF-AVC S YCC 420 8-bit
Folder Automatically created when card is inserted
DCIM / XFVC / MISC folders
Folder Actions Select folder / Create folder (new folder name can be user-changed)
Still Images DCF standards compliant
Default (within DCIM folder) xxx_R8M2
Can be changed by user to any 5-character string
Movies XFVC folder: XF-HEVC S / XF-AVC S file formats
REEL_xxxx (MP4 video file in XFVC folder)
News Metadata Not supported
Settings Auto (AWB); includes Ambience priority / White priority
Daylight
Shade
Cloudy
Tungsten light
White fluorescent light
Flash
Custom WB
Color Temp (four manual user pre-sets available: K1 K4)
White Balance Shift Shift Blue / Amber bias: ±9 levels
Magenta / Green bias: ±9 levels
Blue/amber and magenta/green shift can be combined
WB Bracketing available: ±3 levels
Type OLED electronic eye-level viewfinder
OLED screen size approx. 0.39 inch
Viewfinder resolution Approx. 2.36 million dots
Magnification Approx. 0.70x
Eyepoint Approx. 22mm (at -1m-1 from eyepiece lens)
Dioptric adjustment Approx. -4.0 +1.0 (user-adjustable)
Viewfinder brightness Auto (adjusts automatically to suit metering results) Manual (adjustable in 5 steps, in yellow Set-up Menu)
Display simulation (Viewfinder & LCD screen) Exposure simulation + Depth-of-field
Exposure simulation
Exposure simulation only when DOF preview pressed
Disable (displays adjust for proper viewing, regardless of actual exposure)
Optical Viewfinder Simulation (EVF and LCD screen) On / Off
Display adjusts to reduce contrast, and improve light/dark details
Display does not reflect actual exposure, and various camera settings such as Picture Style, WB, HDR PQ, etc.
HDR / C.Log View Assist (Viewfinder & LCD screen) Available during HDR PQ, or when Canon Log 3 / PQ / HLG is set in Custom Picture settings
Type TFT color, liquid-crystal monitor
Size 3.0 inch (3:2 aspect ratio); diagonal approx. 2.95 in. / 7.5 cm
Resolution Approx. 1.62 million dots
Touch-screen Operation Yes (capacitive sensing)
Vari-Angle Adjustment Opening angle: approx. 0175°
Rotating angle: forward approx. 090° / backward approx. 0180°
Coatings Anti-smudge coating (anti-reflection coating not applied)
Magnified View (still images) 1.5x 10x
AF Point Display (still images) Available
Highlight Alert Available (blinking highlights, during single-image display)
Auto Rotate On (display + computer) / On (computer only) / Off
Video: via Change movie rotation information
Search By Rating / Date / Folder / Protection / Type of file (1) / Type of file (2)
[Protect when setting the rating] can be set.
Ratings (Star) Off / Star ratings 15
Protect Images Select images / Select range / All images in folder / Unprotect all images in folder / Unprotect all images on card / All found images / Unprotect all found images / All images on card
Image Copy (to card on camera) Not Available
Focus Type Dual Pixel CMOS AF (from CMOS imaging sensor)
AF Zones for Auto Selection Still images: max. 1,053 zones
Movies: max. 1,053 zones (when 4K is active)
With focusing area approx. 100% x 100%
Selectable AF Point Positions Still images: max. 4,368 positions (78x56)
Movies: max. 3,588 positions (78x46)
User-adjustable AF point positioning over approx. 90% (H) x 100% (V)
AF Brightness Range Still images: EV -7.5 21
Movies: EV -5.5 21 (Full HD: EV -5.0 21)
With f/1.2 lens (except DS lenses); center AF point; One-shot AF; ISO 100
AF Areas Spot AF
1-point AF
Expand AF (4-point expansion)
Expand AF (8-point expansion)
Flexible Zone AF 1
Flexible Zone AF 2
Flexible Zone AF 3
Whole Area AF
AF Subject Detection Auto
People
Animals (dogs / cats / birds / horses)
Vehicles (motorsports cars & motorcycles / aircraft / trains)
Certain types of animals or vehicles may not be detectable
Register People Priority available, for up to ten human subjectsFootnote4
Eye Detect AF Auto (camera selects most prominent eye for focusing)
Right Eye (prioritizes subjects right eye)
Left Eye (prioritizes subjects left eye)
Disable
Defocus (video only) (via user-customized button) Intentional shift of focus from sharp original subject to a de-focused, blurred state
Available in AF mode only; [Movie Servo AF] will be paused
Blur amount user-selectable during defocus (1 5)
AF speed during defocus user-selectable (1 10)
Defocus effects may not be suitable, depending on lens, scene, and recording conditions
AF-assist beam Built-in to camera Compatible white LED AF-assist beams on Canon speedlites
Intermittent flash AF-assist beams and red AF-assist beams on speedlites not compatible
Manual focus aids Focus guide / MF Peaking
Focus Bracketing User-enabled
2 999 source images can be taken (user-defined in Menu)
User selects Focus increment, from 1 (narrow) to 10 (wide)
In-camera compositing of a finished JPEG image
Source images can also be composited in Canon Digital Photo Professional software, or other compatible third-party software
Electronic shutter only; flash not possible
Metering modes (stills) Evaluative metering (linked to active AF point / Area)
Partial metering (approx. 5.9% of image area, at center of screen)
Spot metering (approx. 3.0% of image area, at center of screen)
Center-weighted average metering
Partial and Spot metering: circle appears at center of LCD screen
Spot metering cannot be linked to off-center AF point locations
Metering modes (movies) Evaluative metering (only)
Metering Range (still images) EV -320
(movies) EV -120
Exposure Modes (stills) A+ (Scene Intelligent Auto)
P (Program AE)
Fv (Flexible-priority AE)
Tv (Shutter-priority AE)
Av (Aperture-priority AE)
M (Manual exposure)
C1 C3 (Custom shooting modes)
B (Bulb mode)
S&F (Program AE)
Movie for close-up demos reverts to Scene Intelligent Auto
SCN (Special scene modes)
SCN (Special Scene Modes, stills)
PortraitPanning Close-up
Group PhotoNight Portrait
KidsHDR Backlight Control
LandscapeSilent Shutter
SportsFood
Smooth skinHandheld Night Scene
Panoramic shot
Exposure Modes (movies) A+ (Scene Intelligent Auto movies)
P (Movie auto exposure)
Tv (Movie shutter-priority AE)
Av (Movie aperture-priority AE)
M (Movie manual exposure)
Fv reverts to movie auto exposure
S&F (Slow and Fast settable on LCD screen for P, Tv, Av, or M)
C1 C3 (movie Custom shooting modes)
B reverts to movie auto exposure
SCN Special scene modes
SCN (Special Scene Modes, movies) Smooth Skin Movie
Movie IS mode
Movie for Close-up Demos
ISO Speed Range (stills) Normal ISO 100 102,400
Expanded ISO 50 204,800 (equivalent)
Minimum ISO 200 when Highlight Tone Priority is active)
ISO Speed Range (video) ISO 100 25,600
ISO range varies, depending on Custom Picture and similar settings
Expanded: max. ISO 102,400 for movies (varies, depending on settings)
Auto ISO Range (stills) Minimum: L (ISO 50) or 100 ISO 51,200 (expandable to ISO 102,400)
Auto ISO Range (video) ISO 100 25,600 (expandable to ISO 102,400)
Exposure Compensation ±0.3 3 stops, in 1/3 or 1/2-stop increments
Auto Exposure Bracketing ±0.3 3 stops, in 1/3 or 1/2-stop increments
(2, 3, 5, or 7 still image shots selectable)
AE Lock Applied automatically: AE is locked as soon as subjects are in focus using One-Shot AF when set to [C.Fn2: AE lock meter. mode after focus].
Applied manually: Use the AE lock button (update by pressing the button again) in Fv, P, Tv, Av, and M modes.
(Enabled in all metering modes.)
Type Electronically controlled focal-plane shutter
Rolling shutter, using CMOS image sensor
Shutter Modes (stills) Electronic 1st-curtain
Electronic shutter
Mechanical shutter not available
Shutter speeds (stills) Electronic 1st-curtain: 1/4000 30 seconds, plus Bulb
Electronic shutter: 1/16,000 30 seconds, plus Bulb
1/16,000 only available in Fv, Tv, or M modes
Electronic shutter up to 1/8000 in P or Av modes
1/16,000 cannot be adjusted in or ½-stop increments
Electronic shutter max. 1/8000 in HDR mode, Focus Bracketing, or if same exposure for new aperture is active
Flash sync speed Electronic 1st-curtain only: max. 1/200 sec.
1/250 sec. With Sync Speed Priority active (Canon speedlites only)
1/250 sec. in 1.6x (crop) mode
Flash not possible with Electronic shutter
Self-timer 10 sec. / 2 sec. / Continuous
Continuous self-timer: 29 shots fired continuously, after 10 sec. Delay
Shutter type (movies) Rolling shutter, using CMOS image sensor
Shutter speeds (movies) 1/8000 sec. 1/8 sec. (slowest speed is based on movie FPS rate)
1/8 sec. minimum in Tv or M movie modes
1/25 sec. minimum in other movie shooting modes
Shutter covers sensor None, at shut-down
Drive modes (still images) Electronic 1st-curtain:
High speed continuous + 6 FPS*
High speed continuous 6 FPS
Low speed continuous 3.0 FPS
Single shooting
Electronic shutter:
High speed continuous + 40 FPS*
High speed continuous 20 FPS
Low speed continuous 5.0 FPS
Single shooting
Self-timer (10 sec. / 2 sec. / Continuous)
*Maximum FPS continuous still-image shooting (Continuous H+ Drive mode) depends upon camera settings; in some shooting conditions (slow shutter speeds, etc.), maximum FPS may not be possible
Pre-continuous shooting (still images) Records 20 shots (approx. 0.5 sec.) before shutter button fully pressed
RAW, C-RAW, JPEG or HEIF images available
Electronic shutter and Continuous H+ drive must be set by user
Flash photography, AEB shooting, and some other functions not Available
Burst rate (continuous still images until camera slows to write to SD card) RAW 73 continuous images (40 FPS, Electronic shutter)
1,000 or more (6 FPS, 1st-curtain Electronic shutter)
Large/Fine JPEG 190 continuous images (40 FPS, Elec shutter)
1,000 or more (6 FPS, 1st-curtain Elec shutter)
Still-image IS In-body Image Stabilization (IBIS), using CMOS sensor
Coordinated IS combined IBIS + optical IS, with IS lenses
Coordinated IS correction:
Center 7.5 stops; Peripheral 7.0 stopsFootnote1
(tests conforming to CIPA standards, using RF24-105mm F2.8 L IS USM Z lens)
Movie Digital IS 5-axis digital stabilization, at CMOS image sensor
Independently activated (vs. IBIS); Coordinated IS available
(Movie Digital IS + IBIS + lens optical IS, if available)
HDR shooting (PQ) Available
Still images: 10-bit HEIF images; YCbCr 4:2:2; Rec. ITU-R BT-2100 (PQ)
Video: Depends on recording format setting
HDR Mode Still images: Off / Moving subject / Dynamic range
Moving subject HDR created from single exposure
Dynamic range: Captures three source images; one finished JPEG image written to memory card (source images can be saved)
Dynamic range source images: Auto / ±1 EV / ±2 EV / ±3 EV
HDR Movie Mode None (HDR PQ video is available)
(still images and video) NegativeFilmtone
PositiveFilmtone
StoryTeal&Orange
StoryMagenta
StoryBlue
PaleTeal&Orange
RetroGreen
Sepiatone
AccentRed
TastyWarm
TastyCool
BrightAmber
BrightWhite
ClearLightBlue
ClearPurple
ClearAmber
Color Filter strength can be adjusted from 100% to 10%
Not available for RAW or C-RAW still images, HDR (PQ), multiple exposures, or focus bracketing
Cannot be set in Basic Zone exposure modes
Movies: cannot be used with HDR (PQ) or Time-lapse movies
Maximum Recording Times Less than 100.0 FPS: maximum 6 hours 00 minutes
Over 100 FPS: maximum 2 hours 00 minutes
Recording time can be shorter, from factors such as battery power or shut-down from heat
Cooling Fan None (no accessory cooling grip available)
Overheating shut-down times (at 73°F / 23°C, internal and external temperatures) 4K at 29.97 FPS, Standard LGOP no restrictions
Full HD at 29.97 FPS, Standard LGOP no restrictions
(Auto power off temperature setting at Standard)
Overheat warning Thermometer icon, and 10-stage analog scale to indicate rising temps
Open Gate Recording None
Canon Log Recording Canon Log 3 (in Custom Picture menu) Dynamic range, with Canon Log 3 approx. 1600%; 14 stops
(4K; at 29.97/25.00 FPS; ISO 800)
Custom Picture (CP) Canon 709 / Canon Log 3 / PQ / HLG / BT709 Standard available for video recording only
User06 User20 spaces available
CP files can be re-named, and extensively adjusted
Proxy Movie Recording None
Main / Sub Recording None
S&F (Slow & Fast recording) Recording FPS: 180 1.0 FPS
some restrictions, depending on movie record format, resolution, etc.
sound not recorded
Playback FPS: (NTSC video system) 23.98; 29.97, or 59.94 FPS
(PAL video system) 24.00; 25.00, or 50.00 FPS
Time-lapse Movie Recording Interval between frames: 2 seconds 99:59:59
Shutter count: 2 frames 3,600 frames
Recording size: 4K UHD / Full HD
Playback speed 29.97 / 25.00 FPS (approx. 2 min. for 3,600 frames)
Movie record formats available:
XF-AVC S YCC422 10-bit
XF-AVC S YCC420 8-bit
HDMI RAW recording to Compatible external recorders None (no RAW video recording capability)
HDMI recording of MP4 format video is possible
Time Code Available
Pre-recording (movies) Records 3 or 5 seconds of video, before user begins video recording
3 / 5 seconds Pre-recording set by user
Video Displays (Viewfinder & LCD screen) Grid display / Histogram / Zebra display / False Color display / Electronic level / Recording emphasis / Aspect Marker 1 & 2
User-set in red shooting menu > Shooting info display (Histogram set in Brightness Info)
Waveform display not available
Zebra display and False Color displays available in Shooting Info Display menu area, during video operation only
Built-in Microphone Stereo mic, on top of camera body
48 kHz; 24 or 16 bit; 2 channels
External Microphone Terminal 3.5mm diameter stereo mini-jack (3-pin)
Plug-in power supported
Multi-function Shoe Input Compatible with Canon Directional Stereo Microphone DM-E1D
Headphone Terminal 3.5mm diameter stereo mini jack
Audio monitoring possible via headphone terminal, or HDMI
DPOF Compatibility DPOF version 1.1
PictBridge printing not available
Print Type Standard / Index / Both
Photobook Set-up None
Start-up Password 6-digit password (set by user) required first time camera turned on, or when [Clear Entered Information] is performed in-camera
Password normally required at each start-up, or when awakening from sleep
Password request can be set to OFF, by user
Password can be changed at any time by user
Wi-Fi (Wireless LAN) 5.0 GHz / 2.4 GHz band
EOS Utility / Image.canon / Canon Camera Connect6 / Content Transfer Professional7 / Camera Control API
* Apps are available on the iOS app store and Google Play store. Full use of all app features In Content Transfer Professional requires a paid subscription.
Maximum Link Speed 5.0 GHz: (IEEE 802.11ax) 143.4 Mbps
(IEEE 802.11ac) 86.7 Mbps
(IEEE 802.11n) 72.2 Mbps
(IEEE 802.11a) 54 Mbps
2.4 GHz: (IEEE 802.11g) 54 Mbps
(IEEE 802.11b) 11 Mbps
Frequency; Channels 5.0 GHz: 5180 5825 MHz; 36 to 165 channels
2.4 GHz: 2412 2462 MHz; 1 to 11 channels
Wireless LAN Setting Method Connect via wizard / Connect via Wi-Fi Protected Setup
Wired LAN None
Version Specification Version 5.3 compliant
Transmission Method GFSK modulation
Bluetooth Communication Functions Canon Camera Connect App / Canon Bluetooth Remote Controller BR-E1 / BR-E2
Bluetooth Pairing Smartphone up to 10 units; BR-E1/E2 remote controller 1 unit
Live Streaming USB (UVC/UAC streaming) / HDMI streaming / Camera Connect app streaming / Live Switcher Mobile app streaming
USB power Delivery supported; requires power supply 5 V / 1.5 A or greater
Video only; not possible during S&F recording, or still-image shooting
Only P / M / Smooth skin movie modes can be set
Live Streaming Formats Video: Motion JPEG compression method; YCC 4:2:2 color sampling; 8-bits; Custom Picture supported; Recording range full range
Resolution / FPS rates 4K 30 FPS; 4K 60 FPS (60 FPS not available in Smooth skin mode); Full HD 60 FPS; Full HD 30 FPS
60 or 30 FPS, regardless of NTSC / PAL settings
USB Terminal USB-C (equivalent to USB 10 Gbps / SuperSpeed Plus USB / USB 3.2 Gen 2)
HDMI Terminal Type D size (micro HDMI terminal)
Remote Control Terminal Canon E3 type terminal (single-pin connector into camera)
Optional Canon RA-E3 Remote Controller Adapter allows Canon 3-pin (N3) to be connected
External Mic IN Terminal 3.5mm diameter stereo mini jack (3-pin)
Flash Sync Terminal Not Supported
Battery (one) Canon LP-E17 battery pack
Canon Battery Charger LC-E17 (included)
Optional Battery Grip None
Optional Extension Grip EG-E2 Grip EX
USB Charging Canon USB Power Adapter PD-E2 or PD-E1 recommended
(other USB power supplies cannot be guaranteed for proper operation)
AC Power Supply Canon DC Coupler DR-E18 and Canon AC Adapter AC-E6N
AC Adapter Kit ACK-E18 can also be used
Number of shots available Viewfinder shooting: Power Saving 220 shots; Smooth 150 shots
LCD screen shooting: Power Saving 340 shots; Smooth 270 shots
Based on CIPA test standards, at 73°F / 23°C
Using new, fully-charged Canon LP-E17 battery pack
Number of shots can vary greatly, depending on shooting conditions, etc.
Video operating time 4K Standard LGOP (59.94 / 50.00 FPS) approx. 40 min. available
Full HD (29.97 / 25.00 FPS) approx. 2 hr. 00 min.
Movie playback time (4K at 59.94 / 50.00 FPS) approx. 2 hr. 40 min.
At 73°F / 23°C, using new, fully-charged Canon LP-E17 battery pack
Dimensions: W x H x D 5.17 x 3.54 x 3.14 in. / 131.4 x 90.0 x 79.7mm
Weight Approx. 19.3 oz. / 1.2 lbs. / 546g
Body only, with battery and one SD card installed
Operating Environment 32°F 104°F / 0°C 40°C
Relative humidity 85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
