Canon Support for imageCLASS LBP214dw | Canon U.S.A., Inc.
imageCLASS LBP214dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 01.30.23
File Size 2.16 MB
Date 12.19.23
File Size 1.85 MB
Date 01.30.23
File Size 2.26 MB
Date 10.03.19
File Size 958.35 KB
Date 09.16.24
File Size 1.85 MB
Date 04.26.18
File Size 4.39 MB
Date 12.01.20
File Size 961.90 KB
Date 09.17.18
File Size 948.95 KB
Date 03.02.26
File Size 1.85 MB
Date 10.07.26
File Size 1.85 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS LBP214dw
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS LBP214dw
imageCLASS LBP214dw Spec Sheet
imageCLASS LBP214dw
MAIN UNIT
TYPEBlack and White Laser Single Function
CORE FUNCTIONSStandard: Print
PROCESSORCanon Custom Processor
CONTROL PANEL5-line LCD
MEMORY1GB
STANDARD INTERFACE CONNECTIONUSB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LTR, 20LB BOND)Standard: 350 Sheets
Maximum: 900 Sheets
PAPER SOURCES (LTR, 20LB BOND)
Standard: 250-sheet Paper Cassette, 100-sheet
Stack Bypass
Optional: 550-sheet Paper Cassette (Cassette Unit-AH1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND)Standard: 65 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Thick, Bond
Stack Bypass: Thin, Plain, Recycled, Thick, Bond,
Label, Envelope (10 Envelopes)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive
Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Stack Bypass: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL
Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassettes: 14.0 lb. Bond to 32.0 lb. Bond (52 to 120 g/m2)
Stack Bypass: 14.0 lb. Bond to 43.0 lb. Bond (52 to 163 g/m2)
WARM-UP TIMEFrom Power On: 14 Seconds or less
From Sleep Mode: 4 Seconds or less
DIMENSIONS (W x D x H)Standard (Desktop): 15.8" x 14.7" x 9.9" (401 mm x 373 mm x 250 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 19.7" x 38.3" x 9.9" (501 mm x 974 mm x 250 mm)
Fully Configured: 19.7" x 38.3" x 15.0" (501 mm x 974 mm x 381 mm)
WEIGHTMachine Only: Approx. 19.4 lb. (8.8 kg)
Boxed Weight: Approx. 28.7 lb. (13.0 kg)
PRINT SPECIFICATIONS
PRINTING METHODLaser Beam Printing
PRINT SPEED3Up to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST PRINT-OUT-TIMEApproximately 6 seconds
RECOMMENDED MONTHLY PAGE VOLUME750 - 4,000 Pages
PRINT RESOLUTION (dpi)600 x 600
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL®6, PCL®5, Adobe PostScript 3®
DOUBLE SIDED PRINTINGAutomatic (Standard)
DIRECT PRINTAvailable from USB memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES4Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service, Google Cloud Print,™5
FONTSPCL fonts: 45 Fonts
PS fonts: 136 Fonts
OPERATING SYSTEMUFR II/PCL/PS:
Windows®7 / Windows 8.1 / Windows 10 / Windows Server2008 / Windows Server2008 R2 / Windows Server2012 / Windows Server2012 R2 / Windows Server2016
Mac OS X v10.8.5 (or later)
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
NETWORKStandard: IP/MAC Address Filtering, IPSEC, TLS
Encrypted Communication, SNMP V3.0, IEEE
802.1X, IPv6
DOCUMENTStandard: Secure Print
WI-FI AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50 to 86º F
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTSAC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTIONMaximum: Approx. 1320 W
Standby: Approx. 10 W
Sleep Mode: Approx. 0.9 W
Typical Electricity Consumption (TEC) Rating: 1.3 kWh
STANDARDSENERGY STAR® Qualified, Rated EPEAT Silver
OPTIONAL ACCESSORIES
Cassette-AH1Item No.: 0732A033
Holds up to 550 Sheets
FOOTNOTES
1 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
2 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
3 Print speed is based on internal testing. Print speed may vary depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
4 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
5 Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
PRODUCT LIMITED WARRANTY
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Advisory Type Service Notice
Date 04.19.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
