Canon Support for imageCLASS D480 | Canon U.S.A., Inc.
imageCLASS D480
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.16.24
File Size 1.32 MB
Date 04.15.09
File Size 13.69 MB
Date 05.08.12
File Size 11.45 MB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 12.19.16
File Size 10.23 MB
Date 12.21.17
File Size 809.44 KB
Date 05.13.15
File Size 11.46 MB
Date 04.23.19
File Size 2.92 MB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 10.03.19
File Size 2.92 MB
Date 05.13.15
File Size 19.03 MB
Date 04.23.19
File Size 815.66 KB
Date 09.21.17
File Size 2.92 MB
Date 09.11.25
File Size 1.32 MB
Date 09.16.26
File Size 2.27 MB
Date 10.07.26
File Size 1.32 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS D480
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS D480
Printer
Printing Method Monochrome Laser
Print Speed (up to) Black:Up to 23 ppm (letter)
Print Resolution (Up to) Up to 600 x 600 dpi
1200 x 600 dpi quality
Toner Compatibility (for Laser MFP) Canon Cartridge 104 (Yield: 2,000 pages*)
Maximum Monthly Duty Cycle: 7,500 pages
*yield is based on 5% coverage document
Paper Weights 17 to 34 lb. (cassette)
17 to 43 lb. (multipurpose tray)
Copier
Copy Resolution (up to) Up to 600 x 600 dpi
Copy Speed (up to) Up to 23 cpm (letter)
Type Monochrome Laser
Zoom 50-200% in 1% increments
Halftones 256 levels
First Copy Time Approx. 9 seconds
Reduction / Enlargement 50%, 64%, 78% / 129%, 200%
Document Feeder 50-sheet1
Copy Size Platen: Up to 8.5" x 11.7"
ADF: Up to 8.5" x 14"
Copy Features Toner Saver Mode, 2 on 1
Scanner
Scanner Type Color Contact Image Sensor (CIS)
Max. Resolutions Up to 600 x 1200 dpi (optical)
9600 x 9600 dpi (interpolated)
Max. Document Size Platen: Up to 8.5" x 11.7"
File Format JPEG, PDF, TIFF, BMP
Fax
Modem Speed Up to 33.6 Kbps (Super G3)
Memory Capacity Up to 256 pages2
Fax Resolution Up to 203 x 391 dpi (super fine)
Speed Dialing Eight one-touch speed dials/100 coded dials
Receive Mode Fax Only, Manual, Answering, DRPD, Fax/Tel Auto Switch
Fax Features Remote RX, Dual Access, two-sided output
General
OS Compatibility Windows&reg; 7, Windows Server&reg; 2008, Windows Vista&reg;, Windows Server&reg; 2003, Windows XP/2000, Mac&reg; OS X 10.3.9 & up, Linux (print only)
Standard Interface USB 2.0 Hi-Speed3
Software Included Canon drivers for Windows®, Document Management & OCR Software
Power Consumption (approx.) 630W (Max), 3W (Energy Saver Mode)
Dimension (W x D x H) 15.4" (W) x 17.4" (D) x 14.2" (H)
Weight Approx. 28.0 lbs. (without Cartridge)
Warranty 1 year limited warranty4 (Extended Warranty available)
Canon imageCLASS D400 Series LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A Inc., (“Canon USA”) with respect to any Canon imageCLASS D400 SERIES copier (the “Product”) purchased and used in the United States, subject to the conditions below.
THIS LIMITED WARRANTY DOES NOT COVER THE CARTRIDGE 104 FOR WHICH A SEPARATE WARRANTY IS GIVEN. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE CARTRIDGE 104 LIMITED WARRANTY.
The Product, when delivered to the original purchaser or the person for whom it was purchased as a gift (the “Purchaser”) in new condition in the original container, is warranted against defective materials or workmanship, under normal use and service, for a period of one (1) year from the date of purchase as follows: defective parts in the Product, proven to be defective upon inspection, will be repaired or replaced with new or comparable rebuilt parts when such Product is returned to a Canon Authorized Service Facility (“ASF”) under the CARRY-IN/MAIL-IN SERVICE option described below, or with a refurbished or reconditioned unit when such Product is returned to Canon USA under the EXCHANGE SERVICE option described below. This warranty shall not extend to consumables such as paper, as to which there shall be no warranty or replacement. Warranty replacement shall not extend the original warranty period of the Product.
In order to obtain warranty service, please call the Canon Help Desk at 1-800-OK-Canon, between 8 a.m. and 8 p.m. ET, Monday through Friday, except holidays, to obtain either CARRY-IN SERVICE /MAIL-IN SERVICE OR EXCHANGE SERVICE, and follow the applicable procedures (described below). Note that a dated proof of purchase is required at the time of service. This requirement will be satisfied by providing a copy of your dated bill of sale or invoice.
1) CARRY-IN/MAIL-IN SERVICE: You will be provided the name and telephone number of the ASF nearest to your location. You must contact an ASF during such ASF’s normal business hours to schedule the repair. If shipping is involved, it is your responsibility to properly package and send the Product (at your cost) to the ASF, together with your dated proof of purchase and a complete explanation of the problem. A Product covered by this limited warranty will be repaired and returned to you without charge by the ASF. Repairs not covered under this warranty will be charged to you at the then-current service rates of the ASF.
2) EXCHANGE SERVICE: A Canon Help Desk technician will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the problem cannot be corrected over the telephone, a Return Authorization Number (RA) will be issued to you. You will be asked for the Product serial number and other information pertaining to your defective Product and for a ship-to location for the replacement Product (street address only, no P.O. box). You must also provide your major credit card number. Your credit card will be charged in an amount up to the cost of a new Product (a) if your defective Product is not received by Canon USA within 10 business days after you receive the replacement Product, (b) if the defects in the defective Product are not covered by this limited warranty; or (c) if the warranty period on the Product has expired or has not been sufficiently established by you by supplying the appropriate documentation.
The Canon Help Desk will ship out the replacement Product prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the instructions on how to ship the defective Product to Canon USA. You must return the defective Product in the shipping carton in which the replacement Product was packed, include the Return Authorization Number (RA), a copy of your dated proof of purchase (bill of sale), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS IN THE RETURN SHIPPING CARTON AND BE SURE TO RETAIN YOUR CARTRIDGE, POWER CORD, USER’S MANUAL, PAPER TRAYS, AND WARRANTY CARD.
EXCHANGE SERVICE expedites, in three (3) business days, the exchange of a defective Product with a replacement Product, except that the Canon Help Desk must receive your request for this service by 6 p.m. ET, Monday through Friday, except holidays, to ensure three (3) business day EXCHANGE SERVICE (four (4) business day EXCHANGE SERVICE for Alaska and Hawaii.) Canon USA does not guarantee three (3) business day service in the event of the occurrence of factors beyond Canon USA’s reasonable control. The replacement Product you receive will be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE DEFECTIVE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA.
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
Regardless of which service option you choose, this warranty shall be void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions, or environmental conditions, prescribed in Canon USA's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon USA who are acting in accordance with Canon USA's service bulletins, (d) use of supplies or parts (other than those distributed by Canon USA) which damage the Product or cause abnormally frequent service calls or service problems or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered.
NEITHER CANON USA NOR ANY ASF SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY ASF), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR FOR ANY OTHER SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA OR ANY ASF HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES, NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY ASF BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESION, USE, MISUSE OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY ASF. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU.) THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT AND STATES YOUR EXCLUSIVE REMEDY.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
