Canon Support for imageCLASS LBP236dw | Canon U.S.A., Inc.
imageCLASS LBP236dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 01.30.23
File Size 2.16 MB
Date 12.19.23
File Size 1.85 MB
Date 01.30.23
File Size 2.26 MB
Date 10.07.21
File Size 4.13 MB
Date 09.16.24
File Size 1.85 MB
Date 10.07.21
File Size 4.15 MB
Date 03.02.26
File Size 1.85 MB
Date 10.07.26
File Size 1.85 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS LBP236dw
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS LBP236dw
Products ChromeOS
imageCLASS LBP236dw
imageCLASS LBP236dw Spec Sheet
imageCLASS LBP236dw
MAIN UNIT
CORE FUNCTIONS
Standard: Print
ITEM CODE
516C005
PROCESSOR
Canon Custom Processor
CONTROL PANEL
5-line LCD
MEMORY
1 GB
STANDARD INTERFACE CONNECTION
USB 2.0, High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n,Wi-Fi® Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 350 Sheets
Maximum: 900 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 250-sheet Paper Cassette, 100-sheet
Multipurpose Tray Optional: 550-sheet Paper Cassette (Cassette Unit-AH1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard: 65 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Thick, Bond
Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Multipurpose Tray: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
WARM-UP TIME
From Power On: 14 Seconds or Less
From Sleep Mode: 4 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop): 15.8" x 14.7" x 9.8"(401 mm x 373 mm x 249 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 15.8" x 31.7" x 12.3"(401 mm x 804 mm x 312 mm)
Fully Configured: 15.8" x 34.4" x 15.0"(401 mm x 874 mm x 381 mm)
WEIGHT
Machine Only: Approx. 19.4 lb. (8.8 kg)
Boxed Weight: Approx. 28.7 lb. (13.0 kg)
OPERATING SYSTEMS
UFR II/PCL/PS: Windows® 10/8.1, Windows Server 2019/2016/2012 R2/2012/Mac OS X (10.11 or later)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED4
Up to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST PRINT OUT TIME
Approx. 5.4 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
750 - 4,000 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, PCL®5, Adobe PostScript 3®
DOUBLE-SIDED PRINTING
Automatic (Standard)
DIRECT PRINT
Available from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1
Apple® AirPrint,® Mopria® Print Service, Canon PRINT Business
FONTS
PCL:93
Fonts PS: 136 Fonts
PRINT FEATURES
Secure Watermark, Header/Footer, Page Layout, Two-sided Printing, Mixed Paper Sizes, Orientations, Toner Reduction, Poster Printing, Print Date, Collating, Grouping, Page Border5, Booklet Printing5
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
DATA
Standard: Verify System at Startup
NETWORK
Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0,IEEE 802.1X, IPv6
DOCUMENT
Standard: Secure Print
WI-FI AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode:
WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:5.9 A, 60 Hz
POWER CONSUMPTION
Maximum: Approx. 1300 W
Standby: Approx. 8.5 W
Sleep Mode: Approx. 0.9 W
Typical Electricity Consumption (TEC) Rating: 0.33 kWh
STANDARDS
ENERGY STAR® Qualified, Currently Rated EPEAT Silver¿2
CONSUMABLES
TONER
Cartridge 057 Black, Standard - Yields up to 3,100 Pages
Cartridge 057 Black, High Capacity - Yields up to 10,000 Pages
PRODUCT LIMITED WARRANTY
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
Title Service Notice: Toner Cartridge Auto Replenishment Service (ARS) will be down for planned server maintenance
Advisory Type Service Notice
Date 03.03.23
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Date 04.19.23
Title Service Notice: Regarding Vulnerability Measure Against Buffer Overflow for Laser Printers and Small Office Multifunctional Printers
Date 02.05.24
Date 06.20.25
Title Service Notice: Regarding Remediation Measure Against Potential Buffer Overflow Vulnerability in Laser Printers and Small Office Multifunctional Printers
Date 02.23.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
