Canon Support for EOS Rebel T7i | Canon U.S.A., Inc.
EOS Rebel T7i
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
| Type | CMOS sensor (supporting Dual Pixel CMOS AF) |
| Pixels | Effective pixels: Approx. 24.2* megapixels Total pixels: Approx. 25.8* megapixels * Rounded to the nearest 100,000. |
| Pixel Unit | Approx. 3.72µm square |
| Aspect Ratio | 3:2 (Horizontal : Vertical) |
| Color Filter System | RGB primary color filters |
| Low Pass Filter | Installed in front of the image sensor, non-detachable |
| Dust Deletion Feature | (1) Self Cleaning Sensor Unit Removes dust adhering to the low-pass filter. Self-cleaning executed automatically (taking approx. 2 sec.) when power is turned on or off. Manual execution also possible (taking approx. 5 sec.). After the cleaning is performed, the camera will automatically restart (power OFF to ON). (2) Dust Delete Data acquisition and appending The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots. (3) Manual cleaning |
| Recording Format | Complies with Design rule for Camera File system 2.0 and Exif 2.3 |
| File Size | 3:2 Aspect Ratio Large: 6000 x 4000 Medium: 3984 x 2656 Small 1: 2976 x 1984 Small 2: 2400 x 1600 RAW: 6000 x 4000 4:3 Aspect Ratio Large: 5328 x 4000 Medium: 3552 x 2664 Small 1: 2656 x 1992 Small 2: 2112 x 1600 RAW: 6000 x 4000 16:9 Aspect Ratio Large: 6000 x 3368 Medium: 3984 x 2240 Small 1: 2976 x 1680 Small 2: 2400 x 1344 RAW: 6000 x 4000 1:1 Aspect Ratio Large: 4000 x 4000 Medium: 2656 x 2656 Small 1: 1984 x 1984 Small 2: 1600 x 1600 RAW: 6000 x 4000 |
| Backup Recording | N/A |
| File Numbering | The following three types of file numbering method can be set: (1) File numbering method Continuous numbering The numbering of captured images will continue even after you replace the camera's card. Auto reset When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card. (2) Manual reset Resets the file number to 0001, and creates a new folder automatically. |
| RAW + JPEG Simultaneous Recording | Simultaneous recording is possible using a combination of RAW and JPEG (Large). |
| Color Space | sRGB, Adobe RGB |
| Picture Style | (1)Auto (2)Standard (3)Portrait (4)Landscape (5)Fine Detail (6)Neutral (7)Faithful (8)Monochrome (9)User Def. 1-3In Basic Zone modes, [Auto] will be set for and of the mode, and [Standard] will be set for other modes. In Creative Zone modes, you can select or set the Picture Style.[Auto] is the default setting for [User Def. 1-3]. |
| Settings | (1)Auto (Ambience priority/White priority) (2)Daylight (3)Shade (4)Cloudy* (5)Tungsten light (6)White fluorescent light (7)Flash (8)Custom (Custom WB) * Effective also in twilight and sunset. |
| Auto White Balance | Option between ambience priority and white priority settings |
| Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels Corrected in reference to the current WB mode's color temperature. |
| Type | Eye-level SLR (with fixed pentamirror) |
| Coverage | Coverage At approx. 19mm eye point |
| Magnification | Approx. 0.82x / 23.2° (50mm lens ∞, -1 m-1) |
| Eye Point | Approx. 19mm (at -1m-1 from the eyepiece lens center) |
| Dioptric Adjustment Correction | Adjustable from approx. -3.0 to +1.0 m-1 (dpt) |
| Focusing Screen | Fixed |
| Mirror | Quick-return half mirror |
| Viewfinder Information | Displayed with transparent liquid crystal (1)AF point information Including Area AF frame(2)Spot metering circle(3)Electronic level (4)Grid (5)Aspect line (6)Flicker detection |
| Depth Of Field Preview | Provided with depth of field preview button |
| Type | TTL secondary image-forming phase-difference detection system with AF-dedicated sensor |
| AF Points | AF Points Up to 45 points (cross-type AF points: max. 45)The number of AF points, cross-type AF points and dual cross-type AF points varies depending on the lens used. Note that, with aspect ratio of 1:1, the maximum number of AF points becomes 35. (Each left and right end line of AF points in total of ten are not usable.) |
| AF Working Range | AF Working Range Conditions: One-Shot AF, at 73°F/23°C, ISO 100 (based on Canon's testing standards and environment) |
| Focusing Modes | (1) Autofocus One-Shot AF Predictive AI Servo AFAI Focus AF (*Switches between One-Shot AF and AI Servo AF) *Switches between One-Shot AF and AI Servo AF(2) Manual focus (MF) |
| AF Point Selection | (1)Single-point AF (Manual selection)The checkmark cannot be removed from this option.(2)Zone AF (Manual selection of zone)All the AF points are divided into nine focusing zones.(3)Large Zone AF (Manual selection of zone)All the AF points are divided into three focusing zones.(4)Automatic selection AF (45 points) |
| AF Assist Beam | AF Assist Beam Intermittent firing of built-in flash Effective range With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead. |
| Metering Modes | 7560-pixel RGB+IR metering sensor 63-zone (9x7) metering 1)Evaluative metering (linked to all AF points) 2)Partial metering (center, approx. 6.0% of viewfinder) 3)Spot metering (center, approx. 3.5% of viewfinder) 4)Center-weighted average metering |
| Metering Range | EV 1-20 (room temperature, ISO 100, evaluative metering) |
| Exposure Control Systems | Creative Zone Program AE (Shiftable)Shutter-priority AE Aperture-priority AE Manual exposure (including bulb)Basic Zone Scene Intelligent Auto (Program AE/ non-shiftable)Flash Off Creative Auto Portrait Landscape Close-up Sports Special Scene Group Photo Kids Food Candlelight Night Portrait Handheld Night Scene HDR Backlight Control Creative Filters Grainy B/W Soft Focus Fish-eye Effect Water Painting Effect Toy Camera Effect Miniature Effect HDR Art Standard HDR Art Vivid HDR Art Bold HDR Art Embossed |
| ISO Speed Range | ISO Speed Range Manual Setting For [Highlight tone priority], the settable ISO speed range will be ISO 200–25600. Auto ISO Speed Settings*1 It depends on [Maximum] of [ISO Auto]. *2 If fill-in flash will cause overexposure, ISO 100 or a higher ISO will be set. |
| Exposure Compensation | Exposure Compensation*Up to ±2 stops, indicated in the viewfinder. *Up to ±3 stops when [Shooting screen: Guided] is set. |
| AE Lock | (1) Auto AE lock * In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved. (2) Manual AE lock * In the P, Tv, Av, and M modes, enabled with the AE lock button. (Press again to update.) * Enabled in all metering modes. |
| Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
| Shutter Speeds | 1/4000 to 30 sec., bulb (total shutter speed range. Available range varies by shooting mode.) X-sync at 1/200 sec. |
| Shutter Release | Soft-touch electromagnetic release |
| Self Timer | 10-sec. delay, 2-sec. delay |
| Shutter Lag Time | With SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.070 sec. Time lag between simultaneous SW-1/SW-2 ON and start of exposure: approx. 0.250 sec. Time lag with the aperture stopped down by 3 stops or less from the open aperture. Excludes AF operation time. |
| Flash Metering | E-TTL II autoflash (evaluative flash metering and average flash metering), FE Lock |
| Flash Exposure Compensation | ±2 stops in 1/3-stop or 1/2-stop increments |
| FE Lock | Provided |
| External Flash Settings | (1) External flash control Flash firing, E-TTL II metering, Flash mode, Wireless functions, Flash zoom, Shutter synchronization, Flash exposure compensation, Flash exposure bracketing and Clear settings. The radio wireless flash functions can be set from the camera. (2) External flash Custom Function setting The setting options for both (1) and (2) will differ depending on the Speedlite used. |
| Drive Modes | Single shooting High-speed continuous shooting Max. approx. 6.0 fps. Maximum continuous shooting speed with 1/500 sec. or faster shutter speed, maximum aperture (varies depending on the lens), Anti-flicker shooting set to Disable, with a fully-charged Battery Pack LP-E17 and at room temperature (73°F/23°C).With the AF mode set to One-Shot AF and the Image Stabilizer turned off when using the following lenses: EF 300mm f/4L IS USM, EF 28-135mm f/3.5-5.6 IS USM, EF 75-300mm f/4-5.6 IS USM, EF 100-400mm f/4.5-5.6L IS USM. Low-speed continuous shooting Max. approx. 3.0 fps Self-timer: 10 sec./remote control2 sec. self-timer Continuous shooting after 10-sec. self-timer (2 to 10 shots) |
| Continuous Shooting Speed | Continuous Shooting Time If the recording time reaches 29 min. 59 sec., the movie shooting stops automatically. Movie shooting does not stop automatically even if the file size reaches 4GB. (When an SDXC card is formatted in ex FAT, a movie will be recorded in a single movie file even if it exceeds 4GB.) |
| Maximum Burst | Maximum Burst The number of possible shots and maximum burst (standard) apply to an 8GB card based on Canon’s testing standards. The maximum burst (High-speed) apply to a 16GB card based on Canon’s testing standards. The file size, number of possible shots and maximum burst vary depending on shooting conditions(aspect ratio of 3:2, subject, memory card brand, ISO speed, Picture Style, etc.)“Full” indicates that shooting is possible until the card becomes full. |
| Shooting Modes | Still photo shooting and video shooting |
| Focusing | Dual Pixel CMOS AF Dual Pixel CMOS AF is possible with all EF and EF-S lenses. Contrast AF is not provided. Manual focus Magnifying the image by 5x or 10x for manual focus possible. |
| Metering Modes | Real-time metering with image sensor AE lock possible. The metering timer can be changed. Evaluative metering (315-zone) Partial metering (center, approx. 6.0% of viewfinder)Spot metering (center, approx. 2.6% of viewfinder)Center-weighted average metering AE lock possible. The active metering timer can be changed. |
| Metering Range | EV 0-20 (room temperature, ISO 100, evaluative metering) |
| Grid Display | (1)Off (2)3x3 (3)6x4 (4)3x3+diag |
| File Format | MP4: Video: MPEG-4 AVC / H.264 * Variable (average) bit rate Audio: AAC MOV: ALL-I (FHD 29.97, time-lapse movies only) |
| File Size | Recording Size: [Full HD] Standard: 1920 x 1080 (30 fps/25 fps/24 fps): 216 MB/min. Lightweight: 1920 x 1080 (30 fps/25 fps): 87 MB/min. [HD] Standard: 1280 x 720 (60 fps/50 fps): 187 MB/min. Lightweight: 1280 x 720 (30 fps/25 fps): 30 MB/min. [SD] Standard: 640 x 480 (30 fps/ 25 fps): 66 MB/min. Lightweight: 640 x 480 (30 fps/ 25 fps): 23 MB/min. * If the recording time reaches 29 min. 59 sec., the movie shooting stops automatically. * The file size is 4 GB, and shooting does not stop automatically. |
| Frame Rates | Video Recording Size and Frame Rates |
| Continuous Shooting Time | Continuous Shooting Time If the recording time reaches 29 min. 59 sec., the movie shooting stops automatically. Movie shooting does not stop automatically even if the file size reaches 4GB. (When an SDXC card is formatted in ex FAT, a movie will be recorded in a single movie file even if it exceeds 4GB.) |
| Focusing | Dual Pixel CMOS AF Contrast AF is not provided. Manual focus Magnifying the image by 5x or 10x for manual focus possible (not possible during movie shooting). |
| Range | Full range (0-255) |
| Exposure Control | Exposure Control*In Basic Zone modes, exposure control is exerted as appropriate for the detected scene |
| Type | TFT color, liquid-crystal monitor |
| Monitor Size | 3.0-inch (screen aspect ratio of 3:2) Approx. 3.03 in./7.70cm diagonal (approx. 2.51 in./6.37cm width, approx. 1.67 in/4.25cm height) |
| Pixels | Approx. 1.04 million dots |
| Coverage | Approx. 95%* * When the aspect ratio is 16:9, vertical viewfinder coverage is approx. 93%. |
| Brightness Control | Adjustable to one of seven brightness levels |
| Coating | Clear View LCD II Anti-smudge coating applied. Anti-reflection coating not applied. |
| Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
| Display Format | Single-image display No information display Basic information display Detailed shooting information display Basic shooting information Lens information and RGB histogram White balance Picture Style and sharpness Contrast, color saturation and color tone Color space and noise reduction Lens aberration correction GPS information (when GPS Receiver is used)Index display4-image9-image36-image100-image |
| Highlight Alert | With detailed information display, overexposed highlight areas with no image data will blink. |
| Histogram | Brightness and RGB |
| Items | Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback. After selecting an item, you can select contents by operating the Main Dial. |
| Protection | Single image (select image) Select range All images in a folder All images in a card All found images (only during image search) |
| Compatible Printers | PictBridge-compatible printers (wireless LAN only) |
| Printable Images | JPEG images compliant to Design rule for Camera File System RAW images can be printed. Movies cannot be printed. |
| DPOF | Complies to DPOF Version 1.1 |
| Custom Functions | 15 Custom Functions with 44 settings settable with the camera |
| Custom Controls | Functions can be assigned to the following control parts: Shutter button (halfway pressing)AE lock button SET button |
| My Menu Registration | My Menu Registration Up to six top-tier menu options and Custom Function settings can be registered. Up to five My Menu tabs can be added. |
| USB Terminal | Hi-Speed USB (USB 2.0)For PC communication For GP-E2 connection For Connect Station connection |
| Video Out Terminal | Type C (resolution switches automatically) * Video is not displayed unless the video format appropriate for the connected TV set, [NTSC] or [PAL], is set. |
| Extension System Terminal | 3.5mm diameter stereo mini jack Directional Stereo Microphone DM-E1 connection |
| Battery | Battery Pack LP-E17 x 1With the AC Adapter AC-E6N and DC Coupler DR-E18, AC power operation is possible. |
| Battery Life | Battery Life |
| Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 4 levels. |
| Power Saving | Power turns off after the set time (10/30* or 30 sec., 1, 2, 4, 8 or 15 min.) of non-operation elapses * Normally 10 sec. is set. 30 sec. will be set for function setting, Live View shooting, image playback, etc. |
| Date/Time Battery | Built-in secondary battery When fully-charged, the date/time can be maintained for approx. 3 months Recharge time: approx. 8 hrs. To become capable to maintain the right date/time for 3 months after main battery power depletion. |
| Start-up Time | Approx. 0.2 sec. (based on CIPA testing standards) |
| Dimensions (W x H x D) | Approx. 5.16 x 3.93 x 3.00 in. (131.0 x 99.9 x 76.2mm)CIPA compliant. |
| Weight | Approx. 18.77 oz. / 532g (including battery pack and SD memory card) Approx. 17.11 oz. / 485g (body only) |
| Working Temperature Range | 32-104°F/0-40°C |
| Working Humidity Range | 85% or less All data are based on Canon's Standard Test Method. Subject to change without notice. If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker. Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
next to your download
