Canon Support for EOS Rebel SL1 | Canon U.S.A., Inc.
EOS Rebel SL1
- Windows Server 2022
- Windows 98
- Windows Me
- Windows XP
- Windows XP (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows 95
- Windows 7 (x64)
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1
- Windows 8.1 (x64)
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows Vista
- Windows Vista (x64)
- macOS 13
- macOS 12
- macOS 11
- Mac OS X v10.1
- Mac OS 9
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
Software Development Kit
The Canon EOS Digital Camera Software Development Kit (EDSDK) enables developers to integrate select Canon cameras directly into their software application solutions, giving them access to remote camera control and communication functionality of the camera. There are two versions of the EDSDK compatible with Windows or Macintosh.
The Software Developer Kit is provided free of charge and can be found at https://developercommunity.usa.canon.com. To learn more please visit the Canon Developer Community site and register to download Canon’s SDKs.
Our Knowledge Base with curated Q&As will point you in the right direction to troubleshoot your error code yourself. Be sure to search the error code you are struggling with along with your product model number in our Knowledge Base.
Type | CMOS Sensor |
Pixels | Effective pixels: Approx. 18.0 megapixels |
Pixel Unit | 4.3 µm square |
Total Pixels | Total pixels: Approx. 18.50 megapixels: 5288 (H) x 3506 (V) pixels |
Aspect Ratio | 3:2 (Horizontal : Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the image sensor |
Dust Deletion Feature | (1) Self Cleaning Sensor Unit Removes dust adhering to the low-pass filter. Self-cleaning executed automatically (taking approx. 2 sec.) when power is turned on or off. Manual execution also possible (taking approx. 5 sec.). (2) Dust Delete Data acquisition and appending The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots. (3) Manual cleaning |
Recording Format | Complies with Design rule for Camera File system 2.0 and Exif 2.30 |
File Size | (1)Large: Approx. 17.90 Megapixels (5,184 x 3,456) (2)Medium: Approx. 8.00 Megapixels (3,456 x 2,304) (3)Small 1: Approx. 4.50 Megapixels (2,592 x 1,728) (4)Small 2: Approx. 2.50 Megapixels (1920 x 1280) (5)Small 3: Approx. 0.35 megapixels (720 x 480) (6)RAW: Approx. 17.90 Megapixels (5,184 x 3,456) |
Backup Recording | N/A |
File Numbering | The following three types of file numbering methods can be set: (1) Continuous numbering * The numbering of captured images will continue even after you replace the camera's card. (2) Auto reset * When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card. (3) Manual reset * Resets the file number to 0001, and creates a new folder automatically. |
RAW + JPEG Simultaneous Recording | Still: JPEG, RAW (Canon RAW 2nd edition), RAW+JPEG Video: MOV (Image data: H.264, Audio: Linear PCM) |
Color Space | sRGB, Adobe RGB |
Picture Style | Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3 |
Settings | Auto, Preset (Daylight; Shade; Cloudy, Twilight, Sunset; Tungsten Light; White Fluorescent Light; Flash), Custom (Approx. 2,000° - 10,000°K), White Balance Correction, and White Balance Bracketing |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | White balance correction:Blue/amber bias: ±9 levelsMagenta/green bias: ±9 levels* Correction based on the current WB mode's color temperature. |
Color Temperature Information Transmission | Provided |
Type | Eye-level SLR (with fixed pentamirror) |
Coverage | Approx. 95% vertically and horizontally (with Eye point approx. 19mm) |
Magnification | Approx. 0.87x / 24.5° (50mm lens ∞, -1m-1) |
Eye Point | Approx. 19 mm (At -1m-1 from the eyepiece lens center) |
Dioptric Adjustment Correction | -3.0 to +1.0 m-1 (dpt) |
Focusing Screen | Fixed |
Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60) |
Viewfinder Information | 1) AF information (AF points and focus confirmation light) 2) Exposure information (Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, spot metering circle, exposure warning) 3) Flash information (Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light) 4) Image information (Highlight tone priority (D+), maximum burst (1-digit display), white balance correction, SD card information) |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Type | TTL secondary image-forming, phase-difference detection |
AF Points | 9 points (Center AF point is AF cross-type at f/5.6, Center AF point is vertical line-sensitive at f/2.8.) |
AF Working Range | Center AF point: EV -0.5 - 18 Other AF points: EV 0.5 - 18 (At room temperature and ISO 100, based on Canon's testing standards) |
Focusing Modes | (1) Autofocus One-Shot AF Predictive AI Servo AF AI Focus AF (*Switches between One-Shot AF and AI Servo AF * Automatically set to One-Shot AF when the drive mode is set to Silent Single Shooting or Silent Continuous Shooting. (AI Servo AF and AI Focus AF cannot be selected.) (2) Manual focus (MF) |
AF Point Selection | (1) Manual selection (2) Auto selection * Automatically set in Basic Zone modes. |
Selected AF Point Display | Indicated by superimposed display in the viewfinder and on the LCD monitor |
AF Assist Beam | (1) Intermittent firing of built-in flash (2) Effective range: Approx. 13.1 ft./4 m. at center, approx. 11.5 ft /3.5 m. at periphery * With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead. * Compatible with AF assist-beam (intermittent firing) of 320EX, 270EX II, and 270EX flashes. |
Metering Modes | TTL maximum aperture metering with 63-zone metering sensor: 1)Evaluative metering (linked to all AF points) 2)Partial metering (center, approx. 9% of viewfinder) 3)Spot metering (center, approx. 4% of viewfinder) 4)Center-weighted average metering |
Metering Range | EV 1.0 - EV 20.0 (at 73°F/23°C with 50mm f/1.8 II lens at ISO 100) |
Exposure Control Systems | Creative Zone (1) Program AE (shiftable) (2) Shutter-priority AE (3) Aperture-priority AE (4) Manual exposure (including bulb)Basic zone (1) Scene Intelligent Auto (Program AE / non-shiftable) (2) Flash Off (3) Creative Auto * Effect shots cannot be set simultaneously with Ambience-based shots or background blurring. Neither can continuous shooting or 2 to 10 shots after 10-sec self-timer be used with Effect shot. * When background blurring is set, shooting with flash is disabled. When the flash is raised, background blurring cannot be set. (4) Portrait (5) Landscape (6) Close-up (7) Sports (8) Special scene - Kids - Food - Candlelight - Night Portrait - Handheld Night Scene - HDR Backlight Control mode |
ISO Speed Range | For Stills: 1.Manual setting range of ISO 100-12800, expansion to ISO 25600 2.Auto, ISO 100-6400 (in whole-stop increments) - In Creative Zone modes, the maximum ISO speed (ISO 400, 800, 1600, 3200, or 6400) for ISO Auto can be set. - With Highlight Tone Priority, ISO 200 or higher will be set. *1: Fixed at ISO 400 for Bulb exposures.*2: Depends on the maximum ISO speed that has been set.*3: If fill-flash will result in overexposure, the ISO speed can be set as low as ISO 100.*3: Scene Intelligent Auto, Night Portrait and Handheld Night Scene modes are excluded.*4: Not applicable to Auto, Kids, Night Portrait, or Handheld Night Scene.*5: If you use bounce flash with an external Speedlite in the Creative Auto, Portrait, Landscape, Close-up, Sports, Food, Candlelight and P modes, the ISO speed is set automatically within ISO 400–1600 (or up to the maximum limit) to match the brightness. |
Exposure Compensation | Manual: ±5 stops in 1/3- or 1/2-stop increments AEB : ±2 stops in 1/3- or 1/2-stop increments * If the exposure compensation exceeds ±2 stops, the left or right icon appears in the viewfinder. * Manual exposure compensation and AEB can be set in combination. * AEB is set in the following sequence: Standard exposure, decreased exposure, and increased exposure. * If AEB is used with the self-timer, the three bracketed shots will be taken in succession after the 10-sec. or 2-sec. delay. |
AE Lock | (1) Auto AE lock * In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved. (2) Manual AE lock * In the P, Tv, Av, and M modes, enabled with the AE lock button. (Press again to update.) * Enabled in all metering modes. |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled * Electronic 1st curtain and mechanical 2nd curtain |
Shutter Speeds | 1/4000 to 30 sec. (total shutter speed range; available range varies by shooting mode), bulb, X-sync at 1/200 sec. * Settable in 1/3- or 1/2-stop increments. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay |
Shutter Lag Time | (1) During SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.075 sec. * Approx. 0.168 seconds in case of silent shooting. (2) Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.150 sec. * Approx. 0.242 seconds in case of silent shooting. * Time lag with the aperture stopped down by 3 stops or less (Excludes AF operation time). |
Flash Metering | E-TTL II autoflash (evaluative flash metering and average flash metering), FE Lock |
Flash Exposure Compensation | ±2 stops in 1/3-stop or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings | (1) External flash function setting * Flash firing, E-TTL II auto flash system, flash mode, wireless master, zoom, sync setting, flash exposure compensation, FEB, and clear setting. * With the 600EX-RT, radio wireless transmission control is possible. (2) External flash C.Fn setting * The actual setting options for (1) and (2) will differ depending on the Speedlite used. |
PC Terminal | Not Provided |
Drive Modes | (1) Single shooting (2) Continuous shooting (3) Silent single shooting (4) Silent continuous shooting * Single silent shooting and continuous silent shooting are not possible when Basic Zone is selected, during Live View shooting, or when using AI Servo AF or AI Focus AF. (5) 10-sec. self-timer/Remote control (6) 2-sec. self-timer (7) Continuous shooting after 10-sec. self-timer (2 to 10 shots) |
Continuous Shooting Speed | High-speed continuous shooting: Max. approx. 4.0 fps * With One-Shot AF or AI Servo AF Silent continuous shooting: Max. approx. 2.5 fps * One-Shot AF only |
Maximum Burst | Based on 8GB memory Card: JPEG Large/Fine: Approx. 28 Shots RAW: Approx. 7 Shots RAW+JPEG Large/Fine: 4 Shots Based on UHS-I memory card: JPEG Large/Fine: Approx. 1140 Shots RAW: Approx. 8 Shots RAW + JPEG Large/Fine: 4 Shots * Figures are based on Canon's testing standards (ISO 100 and Standard Picture Style). * At ISO 12800, maximum burst will greatly decrease due to internal processing. |
Shooting Modes | Still photo shooting and video shooting |
Focusing | (1) AF operation of the Hybrid CMOS AF, One-shot AF i.Face Detection plus Tracking AF ii.FlexiZone - Multi * 31 zones * AF at the touched zone iii.FlexiZone - Single (2) TTL secondary image-forming, phase-difference detection with AF operation, One-shot AF i.Manual selection ii.Auto selection * Automatically set in Basic Zone modes (3) Manual focus * Manual focusing by enlarging images by approx. five to ten times |
Metering Modes | Real-time evaluative metering with image sensor. (1) Evaluative metering (315 zones) (2) Partial metering (approx. 10.3% of Live View screen) (3) Spot metering (approx. 2.6% of Live View screen) (4) Center-weighted average metering * AE lock possible. The active metering time can be changed. |
Metering Range | EV 0 to EV 20 (At room temperature, 50mm f/1.4 lens, ISO 100) |
Grid Display | Two grids provided: (1) Grid 1: Pair of vertical and horizontal lines (2) Grid 2: 5 vertical and 3 horizontal lines |
Exposure Simulation | Provided |
Silent Shooting | Provided |
File Format | MOV: Movie: MPEG-4 AVC / H.264 * Variable (average) bit rate Audio: Linear PCM * Meta information is embedded in the MOV file (no separate THM file) |
File Size | Recording Size: [Full HD] 1920 x 1080 (30 fps/25 fps/24 fps): 330 MB/min. [HD] 1280 x 720 (60 fps/50fps): 330 MB/min. [SD] 640 x 480 (30 fps/25fps): 82.5 MB/min. * If the file size exceeds 4GB, a new file will be automatically created. ** SD Class 6 or higher required. |
Frame Rates | 1920 x 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p 1280 x 720 (HD): 60p (59.94) / 50p 640 x 480 (SD): 30p (29.97) / 25p |
Continuous Shooting Time | Based on 8GB Memory Card: [1920 x 1080] 30 fps/25 fps/24 fps: 22 min. [1280 x 720] 60 fps/50 fps: 22 min. [640 x 480] 30 fps/25 fps: 1 hr. 32 min. Based on 16GB Memory Card: [1920 x 1080] 30 fps/25 fps/24 fps: 44 min. [1280 x 720] 60 fps/50 fps: 44 min. [640 x 480] 30 fps/25 fps: 3 hr. 4 min. * If recording time reaches 29 min. 59 sec., movie shooting stops automatically. |
Focusing | (1) One-shot AF (2) Servo AF (3) Manual Focus * Magnify the image by approx. 5x or appox. 10x and focus manually. AF using AF point selection: i.Face Detection plus Tracking AF ii.FlexiZone - Multi * 31 zones * AF at the touched zone iii.FlexiZone - Single |
Range | 8 bit, 0 - 255 |
Exposure Control | (1) Program AE for movie shooting * In Basic Zone modes, P, Av, and Tv modes * Shutter speed 1/30 - 1/4000 sec. (Signal accumulation time), aperture, and ISO speed automatically set. (2) Manual exposure * Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps. |
Exposure Compensation | Provided (±3 stops in 1/3-stop increments) * For movies, exposure compensation will not be applied beyond ±3 stops even if the exposure compensation has been set beyond ±3 stops. * For still photo shooting, the exposure compensation can be set and applied up to ±5 stops. |
Type | TFT color, liquid-crystal monitor with Touch Panel LCD (capacitive type) |
Monitor Size | Wide 3.0-inch (Screen aspect ratio of 3:2) 7.7cm diagonal (6.4cm wide, 4.3cm high) |
Pixels | Approx. 1,040,000 dots |
Coverage | Approx. 100% |
Brightness Control | Adjustable to one of seven brightness levels |
Coating | Anti-smudge coating |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
Display Format | (1) Single image displaySingle image, basic information, detailed information, histogram display(2) Index display4/9/36/100 images(3) Jump display (Image jump w/ Main Dial)1/10/100 images, by date, by folder, movies only, stills only, by rating |
Highlight Alert | On the detailed information and histogram displays, highlight areas with no image data will blink. |
Histogram | Brightness / RGB |
Items | During shooting: When you press the Quick Control function button under the following conditions, you can set the functions below: *The settable functions depend on the shooting mode(1)With viewfinder shooting: Shutter speed, aperture, ISO speed, exposure compensation/ AEB, flash exposure compensation, Picture Style, White balance, White balance correction/White balance bracketing, Auto Lighting Optimizer, Metering mode, AF operation, Drive mode/Self-timer, image-recording quality, Flash firings, Ambience-based shots, Light/scene-based shots, Extra Effect Shot, Background blurring, Special scene modes, and Color tone.(2)With Live View shooting: AF method, Drive mode/Self-timer, Metering mode, image-recording quality, White balance, Picture Style, Auto Lighting Optimizer, Creative Filter, Flash firing, Ambience-based shots, Light/scene-based shots, Extra Effect Shot, Special scene modes, and Color tone.(3)With video shooting: AF method, Drive mode/Self-timer, image-recording quality, movie-recording size, video snapshot, White balance, Picture Style, Auto Lighting Optimizer, and Miniature effect movie. During Playback: When you press the Quick Control function button under the following conditions, you can set the functions below: (1)During still photo playback: Image protect, image rotate, rating, Creative Filters, resize, Cropping, and image jump with Main Dial (2)During movie playback: Image protect, rating, and image jump with Main Dial |
Protection | Erase protection can be applied/canceled for a single image, all images in a folder, or all images on the card |
Erase | Erase single image, erase selected images, erase all images in folder, erase all images on a card, or erase only unprotected images |
Compatible Printers | PictBridge-compatible printers |
Printable Images | RAW, JPEG, and RAW+JPEG images complying to Design rule for Camera File System * Movies cannot be printed. |
DPOF | Complies to DPOF Version 1.1 |
Compatible Images | Not Provided |
Custom Functions | Eight Custom Functions with 24 settings settable with the camera |
Custom Controls | Not Provided |
My Menu Registration | Up to six top-tier menu options and Custom Function settings can be registered |
USB Terminal | For personal computer communication and PictBridge (Hi-Speed USB) |
Video Out Terminal | HDMI mini OUT terminal: Type C (Switches automatically to suit the resolution) Video output: 1080/60i, 1080/50i, 480/60p, 576/50p * Switches automatically to 1, 2, 3, or 4 to suit the TV |
Extension System Terminal | Not Provided |
Battery | Battery Pack LP-E12 x 1 * With the AC Adapter Kit ACK-E15, AC power is possible. |
Battery Life | 1)Camera body only |
Battery Check | Automatic battery level check when power is turned ON. Battery level indicated in one of four levels on LCD monitor. |
Power Saving | Power turns off after the set time of non-operation elapses * [Auto power off] settable to 30 sec., 1 min., 2 min., 4 min., 8 min., 15 min. or disable |
Date/Time Battery | Built-in secondary battery. When fully-charged, the date/time can be maintained for about three months. |
Start-up Time | Approx. 0.1 sec. (Based on CIPA testing standards) |
Dimensions (W x H x D) | Approx. 4.60 x 3.57 x 2.74 in.1 / 116.8 x 90.7 x 69.4mm1 1(Weight specifications and dimensions are for camera body only; does not include battery or memory card.) |
Weight | Approx. 14.36 oz. / 407g (CIPA standard) Approx. 13.06 oz.1 / 370g1 (Body only) Approx. 13.16 oz 1 / 373g1 (White Body only) 1(Weight specifications and dimensions are for camera body only; does not include battery or memory card.) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or lessAll data are based on Canon's Standard Test Method. Subject to change without notice. If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker. Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
