Canon Support for EOS Rebel T6i | Canon U.S.A., Inc.
EOS Rebel T6i
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
| Type | CMOS Sensor |
| Pixels | Effective pixels: Approx. 24.20 megapixels Total pixels: Approx. 24.70 megapixels |
| Pixel Unit | 3.72µm square |
| Aspect Ratio | 3:2 (Horizontal : Vertical) |
| Color Filter System | RGB primary color filters |
| Low Pass Filter | Fixed position in front of the image sensor |
| Dust Deletion Feature | (1) Self Cleaning Sensor Unit Removes dust adhering to the low-pass filter. Self-cleaning executed automatically (taking approx. 2 sec.) when power is turned on or off. Manual execution also possible (taking approx. 5 sec.). (2) Dust Delete Data acquisition and appending The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots. (3) Manual cleaning |
| Recording Format | Complies with Design rule for Camera File system 2.0 and Exif 2.30 |
| File Size | 3:2Large: Approx. 24.00 Megapixels (6000 x 4000)Medium: Approx. 10.60 Megapixels (3984 x 2656)Small 1: Approx. 5.90 Megapixels (2976 x 1984)Small 2: Approx. 2.50 Megapixels (1920 x 1280)Small 3: Approx. 0.35 Megapixels (720 x 480)RAW: Approx. 24.00 Megapixels (6000 x 4000)4:3 Large: Approx. 21.30 Megapixels (5328 x 4000) Medium: Approx. 9.50 Megapixels (3552 x 2664) Small 1: Approx. 5.30 Megapixels (2656 x 1992) Small 2: Approx. 2.20 Megapixels (1696 x 1280) Small 3: Approx. 0.31 Megapixels (640 x 480) RAW: Approx. 24.00 Megapixels (6000 x 4000)16:9 Large: Approx. 20.20 Megapixels (6000 x 3368) Medium: Approx. 8.90 Megapixels (3984 x 2240) Small 1: Approx. 5.00 Megapixels (2976 x 1680) Small 2: Approx. 2.10 Megapixels (1920 x 1080) Small 3: Approx. 0.29 Megapixels (720 x 408) RAW: Approx. 24.00 Megapixels (6000 x 4000)1:1 Large: Approx. 16.00 Megapixels (4000 x 4000) Medium: Approx. 7.10 Megapixels (2656 x 2656) Small 1: Approx. 3.90 Megapixels (1984 x 1984) Small 2: Approx. 1.60 Megapixels (1280 x 1280) Small 3: Approx. 0.23 Megapixels (480 x 480) RAW: Approx. 24.00 Megapixels (6000 x 4000) |
| Backup Recording | N/A |
| File Numbering | The following three types of file numbering method can be set: (1) Continuous numbering * The numbering of captured images will continue even after you replace the camera's card. (2) Auto reset * When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card. (3) Manual reset * Resets the file number to 0001, and creates a new folder automatically. |
| RAW + JPEG Simultaneous Recording | Yes |
| Color Space | sRGB, Adobe RGB |
| Picture Style | Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3 * In Basic Zone modes, "Auto" is set automatically. * In Creative Zone modes, you can select or set the Picture Style. * Default settings for [User Defined 1-3] are [Auto]. |
| Settings | Auto, Preset (Daylight; Shade; Cloudy, Twilight, Sunset; Tungsten light; White Fluorescent Light; Flash), Custom (Approx. 2,000° - 10,000°K), White Balance Correction, and White Balance Bracketing |
| Auto White Balance | Auto white balance with the image sensor |
| Color Temperature Compensation | White balance correction:Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels* Correction based on the current WB mode's color temperature. |
| Color Temperature Information Transmission | Provided |
| Type | Eye-level SLR (with fixed pentamirror) |
| Coverage | Approx. 95% vertically and horizontally (with Eye point approx. 19mm) * Coverage is approx. 93% when aspect ratio is set to 16:9. |
| Magnification | Approx. 0.82x / 23.2° (50mm lens ∞, -1 m-1) |
| Eye Point | Approx. 19 mm (At -1m-1 from the eyepiece lens center) |
| Dioptric Adjustment Correction | Adjustable from approx. -3.0 to +1.0 m-1 (dpt) |
| Focusing Screen | Fixed |
| Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60) |
| Viewfinder Information | AF information AF points and focus confirmation Exposure information Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, spot metering circle, exposure warning, flicker detection indicator Flash information Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light Image information Highlight tone priority (D+), maximum burst (1-digit display), white balance correction, SD card information |
| Depth Of Field Preview | Enabled with depth-of-field preview button |
| Type | TTL secondary image-forming, phase-difference detection |
| AF Points | 19 points All AF points are cross-type at f/5.6 Center AF point is diagonal cross-type at f/2.8 |
| AF Working Range | EV -0.5 - 18 (at room temperature and ISO 100, based on Canon's testing standards) |
| Focusing Modes | (1) Autofocus One-Shot AF Predictive AI Servo AFAI Focus AF (*Switches between One-Shot AF and AI Servo AF) *Switches between One-Shot AF and AI Servo AF(2) Manual focus (MF) |
| AF Point Selection | (1) Manual selection (2) Auto selection * Automatically set in Basic Zone modes. |
| Selected AF Point Display | Indicated by superimposed display in the viewfinder and on the LCD monitor. |
| AF Assist Beam | Intermittent firing of built-in flash Effective range: Approx. 13.1 ft. / 4m at center, approx. 11.5 ft. / 3.5m at periphery * With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead. * Compatible with AF assist-beam (intermittent firing) of 320EX, 270EX II, and 270EX flashes. |
| Metering Modes | 7560-pixel RGB+IR metering sensor Metering with the area divided into 63 segments (9x7) 1)Evaluative metering (linked to all AF points) 2)Partial metering (center, approx. 6.0% of viewfinder) 3)Spot metering (center, approx. 3.5% of viewfinder) 4)Center-weighted average metering |
| Metering Range | EV 1 - 20 (at 23°C / 73°F with 50mm f/1.8 II lens at ISO 100) |
| Exposure Control Systems | Creative Zone (1) Program AE (shiftable) (2) Shutter-priority AE (3) Aperture-priority AE (4) Manual exposure (including bulb) Basic zone (1) Scene Intelligent Auto (Program AE / non-shiftable) (2) Flash Off (3) Creative Auto * When background blurring is set, shooting with flash is disabled. When the flash is raised, background blurring cannot be set. (4) Portrait (5) Landscape (6) Close-up (7) Sports (8) Special Scene• Kids• Food• Candlelight• Night Portrait• Handheld Night Scene• HDR Backlight Control mode |
| ISO Speed Range | For Stills: Manual setting range of ISO 100-12800, expansion to IS 25600 equivalent. *1: Depends on the maximum ISO speed that has been set. *2: If fill-flash will result in overexposure, the ISO speed can be set to ISO 100 at the maximum. *3: If you use bounce flash with an external Speedlite in the Creative Auto, Portrait, Landscape, Macro, Sports, Food, or P mode, the ISO speed is set automatically within ISO 400–ISO 1600 (or up to the maximum limit) to match the brightness. |
| Exposure Compensation | (1) Manual: ±5 stops in 1/3- or 1/2-stop increments (2) AEB : ±2 stops in 1/3- or 1/2-stop increments * If the exposure compensation exceeds ±2 stops, the left or right icon appears in the viewfinder. * Manual exposure compensation and AEB can be set in combination. * AEB is set in the following sequence: Standard exposure, decreased exposure, and increased exposure. * If AEB is used with the self-timer, the three bracketed shots will be taken in succession after the 10-sec. or 2-sec. delay. |
| AE Lock | (1) Auto AE lock * In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved. (2) Manual AE lock * In the P, Tv, Av, and M modes, enabled with the AE lock button. (Press again to update.) * Enabled in all metering modes. |
| Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled * Electronic 1st curtain and mechanical 2nd curtain |
| Shutter Speeds | 1/4000 to 30 sec., Bulb (total shutter speed range) X-sync at 1/200 sec. |
| Shutter Release | Soft-touch electromagnetic release |
| Self Timer | 10-sec. or 2-sec. Delay |
| Shutter Lag Time | During SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.075 sec. *Approx. 0.100 sec. for Silent Shooting: approx. 0.250 sec. with flash Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.240 sec. *Time lag with the aperture stopped down by 3 stops or less (Excludes AF operation time). *Approx. 0.265 sec. for Silent Shooting |
| Flash Metering | E-TTL II autoflash (evaluative flash metering and average flash metering), FE Lock |
| Flash Exposure Compensation | ±2 stops in 1/3-stop or 1/2-stop increments |
| FE Lock | Provided |
| External Flash Settings | (1) External flash function setting * Flash firing, E-TTL II auto flash system, flash mode, wireless master, zoom, sync setting, flash exposure compensation, FEB, and clear setting. * With the 600EX-RT, radio wireless transmission control is possible. (2) External flash C.Fn setting * The actual setting options for (1) and (2) will differ depending on the Speedlite used. |
| PC Terminal | Not Provided |
| Drive Modes | Single shooting Continuous shooting Max. approx. 5.0 fps * At 1/500 sec. or faster shutter speed, and at the maximum aperture (varies depending on the lens).Silent single shooting Silent continuous shooting Max. approx. 3.0 fps10-sec. self timer/remote control2-sec. self-timer Continuous shooting after 10-sec. self-timer (2 to 10 shots) |
| Continuous Shooting Speed | High-speed continuous shooting: Max. approx. 5.0 fps |
| Maximum Burst | Number of Shots Based on 8GB memory Card: JPEG Large/Fine: Approx. 180 JPEG Large/Norma: Approx. 1810 (Full) Medium/Fine: Approx. 1770 (Full) Medium/Normal: Approx. 3500 (Full) S1/Fine: Approx. 2830 (Full) S1/Normal: Approx. 5320 (Full) S2: Approx. 5320 (Full) S3: Approx. 20180 (Full) RAW: Approx. 7 Shots RAW+JPEG Large/Fine: 6 Shots Number of Shots Based on 8GB UHS-I memory card: JPEG Large/Fine: Approx. 940 (Full) JPEG Large/Norma: Approx. 1810 (Full) Medium/Fine: Approx. 1770 (Full) Medium/Normal: Approx. 3500 (Full) S1/Fine: Approx. 2830 (Full) S1/Normal: Approx. 5320 (Full) S2: Approx. 5320 (Full) S3: Approx. 20180 (Full) RAW: Approx. 8 Shots RAW+JPEG Large/Fine: 6 Shots * The number of possible shots and maximum burst are those obtained with the 8GB card of Canon's testing standards. * The file size, number of possible shots, and maximum burst differ depending on shooting conditions (aspect ratio of 3:2, subject, memory card brand, ISO speed, Picture Style, etc.). * Figures appended with an "Full" indicate that continuous shooting is possible until the card becomes full. |
| Shooting Modes | Still photo shooting and video shooting |
| Focusing | (1) Hybrid CMOS AF III * Covers approx. 80% (width) x 80% (height) of the screen area. (2) Manual focus *Manual focusing by enlarging images by approx. five to ten times |
| Metering Modes | Real-time evaluative metering with image sensor. (1) Evaluative metering (315 zones) (2) Partial metering (approx. 10.0% of Live View screen) (3) Spot metering (approx. 2.7% of Live View screen) (4) Center-weighted average metering * AE lock possible. The active metering time can be changed. |
| Metering Range | EV 0 - 20 (at 73°F/23°C at ISO 100); EV 0 - 18 (width Hybrid CMOS AF III at 73°F/23°C at ISO 100) |
| Grid Display | (1) 3x3 (2) 6x4 |
| Exposure Simulation | Provided |
| Silent Shooting | Not provided |
| File Format | MP4: Movie: MPEG-4 AVC / H.264 * Variable (average) bit rate Audio: AAC MOV: MOV format movie cannot be shot. (playback is possible) |
| File Size | Recording Size: [Full HD] Standard: 1920 x 1080 (30 fps/25 fps/24 fps): 216 MB/min. Lightweight: 1920 x 1080 (30 fps/25 fps): 87 MB/min. [HD] Standard: 1280 x 720 (60 fps/50 fps): 187 MB/min. Lightweight: 1280 x 720 (30 fps/25 fps): 30 MB/min. [SD] Standard: 640 x 480 (30 fps/ 25 fps): 66 MB/min. Lightweight: 640 x 480 (30 fps/ 25 fps): 23 MB/min. * If the recording time reaches 29 min. 59 sec., the movie shooting stops automatically. * The file size is 4 GB, and shooting does not stop automatically. |
| Frame Rates | 1920 x 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p 1280 x 720 (HD): 60p (59.94) / 50p 640 x 480 (SD): 30p (29.97) / 25p |
| Continuous Shooting Time | * If recording time reaches 29 min. 59 sec., movie shooting stops automatically. * See Frame Rates section for actual frame rates |
| Focusing | (1) Hybrid CMOS AF III * Covers approx. 80% (width) x 80% (height) of the screen area. (2) Manual focus * Magnify the image by approx. 5x or approx. 10x and focus manually. |
| Range | 8 bit, 0 - 255 |
| Exposure Control | (1) Program AE for movie shooting * In Basic Zone modes, P, Av, and Tv modes * Shutter speed 1/30 - 1/4000 sec. (Signal accumulation time), aperture, and ISO speed automatically set. (2) Manual exposure * Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps. |
| Exposure Compensation | Provided (±3 stops in 1/3-stop increments) * For video, exposure compensation will not be applied beyond ±3 stops even if the exposure compensation has been set beyond ±3 stops. * For still photo shooting, the exposure compensation can be set and applied up to ±5 stops. |
| Type | TFT color, liquid-crystal monitor with Touch Panel LCD (capacitive type) |
| Monitor Size | Wide 3.0-inch (Screen aspect ratio of 3:2) 7.7cm diagonal (6.37cm wide, 4.25cm high) |
| Pixels | Approx. 1,040,000 dots |
| Coverage | Approx. 100% |
| Brightness Control | Adjustable to one of seven levels |
| Coating | Anti-smudge coating |
| Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
| Display Format | Single image display • Single image, basic information, detailed information, histogram display Index display • 4/9/36/100 images Jump display (Image jump w/ Main Dial) • 1/10/100 images, shooting date, by folder, movies only, stills only, by rating |
| Highlight Alert | On the detailed information and histogram displays, highlight areas with no image data will blink. |
| Histogram | Brightness / RGB |
| Items | When you press the Quick Control function button under the following conditions, you can set the functions below:During still photo playback: Image protect, image rotate, rating, Creative Filters, resize, Cropping, and image jump with Main Dial During movie playback: Image protect, rating, and image jump with Main Dial |
| Protection | Erase protection can be applied/canceled for a single image, all images in a folder, or all images on the card |
| Erase | Erase single image, erase selected images, erase all images in folder, erase all images on a card, or erase only unprotected images |
| Compatible Printers | PictBridge-compatible printers |
| Printable Images | RAW, JPEG, and RAW+JPEG images complying to Design rule for Camera File System * Movies cannot be printed. |
| DPOF | Complies to DPOF Version 1.1 |
| Compatible Images | Not Provided |
| Custom Functions | 13 Custom Functions with 41 settings settable with the camera |
| Custom Controls | Not Provided |
| My Menu Registration | Up to six top-tier menu options and Custom Function settings can be registered |
| USB Terminal | For personal computer communication and PictBridge (Hi-Speed USB) Audio (stereo)/video (NTSC/PAL) output To connect a GP-E2 GPS Receiver |
| Video Out Terminal | Type C (Switches automatically to suit the resolution) Video output: 1080/60i, 1080/50i, 480/60p, 576/50p * Switches automatically to 1, 2, 3, or 4 to suit the TV |
| Extension System Terminal | 3.5mm diameter stereo mini-jack |
| Battery | One Battery Pack LP-E17 * With the AC Adapter Kit ACK-E18, AC power is possible. * With Battery Grip BG-E18, it is possible to use two Battery Pack LP-E17 units. |
| Battery Life | 1)Camera body only, LP-E17 x1 2)Using Battery Grip BG-E18 |
| Battery Check | Automatic battery level check when power is turned ON. Battery level indicated in one of four levels on LCD monitor. |
| Power Saving | Power turns off after the set time of non-operation elapses * [Auto power off] settable to 30 sec., 1 min., 2 min., 4 min., 8 min., 15 min. or disable |
| Date/Time Battery | Built-in secondary battery It is not replaceable by the user. It recharges when the batter pack is loaded or when the AC adapter is connected. Without any recharging, the backup battery can maintain the date/time for approx. 3 months. The backup battery takes approx. 8 hours to be fully recharged. |
| Start-up Time | Approx. 0.18 sec. (based on CIPA testing standards) |
| Dimensions (W x H x D) | Approx. 5.20 x 3.98 x 3.07 in. Approx. 131.9 x 100.9 x 77.8mm |
| Weight | Approx. 19.58 oz. / 555g (CIPA standard) Approx. 17.99 oz. / 510g (Body only) |
| Working Temperature Range | 32-104°F/0-40°C |
| Working Humidity Range | 85% or less All data are based on Canon's Standard Test Method. Subject to change without notice. If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker. Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
next to your download
