Canon Support for imageCLASS MF244dw | Canon U.S.A., Inc.
imageCLASS MF244dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
WINDOWS
macOS X
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 | Golden Gate 27 |
Printer Specifications
| Printer Type | Monochrome Laser |
| Print Speed | Up to 16ppm (2-sided plain paper letter) / 28ppm (1-sided plain paper letter)1 |
| First Print Time | 6 seconds or less (letter)2 |
| Printer Language | UFR II LT (Host-based), PCL (5e, 6) |
| Print Resolution | Up to 600 x 600 dpi |
| Maximum Print Size | Up to Legal (8.5 x 14 inches) |
| Duplex Print | Yes |
| Print Modes | Watermark, Page Composer, Toner Saver |
| Print Memory | 512 MB (Shared) |
Copier Specifications
| Copy Speed | Up to 28ppm (letter, 1-sided), Up to 16ppm (letter, 2-sided) |
| Copy Resolution | Up to 600 x 600 dpi |
| Original Type | Text/Photo, Text, Photo |
| Halftones | 256 Levels |
| Warm-up Time | 14 seconds or less from power on |
| First Copy Time | Approximately 9 seconds3 |
| Recovery Time | Approximately 2 seconds |
| Maximum Number of Copies | Up to 999 copies |
| Reduction/Enlargement | 25-400% in 1% increments |
| Copy Size | Platen: Up to 8.5 x 11, Feeder: Up to 8.5 x 14 |
| Copy Features | Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
| Copy Memory | 512 MB (Shared) |
Scanner Specifications
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-bit |
| Scan Resolution | Up to 600 x 600 dpi (optical) |
| Scan Size | Platen / Feeder: Up to Legal |
| Duplex Scan | No |
| Compatibility | TWAIN, WIA, ICA |
| Scan Features | Push Scan, Pull Scan: USB and Network |
Paper Handling Specifications
| Standard Paper Source(s) | 250-sheet cassette plus 1-sheet multipurpose tray, 16-43 lb. (bond, plain paper)4 |
| Document Feeder | 35-sheet Auto Document Feeder4 |
| Paper Output | 100 sheets (face down) |
| Media Sizes | Letter, Legal, Executive, Statement |
| Media Types | Plain, Color, Recycled, Heavy, Bond, Label, Envelope |
| Envelope Capacity | 1 (Multipurpose Tray) |
| Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
| Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (Network), 802.11 b/g/n Wireless5, Wi-Fi Direct Connection6 |
| WiFi Access Mode | Infrastructure Mode, WPS Easy Set Up |
| WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
| WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
| Mobile Functions | Canon PRINT Business7, Apple® AirPrint®8, Mopria™ Print Service9, Google Cloud Print™10 |
| Network Functions | Print, Scan |
| Web Browser Support for Remote UI | IE 7.0 or higher, Safari 3.2.1 or higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6), IPP, IPPS |
| TCP/IP Set of Application Services | Bonjour(mDNS),DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1/SNMPv3 (IPv4,IPv6), HTTP/HTTPS, SNTP |
| OS Compatibility | Windows® 10, 8.1, 8, 7, Windows Vista®,Windows Server® 2012, 2012 R2, 2008, 2008 R2, 2003, 2003 R2, Mac OS 10.6.8 or later |
| Cable Included | Power Cord (USB not included) |
| Bundled Software | Printer driver, Fax driver, Scanner driver, MF Scan Utility, Address Book Tool |
Environmental Specifications
| Power Consumption | Approx: Operation: 480 W, Standby: 4.1 W, Energy Saver: 1.2 W (USB), 1.3 W (wired), 2 W (wireless) |
| Typical Energy Consumption | 0.9kWh |
General Specifications
| Dimensions | 15.4"(W) x 14.7"(D) x 14.2"(H) |
| Unit Weight (without/with cartridge) | 26.7 lbs. w/o cartridge, 28 lbs. w/ cartridge |
| Package Weight | 37.5 lbs |
| Cartridge Type | Cartridge 137 (Yields approximately 2,400 pages), Single Cartridge System *Yields based on ISO/IEC Standard |
| LCD Display | Tiltable LCD |
| Duty Cycle | Up to 15,000 pages per month, RMPV (Recommended Monthly Print Volume): 750 - 3,000 pages |
| Security | IP/MAC address filtering, IEEE802.1x, SNMPv3, HTTPS/IPPS |
| Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Simplified Chinese, Traditional Chinese, Korean |
| Warranty | 1 year limited exchange/carry-in warranty11 (Extended warranty available) |
PRODUCT LIMITED WARRANTY
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
next to your download
